Cut the Cards
07-30-2020, 08:00 PM
Cut the Cards
PPC Journal V5N4 Page 13 poses a question about a deck of cards. Choose a card at random from a deck of 52 and put the card back. What is the average number of choices required to see all 52 cards?
I simulated the experiment in C++ and got the right answer (236) but I can't figure how to do this analytically. Is it possible?
If you simplify the problem down to a deck of 2 cards then it's easier: you choose the first card, and then it's just a matter of the average number of choices to get the second: 1*1/2 + 2*1/4 + 3*1/8 ..., but can that be extended to more cards?
Dave
07-30-2020, 08:58 PM
RE: Cut the Cards
(07-30-2020 08:00 PM)David Hayden Wrote:  Choose a card at random from a deck of 52 and put the card back.
First card picked must never been seen, thus only 1 try needed to get 1st card.
Probability of getting the next "new" card = 51/52, or averaged 52/51 tries to get 2nd card
We can get averaged picks either way:
XCas> sum(1/t, t=1 .. 52) * 52.0                 → 235.978285436
XCas> int((t^52-1)/(t-1), t=0 .. 1) * 52.0    → 235.978285436
→ averaged 236 picks to see all 52 cards
07-30-2020, 09:49 PM
RE: Cut the Cards
So, it approaches x*(ln(x)+0.57721), where the latter constant is the Euler-Mascheroni constant. This isn't as accurate as doing it analytically but is good for fast calculations. For instance, if you picked a random second of a year every second, how many years would it take? About 17.84 total.
So many signals, so little bandwidth!
07-30-2020, 10:21 PM
RE: Cut the Cards
Here is simulations, using Lua
Note: math.random(n) return 1 .. n, each with same probability.
function run(tests,cards)   -- averaged picks
    local n = 0             -- bad tries
    for i=1,tests do
        for t=1,cards do
            while math.random(cards) < t do n=n+1 end
        end
    end
    return n/tests + cards
end
lua> run(1e6, 52)
235.970842
07-31-2020, 12:24 AM (This post was last modified: 07-31-2020 12:51 AM by John Keith.)
RE: Cut the Cards
(07-30-2020 09:49 PM)Jim Horn Wrote:  So, it approaches x*(ln(x)+0.57721), where the latter constant is the Euler-Mascheroni constant.
Or in other words, n*H(n), where H(n) is the nth harmonic number. (Albert's first formula in post #2)
(07-30-2020 09:49 PM)Jim Horn Wrote:  This isn't as accurate as doing it analytically but is good for fast calculations.
Actually it is very accurate as the first image in the Wikipedia link shows: LN(n)+gamma is the asymptotic limit of H(n) as n approaches infinity.
08-21-2020, 11:00 PM
RE: Cut the Cards
(07-30-2020 08:58 PM)Albert Chan Wrote:  First card picked must never been seen, thus only 1 try needed to get 1st card.
I might jumped too quickly to say averaged 1/p tries to get the next card.
Let probability of getting the card = p ; of not getting it = q = 1-p
Expected tries
= p + 2qp + 3q²p + 4q³p + ...
= (1-q) (1 + 2q + 3q² + 4q³ + ...)
= (1 + 2q + 3q² + 4q³ + ...) - (q + 2q² + 3q³ + ...)
= 1 + q + q² + q³ + ...
= 1/(1-q)
= 1/p
For n > 0, we have:     \(\Large {1 \over (1-x)^n}\normalsize = \displaystyle \sum_{k=0}^∞ \binom{-n}{k}(-x)^k = \sum_{k=0}^∞ \binom{k+n-1}{n-1} x^k \)
Examples:
XCas> series(1/(1-x)^2, x, polynom) → 1+2*x + 3*x^2 + 4*x^3 + 5*x^4 + 6*x^5
XCas> series(1/(1-x)^3, x, polynom) → 1+3*x + 6*x^2+10*x^3+15*x^4+21*x^5   // triangular numbers coefficients
XCas> series(1/(1-x)^4, x, polynom) → 1+4*x+10*x^2+20*x^3+35*x^4+56*x^5   // tetrahedral numbers coefficients
08-24-2020, 01:57 PM (This post was last modified: 08-24-2020 02:07 PM by Gerson W. Barbosa.)
