How to change bases?
12-01-2019, 08:43 AM
RE: How to change bases? | |||
12-01-2019, 02:42 PM
(This post was last modified: 12-01-2019 02:46 PM by rprosperi.)
(12-01-2019 08:43 AM)Didier Lachieze Wrote:(11-30-2019 02:41 PM)rprosperi Wrote: I usually find the stories behind such discoveries (think the 42S hex table at Taco Bell) at least as interesting as the actual result itself. Full disclosure, it was actually a Jack in the Box, I just used Taco Bell as a metaphor... Here's a recent post with a quick summary (prior versions detailed how good the cheeseburger was): https://www.hpmuseum.org/forum/thread-14...#pid124274 --Bob Prosperi |
12-02-2019, 06:16 AM
(This post was last modified: 12-02-2019 06:18 AM by Tim Wessman.)
So just looked at the code and found something interesting that was put in at r9649... looks like all of this got lost somewhere and missed documenting/testing. Most likely you will wipe all memory, fry your CPU, and potentially explode, so don't blame me. Also, i suspect that will be removed at some point as they really dont belong in "CONVERT" and should be in a different location.
Code: if (wcsicmp2(Params[1]->String()->string(), L"base")==0 && NbParams==3) return BaseConvertion(Params[0], Params[2]); TW Although I work for HP, the views and opinions I post here are my own. |
12-03-2019, 02:05 AM
here an alternative to converge base numbers, from base 2 to base 31 and also numbers of decimal places
the program link in the video description |
