Ans before minus problem [Beginner Alert]
03-24-2020, 09:19 AM
Well, decided to buy the hp prime for school and now I've ended up in a problem. Every time I enter a negative number, especially irritating in statistics, "Ans" decides to pop up before the minus sign. Making go back a step to delete 3 letters every time I need to input a negative number. Is there an option to dissable the automatic "ans"?
03-24-2020, 11:12 AM
RE: Ans before minus problem [Beginner Alert]
Seems you are using the subtraction operand (-) instead of the change sing key (+/-)
11C 12C 15C 17BII 18C 19BII 21 25 27S 28S 32E 32S 32SII 33C 33S 34S 35S 38C 39gs 39GII 40gs 41C 41CV 41CX 42S 45 48G+ 48GII 49G 49G+ 50 67 71B 97
03-24-2020, 06:36 PM
Oh... I thought that button was for situations like: x= ±√4 => x=2 x= -2
03-24-2020, 11:22 PM
I suppose the '+/-' key would have been labelled '(-)' if it wasn't for the need to support RPN.
— Ian Abbott
03-25-2020, 02:33 AM
(03-24-2020 11:22 PM)ijabbott Wrote:  I suppose the '+/-' key would have been labelled '(-)' if it wasn't for the need to support RPN.
Yes '(-)' is what most calculator manufacturers currently use for their sign change key.
HP used 'CHS' (Change Sign) for many years. HP changed the key label to '+/-' in 1990 with the introduction of the HP-48SX and appear to have used that symbol on newer models ever since.
TI used '+/-' for this key for many years until around 1990 when they switched to '(-)' with the introduction of the TI-81 graphing calculator and appear to have used that symbol on newer models ever since.
Early Sharp and Casio models used '+/-' for this key until they also switched to '(-)'.
03-25-2020, 10:24 PM
(03-25-2020 02:33 AM)Steve Simpkin Wrote:  HP used 'CHS' (Change Sign) for many years.
On the Friden 132 from the mid 60's, the key was labeled "CHANGE SIGN".
03-25-2020, 10:55 PM
Interesting. On the first (HP9100A) and second (HP9810A) generation HP desktops they labeled it "CHG SIGN".
https://www.hpmuseum.org/9100/9100akm.jpg
https://www.hpmuseum.org/98xx/9810kbds.jpg
On the third generation (HP9815A) HP desktop they changed it to a "+ -" symbol with a pair of curved arrows between them.
https://www.hpmuseum.org/9805_15/9815keyl.jpg
When they came out with the HP-35 hand held, they changed it to "CHS". "CHS" was then used on hand helds and desktop models until the HP-48SX.