RE: Cut the Cards
The H(n) function can be easily defined on the HP 50g:
« 1. + Psi 1. Psi - »
'H' STO
For instance,
52 ENTER ENTER H × 235.978285436
08-24-2020, 09:49 PM
RE: Cut the Cards
Thanks for all those formulas and explanations.
Here is an implementation of the brute force algorithm for the experimental analysis:
// Forward declaration
CRDS(N);
// Main func:
// N is the number of cards
// L is the number of tests
// Returns average number of peeks
EXPORT CARDS(N,L)
BEGIN
 LOCAL I, S := 0;
 FOR I FROM 1 TO L DO
  S := S + CRDS(N);
 END;
 RETURN S/L;
END;
// Peek a card until all cards
//   are peeked at least once
EXPORT CRDS(N)
BEGIN
 LOCAL LL, C := 0;
 LL:=MAKELIST(0,A,1,N);
 WHILE ΠLIST(LL)=0 DO
  LL(RANDINT(1,N)):=1;
  C := C+1;
 END;
 RETURN C;
END;
Usage:
CARDS(number-of-cards, number-of-analysis)
Example:
CARDS(52, 1000)
Returns: 235.951
Thibault - not collector but in love with the few HP models I own - Also musician : http://walruspark.co
08-25-2020, 06:14 PM (This post was last modified: 08-28-2020 01:23 AM by Albert Chan.)
RE: Cut the Cards
Replacing ln(x) by ln(x+0.5) gives much better estimate for ψ(x+1).
ψ(x+1) = slope of ln(gamma(t)) at t = x+1. When x is large:
\(\psi(x+1) ≈ {\ln\Gamma(x+2)\;-\;\ln\Gamma(x)\over 2}=\ln\sqrt{(x+1)(x)} ≈ \ln(x+0.5)\)
>>> x = 52
>>> H = log(x+0.5) + 0.57722
>>> print format(x*H, 'g')
235.978
see https://en.wikipedia.org/wiki/Digamma_fu...roximation
08-25-2020, 11:41 PM (This post was last modified: 08-26-2020 12:00 AM by Gerson W. Barbosa.)
RE: Cut the Cards
FWIW,
« 1. Psi + EXP 6. OVER INV 12. + / + 1. - »
'H­-¹' STO
Example:
1100 H7.58073560027
H­-¹1100
H-­¹ should be accurate to 11 or 12 digits for arguments equal or greater than 7.5
08-26-2020, 03:06 AM (This post was last modified: 09-01-2020 02:22 PM by Albert Chan.)
RE: Cut the Cards
(08-25-2020 11:41 PM)Gerson W. Barbosa Wrote:  FWIW,
'H­-¹' STO
Example:
1100 H7.58073560027
H­-¹1100
Here is another version, using asymptotic estimate: \(\quad\exp(\psi(x+0.5)) ≈ x + \large{1\over24x} \)
Let k = exp(ψ(x+0.5)), n = x - 0.5 → k = exp(H(n) + ψ(1)) ≈ x + 1/(24x)
If x is big, x ≈ k, we have:                 \(n ≈ k - \large{1\over 24k} - {1\over2}\)
HP50g inverse harmonic function:      « 1. Psi + EXP DUP 24. * INV - .5 - »
Both formulas perform well for large H, but this new version is also good for smaller H
>>> from mpmath import exp, euler, harmonic
>>> f1 = lambda k: k + 6/(1/k+12) - 1
>>> f2 = lambda k: k - 1/(24*k) - .5             # new version
>>> for n in range(50,100,10):
...          h = harmonic(n)
...          k = exp(h - euler)
...          e1, e2 = n - f1(k), n - f2(k)              # under-estimated errors
...          print '%d\t%.10f\t%.10f\t%g' % (n, e1, e2, abs(e1/e2))
50       -0.0000013228       0.0000000364       36.3546
60       -0.0000009261       0.0000000212       43.7606
70       -0.0000006844       0.0000000134       51.1669
80       -0.0000005263       0.0000000090       58.5736
90       -0.0000004172       0.0000000063       65.9804
08-26-2020, 08:23 AM
RE: Cut the Cards
(08-26-2020 03:06 AM)Albert Chan 0.247866177136� 54 Wrote:  HP50g inverse harmonic function:      « 1. Psi + EXP DUP 24. * INV - .5 - »
For H less than 2.0701076 the first formula is slightly better:
« DUPDUP H H­¹ - SWAP DUP H H­¹2 - / ABS »
50 → 36.4435261708
10 → 6.75851700917
2.0701076 → 1.
