linear mode (Entry: algebraic)
01-13-2020, 03:25 PM
(This post was last modified: 01-25-2020 03:16 AM by compsystems.)
Hi. Good morning
The following code can be entered directly on the entry line, but only work in CAS and linear mode (Entry: algebraic/1D). Why? the definition failure in textbook mode (aka pretty print or 2D input) Please copy and paste the following codes into the input line (simulator) PHP Code: function fract(X_,Y_,Nmax) // Mandelbrot fractal, not using symmetry. //deltalist(time(fract(320,240,10))); fract(320,240,10) from program editor with please add the header #cas ... #end PHP Code: function fract1(X_,Y_,Nmax) // Mandelbrot fractal, using symmetry. fract1(320,240,10) |
01-13-2020, 04:03 PM
RE: linear mode (Entry: algebraic)
(01-13-2020 03:25 PM)compsystems Wrote: Hi. Good morning Why not? In RPN mode, you'd enter the parameters on the stack then call the function. 320 ENTER 240 ENTER 10 ENTER fract1() Tom L Cui bono? |
01-13-2020, 07:00 PM
(01-13-2020 03:25 PM)compsystems Wrote: The following code can be entered directly on the entry line, but in linear mode (Entry: algebraic) mode why? Failure in textbook mode I have tried it in both modes and they work without problems. FW 2019 11 20 BETA Have you tried restoring the Home and CAS settings? That code should work smoothly with a default setting. Viga C | TD | FB |
01-13-2020, 11:49 PM
(This post was last modified: 01-14-2020 02:46 AM by compsystems.)
The code works well and the function is well defined only in Algebraic mode.
I just found the problem. When the function is defined from the input line and when this input mode (textbook) the comments are interpreted as double division // -> ÷÷ I hope that the problems that are reported are solved, the history view has problems just like the input line. Solution interpret double // as a comment, also interpret the symbols # and © as a comment |
01-14-2020, 12:31 AM
Acabo de entender tu punto, haces cosas extrañas xD.
Pues sí, ciertamente para trabajar perfectamente en el CAS se debe cambiar a modo algebraico, ya que Libro de texto adiciona caracteres para el formato, eso es algo normal y es una limitación esperada. Estaba probando los códigos desde #cas #end en un contenedor de programa, te recomendaría que trabajes directamente ahí. I just understood your point, you do strange things xD. Well yes, certainly to work perfectly in the CAS must be changed to algebraic mode, since Textbook adds characters to the format, that is normal and is an expected limitation. I was testing the codes from #cas #end in a program container, I would recommend that you work directly there. Viga C | TD | FB |
01-14-2020, 02:40 AM
(This post was last modified: 01-14-2020 08:37 PM by compsystems.)
It is easier to copy a code made in an external editor or copy it from a website and paste it directly into the calculator (simulator) input line, instead of going to the calculator's program editor, due to its small screen limitation. The problem It is solved by working in linear mode but it is necessary to be constantly changing to pretty print (Text book), another solution is to previously remove the comments of each code to be defined, but the most practical solution is that the interpreter of the input line knows how to differentiate the operator division / of a commentary //
and even the definition fails if you enter from the variable editor [shift]+[mem] + CAS Vars using / * and * / also fails PHP Code: function fract(X_,Y_,Nmax) /* Mandelbrot fractal, not using symmetry. */ |
