Control of input parameters in prgms./fns.
12-27-2013, 02:26 AM
Is there any way, inside a program/function in HP Prime, to tell haw many input parameters were passed and modify the prgm./fn. behavior accordingly. As far as I know if you declared 3 parameters and enter while running the prgm./fn. two or one you will get error.
Thanks. |
12-27-2013, 02:31 AM
RE: Control of input parameters in prgms./fns.
No way, there is no http://en.wikipedia.org/wiki/Polymorphis...r_science)
My website: ried.cl |
12-27-2013, 04:34 AM
(12-27-2013 02:26 AM)John P Wrote: Is there any way, inside a program/function in HP Prime, to tell haw many input parameters were passed and modify the prgm./fn. behavior accordingly. As far as I know if you declared 3 parameters and enter while running the prgm./fn. two or one you will get error. One idea would be to pass a single input -- a list. The list itself can contain however many objects (parameters) you want. You just need to add code to parse the list according to your needs. Graph 3D | QPI | SolveSys |
12-27-2013, 05:25 AM
Other option is if TW adds optional parameters
Code: EXPORT Name(required_var, required_var, optional_var=default, optional_var=default) My website: ried.cl |
12-27-2013, 07:52 AM
Thank you all. I was thinking about adding one more real number parameter and the prgm. would check. If it would be for ex. 2 the program would use the two parameters I want and if it would be 1 prgm. would use one parameter etc.
06-05-2014, 06:16 PM
(12-27-2013 04:34 AM)Han Wrote:(12-27-2013 02:26 AM)John P Wrote: Is there any way, inside a program/function in HP Prime, to tell haw many input parameters were passed and modify the prgm./fn. behavior accordingly. As far as I know if you declared 3 parameters and enter while running the prgm./fn. two or one you will get error. I am re-asking the same question for the newest firmware. I dreamed that it changed. Did my dream come true or it is back to the same old reality. Thanks for replays. |
06-06-2014, 08:11 AM
hello,
Nope, sorry, no changes there... using a list is still the only solution. or having multiple functions, with slightly different names and different number of parameters. PPL does not yet implement default parameters, nor var-args, not overloading... Cyrille |
06-06-2014, 01:00 PM
(06-06-2014 08:11 AM)cyrille de brébisson Wrote: hello, Thank you. |