1 → 0.290013346857
0.5131 → 2.30966647121E-5
0.5 → 7.2984301462E-3
0.2 → 0.162258684815
0 → 0.247866177136
08-26-2020, 02:13 PM (This post was last modified: 08-31-2020 08:31 PM by Albert Chan.)
RE: Cut the Cards
I added a tiny correction to compensate errors for smaller H.
HP50g H-1 :       « 1. Psi + EXP DUPDUP SQ 24. * 2.7 + / - .5 - »
from mpmath import exp, euler, harmonic, psi
f3 = lambda k: k - k/(24*k*k+2.7) - .5    # new formula
def test(lst):
    print 'n\t err(f1)\t err(f2)\t err(f3)'
    for n in lst:
        h = harmonic(n)
        k = exp(h - euler)
        print n,'\t% .10f\t% .10f\t% .10f' % (n-f1(k), n-f2(k), n-f3(k))
>>> test(range(10) + range(10,60,10))
n         err(f1)            err(f2)             err(f3)
0         0.0031607566       0.0127518672       -0.0067666262
1        -0.0003177730       0.0010957186       -0.0001620997
2        -0.0002588484       0.0002719596       -0.0000171164
3        -0.0001712995       0.0001037256       -0.0000035307
4        -0.0001178786       0.0000497922       -0.0000010529
5        -0.0000852046       0.0000275594       -0.0000003957
6        -0.0000641850       0.0000167992       -0.0000001742
7        -0.0000499820       0.0000109785       -0.0000000859
8        -0.0000399758       0.0000075616       -0.0000000463
9        -0.0000326776       0.0000054263       -0.0000000266
10       -0.0000271983       0.0000040243       -0.0000000162
20       -0.0000076840       0.0000005432       -0.0000000006
30       -0.0000035570       0.0000001651       -0.0000000001
40       -0.0000020419       0.0000000705       -0.0000000000
50       -0.0000013228       0.0000000364       -0.0000000000
If needed, we could apply Newton's method to get better estimate.
>>> h = harmonic(10)                # h = 2.9289682539682538
>>> x = f3(exp(h-euler))            # x = 10.000000016205583
>>> x - (harmonic(x) - h) / psi(1, x+1)
mpf('10.0')
08-26-2020, 06:13 PM
RE: Cut the Cards
D’oh, my latest improvement ended up being equivalent to your f2 program, same number of bytes as yours (56.5).
That’s an old attempt at exact results, but I wasn’t pleased with it. Perhaps I can make it shorter some day:
https://hpmuseum.org/forum/thread-6157-post-55046.html
08-27-2020, 10:07 PM
RE: Cut the Cards
How about « 1. Psi + EXP DUP 1. + 4. * INV OVER 1. EXP / + INV OVER 24. * + INV - .5 - » ?
Again, best for smaller H. A previous attempt ( « 1. Psi + EXP DUP SQ 24. * 1. EXP + INV NEG 1. + * .5 - » ) gave the same results as yours when I replaced 1 EXP ( e ) with 2.7.
08-28-2020, 09:26 PM (This post was last modified: 08-29-2020 02:51 AM by Albert Chan.)
RE: Cut the Cards
(08-26-2020 02:13 PM)Albert Chan Wrote:  I added a tiny correction to compensate errors for smaller H.
(08-27-2020 10:07 PM)Gerson W. Barbosa Wrote:  How about « 1. Psi + EXP DUP 1. + 4. * INV OVER 1. EXP / + INV OVER 24. * + INV - .5 - » ?
Just to be clear, both corrections are not based on actual continued fraction of e^ψ(x+1/2)
My correction (and probably Gerson's version) are based on curve fitting, for small H.
I picked 2.7 instead of e to get better accuracy at bigger H, it is simply a trade-off.
