Half-precision Γ(x+1) [HP-12C]
02-16-2020, 12:30 AM
and about half the memory space.
0.1 R/S -> 0.9(392743098) 0.5 R/S -> 0.8862(420073) 1 R/S -> 1.0000(93310) 2 R/S -> 2.0000(31342) 3 R/S -> 6.0000(24847) 4 R/S -> 24.0000(3634) 5 R/S -> 120.0000(823) 10 R/S -> 3628800.(316) 12 R/S -> 4790016(319) 13 R/S -> 622702(1117) 14 R/S -> 8.717829(639) 10 15 R/S -> 1.307674(440) 12 20 R/S -> 2.432902(140) 18 50 R/S -> 3.041409(537) 64 60 R/S -> 8.3209871(88) 81 69 R/S -> 1.7112245(67) 98 69.95 R/S -> 9.68284767(3) 99 |
02-16-2020, 05:47 PM
RE: Half-precision Γ(x+1) [HP-12C]
Very nice and compact formula, where did you get it ?
I am curious, your thread named half-precision, does a full-precision version exist ? I rewrite below term, reduced 9 steps, all done in the stack. \(\large c={840 x^2 + 314x + 66 \over 5040x^2 + 1464x + 419} = {1 \over {6 - {1 \over \Large 2x + {360x+66 \over 420x-23} }}}\) \(\Gamma(x+1) ≈ (x/e)^x \sqrt{2\pi(x+c)}\) Code: 01- ENTER |
02-16-2020, 07:39 PM
(02-16-2020 05:47 PM)Albert Chan Wrote: Very nice and compact formula, where did you get it ? That was just a test. I have seen correction factors to Stirling's approximation outside the surd, so I decided to place a continued fraction inside it, hoping it to eventually assume a generalized form. If such an infinite continued fraction existed, then it would be easy to get full accuracy with minimum memory for whatever programmable calculator or computer we would like to implement it on. Anyway, here is what I have so far, in case someone is interested in finding the elusive pattern, if any: \[x! \approx \sqrt{2\pi \left ( x + \frac{1}{6-\frac{1}{2x+\frac{6}{7-\frac{5}{3x+\frac{11}{20}}}}} \right )}\left ( \frac{x}{e} \right )^{x}\] Here, the last denominator (11/20) is somewhat arbitrary. I had written it using the plain continued fraction above, in 47 steps or so, but since it's not definitive, I decided to use the Horner form version. In the linked Wikipedia article there is an even more compact and more accurate formula. Scroll down to "Versions suitable for calculators" and look for Gergő Nemes's formula. Back to the continued fraction, that was the latest one I was trying yesterday: \[x + \frac{1}{6-\frac{1}{2x+\frac{6}{7-\frac{5}{3x+\frac{11}{8-\frac{9}{4x+\frac{16}{23-\frac{13}{5x+\frac{21}{10}}}}}}}}}\] I think the first four or five terms are correct. The next terms don't appear to improve the approximation, so they are partially or completely wrong. |
02-17-2020, 05:43 AM
(This post was last modified: 02-17-2020 05:45 AM by Gerson W. Barbosa.)
More than two-third precision and one-third the program memory space using Gergő Nemes's formula mentioned above:
0.1 R/S -> 0.951(1141433) 0.5 R/S -> 0.886(1706366) 1 R/S -> 0.9999(830883) 2 R/S -> 1.99999(5097) 3 R/S -> 5.99999(6379) 4 R/S -> 23.99999(521) 5 R/S -> 119.99999(02) 10 R/S -> 3628799.99(3) 12 R/S -> 479001599.(2) 13 R/S -> 6227020(775) 14 R/S -> 8.7178291(15) 10 15 R/S -> 1.307674368 12 20 R/S -> 2.4329020(19) 18 50 R/S -> 3.0414093(04) 64 60 R/S -> 8.32098711(0) 81 69 R/S -> 1.7112245(50) 98 69.67 R/S -> 2.9433192(47) 99 |
02-20-2020, 08:25 AM
This version used two Registers: R0 and R1
Store Pi to R0 Γ(x) for 1 ≤ x ≤ 64 --------------------- Example: [FIX] 2 Γ(5.25) 5.25 [R/S] 35.21 7! = Γ(8) 8 [R/S] 5040.00 2.34! = Γ(3.34) 3.34 [R/S] 2.80 -------------------- Program: Code:
Remark: This routine is adapted from HP-55 Statistic Programs P.14 Gamo |
04-23-2020, 10:59 AM
(This post was last modified: 04-23-2020 11:14 AM by Gerson W. Barbosa.)