To build e^ψ(x+1/2) continued fraction with XCas:
XCas> k := exp(Psi(x+0.5))
XCas> limit(k/x, x=inf)        → 1
XCas> limit(1/(k -x)/x, x=inf)        → 24
XCas> limit(1/(1/(k -x) -24x)/x , x=inf)        → 10/37
XCas> limit(1/(1/(1/(k -x) -24x) -10/37*x)/x , x=inf)        → 0 ???
The last one is likely a XCas bug, Mathematica get the coefficient: 689976/74381
\(\qquad\qquad\exp( \psi(x+1/2)) = x
+\frac{1}{24 \cdot x
+\Large\frac{1}{\frac{10}{37} \cdot x
+\frac{1}{\frac{689976}{74381} \cdot x \;
+\; \cdots}}} \)
To confirm, lets try H-1(H(20)):
XCas> f(x) := 1/(24*x + 1/(10/37*x + 1/(689976/74381*x)))
XCas> h := float(harmonic(20))          → 3.59773965714
XCas> k := exp(h - euler_gamma)      → 20.5020317757
XCas> fsolve(x+f(x) = k, x=k) - 0.5    → 20.0
If f(x) is small, x ≈ k. We can also iterate for x, like this:
XCas> x0 := k
XCas> x0 := k - f(x0)      → 20.5000002012
XCas> n := x0 - 0.5        → 20.0
08-28-2020, 11:39 PM
RE: Cut the Cards
For the inverse digamma function I’ve been using a continued fraction with increasing number of terms. I am sure about only the first half of them, though. It’s difficult to be sure about the other half when one is limited to only 12 digits.
\(\rm{e}^{{x}}+\frac{1}{2+\frac{1}{6\rm{e}^{{x}}-\frac{1}{2+\frac{1}{\rm{e}^{{x}-1}-\frac{1}{2+\frac{1}{\rm{e}^{{x}}+\frac{1}{2}}}}}}}\)
08-29-2020, 04:02 PM
RE: Cut the Cards
FYI, above H-1 is equvialent to Ψ-1 (previous post)
Since H(n) = Ψ(n+1) - Ψ(1), we flip the sign of -0.5 to +0.5
XCas> invPsi1(k) := k - 1/(24k + 1/(k/e + 1/(4k+4))) + 1/2
\(k \rightarrow k-\frac{1}{24\cdot k+
\large\frac{1}{\frac{k}{e}+\frac{1}{4\cdot k+4}}}+\frac{1}{2}\)
XCas> invPsi2(k) := k + 1/(2 + 1/(6k - 1/(2 + 1/(k/e - 1/(2 + 1/(k+1/2))))))
\(k \rightarrow k+\frac{1}{2+\frac{1}{6\cdot k-\frac{1}{2+\frac{1}{\frac{k}{e}-\frac{1}{2+\frac{1}{k+\frac{1}{2}}}}}}}\)
XCas> simplify(invPsi1(k) - invPsi2(k))       → 0
Let's try a few x, to see if it round-trip.
XCas> invPsi(x) := invPsi1(exp^float(x))             // Note: k = e^x
XCas> map(range(1,6), x->[x, Psi(invPsi(x))])
\(\qquad\left(\begin{array}{cc}
1 & 0.999999666188 \\
2 & 2.00000000607 \\
3 & 3.00000000018 \\
4 & 4.0 \\
5 & 5.0
\end{array}\right)\)
06-23-2021, 12:08 AM
RE: Cut the Cards
An integral, from a very old (2006) thread: So your HP can INTEGRATE ...
I revived the old thread recently, for an integral that HP71B failed, see HP71B IBOUND fooled
            / Inf
            |     FRAC(x)
     I7 =   |     -------  .dx
            |       x²
           / 1
I put the solution here because integral is closely related to harmonic number
I7 = ∫((x-1)/x^2, x=1..2) + ∫((x-2)/x^2, x=2..3) + ∫((x-3)/x^2, x=3..4) + ...
    = (ln(2) - ln(1) - 1/2)    + (ln(3) - ln(2) - 1/3)   + (ln(4) - ln(3) - 1/4)    + ...
\(I_7 - 1 = \displaystyle \lim_{n \to ∞} (\,\ln(n) - H_n\,) = - \gamma\)
\(I_7 = 1 - \gamma ≈ 0.422784\)