(02-16-2020 07:39 PM)Gerson W. Barbosa Wrote: If such an infinite continued fraction existed, then it would be easy to get full accuracy with minimum memory for whatever programmable calculator or computer we would like to implement it on. Most likely there is no such a continued fraction, otherwise it would be known by now. If it existed short programs for gamma function would be possible, like the one below for the HP-75C. The results won’t become any better by increasing the number of iterations (I). 10 INPUT X 15 Y=2*X 20 I=4 25 N=5*I-4 30 D=I+5 35 C=Y+(N+5)/(D+1) 40 FOR K=1 TO I 45 C=Y+N/(D-N/C) 50 N=N-5 55 D=D-1 60 NEXT K 70 F=SQR(2*PI*(C-X))*(X/EXP(1))^X 75 DISP F .5-> .88662(7414717) 1 -> 1.0000(5537894) 2 -> 2.00000(622165) 3 -> 6.00000(235186) 4 -> 24.00000(15634) 5 -> 120.000000(852) 6 -> 719.999996708 (720) 7 -> 5039.99996836 (5040) 8 -> 40319.9997698 (40320) 9 -> 362879.998278 (362880) 10-> 3628799.98602 (3628800) 11-> 39916799.8757 (39916800) 12-> 479001598.800 (479001600) 13-> 6227020787.22 (6227020800) 14-> 87178291052.2 (87178291200) 15-> 1.30767436(614)E12 20-> 2.43290200(663)E18 50-> 3.041409320(28)E64 60-> 8.320987112(84)E81 69-> 1.711224524(11)E98 P.S.: The results will be consistently less then the exact ones (except when x is close to 0) if line 20 is changed to 20 I=2 |
04-27-2020, 05:12 PM
(This post was last modified: 04-27-2020 09:15 PM by Gerson W. Barbosa.)
RE: 4/5th-precision Γ(x+1) [HP-41C]
41 steps on my HP-41C (but you can always make it shorter).
01 LBL "GXP1" 02 ENTER 03 ENTER 04 336 05 * 06 224 07 + 08 X<>Y 09 * 10 99 11 ST+ Y 12 X<> L 13 ENTER 14 ENTER 15 56 16 * 17 42 18 + 19 X<>Y 20 * 21 18 22 ST+ Y 23 X<> L 24 X<> Z 25 / 26 X<>Y 27 + 28 ST+ X 29 LASTX 30 RCL X 31 -1 32 E^X 33 * 34 X<>Y 35 Y^X 36 X<>Y 37 PI 38 * 39 SQRT 40 * 41 END .5-> 0.8862(859731) 1 -> 1.00000(8281) 2 -> 2.00000(1930) 3 -> 6.000000(983) 4 -> 24.000000(68) 5 -> 120.0000000 6 -> 719.9999952 (720) 7 -> 5039.999965 (5040) 8 -> 40319.99985 (40320) 9 -> 362879.9989 (362880) 10-> 3628799.990 (3628800) 11-> 39916799.89 (39916800) 12-> 479001598.8 (479001600) 13-> 6227020801 (6227020800) 14-> 871782912(1)E10 15-> 1.307674368E12 20-> 2.4329020(11)E18 50-> 3.0414093(32)E64 60-> 8.3209871(07)E81 69-> 1.71122452(1)E98 69.95 -> 9.68284767(8)E99 P.S.: 37 steps 01 LBL "GXP1" 02 ENTER 03 ENTER 04 + 05 RCL X 06 1.5 07 + 08 6 09 X<>Y 10 / 11 CHS 12 7 13 + 14 6 15 X<>Y 16 / 17 + 18 1/X 19 CHS 20 6 21 + 22 1/X 23 + 24 ST+ X 25 X<>Y 26 R^ 27 -1 28 E^X 29 * 30 X<>Y 31 Y^X 32 X<>Y 33 PI 34 * 35 SQRT 36 * 37 END |
09-12-2020, 01:15 AM
(This post was last modified: 09-13-2020 01:25 PM by Albert Chan.)
Hi, Gerson
With the help of Wolfram Alpha, I have improved on your surd-based CF correction. Turning series of (Gamma(1+x)/(x/e)^x)^2/(2*pi), x=inf to continued fractions: \(\large \left({x! \over (x/e)^x}\right)^2 / (2\pi) ≈ x + \Large \frac{1}{6-\frac{1}{\left(2x+\frac{77}{90}\right) +\frac{1}{\left(\frac{16200}{5929}x + \frac{86748660}{246071287}\right) }}} \) But, we can do much better with corrections to lgamma(x) - ln(stirling(x)): XCas> series(lgamma(x) - ln(sqrt(2*pi/x)*(x/e)^x), x=inf, 10, polynom) \(\large {(1/x) \over 12} - {(1/x)^3 \over 360} + {(1/x)^5 \over 1260} - {(1/x)^7 \over 1680} + {(1/x)^9 \over 1188} \) Even better, coefficients can be easily generated = \(\large{B_{2k} \over (2k)(2k-1)}\) Example: first coefficient = B2/(2*1) = 1/12 Above series is usable as-is, but its continued fraction form is better: \(\frac{1}{12\cdot x +\large \frac{1}{\frac{5}{2} \cdot x +\frac{1}{\frac{84}{53} \cdot x +\frac{1}{\frac{2809}{2340} \cdot x +\frac{1}{\frac{1003860}{1218947} \cdot x}}}}}\) Lets compare all 3 continued fraction corrections (c1 = Gerson original version) Note: "bottom" coefficient adjusted to gives better factorial approximation, for small x. Since all CF are based from asymptotic series, the adjustment will not affect big x. For fair comparison, we define x! = Γ(x+1), with same sized x. (this also gives better factorial approximations, since all assumed big x) Code: function c1(x) return 1/(6-1/(2*x+6/(7-5/(3*x+11/20)))) end lua> fmt = '%g\t%-18.10g%-18.10g%-18.10g' -- show 10 digits precision lua> for x = 1,10 do print(fmt:format(x, fac_c1(x), fac_c2(x), fac_c3(x))) end 1 1.000015628 0.9999985323 1 2 2.000008196 1.999999694 1.999999998 3 6.000008831 5.999999848 5.999999999 4 24.00001549 23.99999988 24 5 120.0000389 119.9999999 120 6 720.000129 719.9999999 720 7 5040.000538 5040 5040 8 40320.00271 40320 40320 9 362880.0161 362880 362880 10 3628800.11 3628800 3628800 Update: Instead of adjusting c3 coefficients, I kept everything exact, and add a correction. To keep code short, I turn all constants to integer. lua> function c3(x) return 1/(12*x+2/(5*x+53/(42*x+1170/(53*x+22999/(429*x+470/x))))) end lua> for x=1,10 do io.write(('%.10g '):format(fac_c3(x))) end; print() 1 2 6 24 120 720 5040 40320 362880 3628800 |
09-12-2020, 01:14 PM
Very good job! You can call it full-precision Γ(x+1) now.
09-13-2020, 10:29 PM
(This post was last modified: 09-14-2020 08:52 AM by Albert Chan.)
Another approach is not to use asymptotic formula at all, and use Lanczos algorithm.
see The Log Gamma Function with C#, for comparison of different methods. I don't understand how it work, but Lanczos is amazing ! Translated code from above link, for HP-71B: Code: 10 DIM C(6) @ K=LN(2*PI)/2-5 >RUN >FOR X=10 TO 90 STEP 10 @ X, FNL(X), LN(GAMMA(X))-RES @ NEXT X 10 12.8018274802 -.0000000001 20 39.3398841871 .0000000001 30 71.2570389671 .0000000001 40 106.63176026 .000000001 50 144.565743946 0 60 184.533828862 -.000000001 70 226.190548324 0 80 269.291097651 0 90 313.65282995 0 Below is doing *negative* fractional factorials ! >FOR X=.1 TO .9 STEP .1 @ X, FNG(X), GAMMA(X)-RES @ NEXT X .1 9.51350769862 .00000000005 .2 4.59084371199 .00000000001 .3 2.99156898768 .00000000001 .4 2.21815954376 0 .5 1.7724538509 .00000000001 .6 1.48919224879 .00000000002 .7 1.29805533263 .00000000002 .8 1.16422971372 .00000000001 .9 1.06862870212 0 |
09-15-2020, 04:30 AM
(09-13-2020 10:29 PM)Albert Chan Wrote: Another approach is not to use asymptotic formula at all, and use Lanczos algorithm. Lanczos approximation is great. The problem is the constants take up too much memory space on the 12C and even on the HP-41C, I fear. |
09-16-2020, 08:02 PM
(02-16-2020 12:30 AM)Gerson W. Barbosa Wrote: and about half the memory space. Thanks for this. I’m having fun with it on my HP-38C emulator (RPN-38CX). Here’s my listing. If anyone has RPN-38CX, you can paste this directly into the display in program mode. By the way, I changed storage register 1 to I. That way no numbered or Financial registers are used. [code] 01 - 31 ENTER 02 - 31 ENTER 03 - 31 ENTER 04 - 8 8 05 - 4 4 06 - 0 0 07 - 61 × 08 - 3 3 09 - 1 1 10 - 4 4 11 - 51 + 12 - 61 × 13 - 6 6 14 - 6 6 15 - 51 + 16 - 21 26 STO I 17 - 25 33 R↓ 18 - 5 5 19 - 0 0 20 - 4 4 21 - 0 0 22 - 61 × 23 - 1 1 24 - 4 4 25 - 6 6 26 - 4 4 27 - 51 + 28 - 61 × 29 - 4 4 30 - 1 1 31 - 9 9 32 - 51 + 33 - 21 71 26 STO ÷ I 34 - 25 33 R↓ 35 - 22 51 26 RCL + I 36 - 7 7 37 - 1 1 38 - 0 0 39 - 61 × 40 - 1 1 41 - 1 1 42 - 3 3 43 - 71 ÷ 44 - 24 21 √x 45 - 25 33 R↓ 46 - 25 33 R↓ 47 - 25 23 LN 48 - 1 1 49 - 41 − 50 - 61 × 51 - 25 22 eˣ 52 - 61 × 53 - 25 7 00 GTO 00 [code] Regards, Bob |
