(42, all flavours) Integer Division - how?
12-14-2020, 05:16 AM
RE: (42, all flavours) Integer Division - how? | |||
12-14-2020, 06:59 AM
(This post was last modified: 12-14-2020 07:59 AM by Werner.)
(corrected)
using floor(q) now, and the 'correct or not' approach: (replace all NOPs with LBL 00 on a real 42S, or the DM42 for the time being) Code: { 45-Byte Prgm } @ X Y Z T Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-14-2020, 07:01 AM
(12-14-2020 05:16 AM)Paul Dale Wrote: An alternative to FMA is an accurate cross product: ab - cd (or equally ab + cd). This can be used for a number of things including FMA. Yes, but an FMA is built into the Intel library, and extended precision is not.. Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-14-2020, 08:04 AM
(This post was last modified: 12-14-2020 08:08 AM by Albert Chan.)
(12-14-2020 06:59 AM)Werner Wrote: using floor(q) now, and the 'correct or not' approach: I started with q = floor(a/b), then correct, but it is not necessary. You can use round(a/b), ceil(a/b), IP(a/b), ... it does not matter. The correction, r is still limited to 0, -1 Example, say we use ceil(a/b) for initial q a/b = 10 - ε → q = 10 → r = -1 a/b = 10 +ε → q = 11 → r = -1 What if a/b = 10 ± ε, because of round-to-nearest, get rounded to exactly 10 ? It is OK. For interger, round/ceil/floor/IP does nothing to it. Since edge case work, so is the rest ... |
12-14-2020, 09:10 AM
That simplifies things:
Code: { 37-Byte Prgm } @ X Y Z T Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-14-2020, 10:10 AM
(12-13-2020 06:41 PM)Albert Chan Wrote: Bonus: it removed the integer arguments requirement. At the risk of being proven wrong again.. as long as b+1 is exact, (and q is not too large), the code for idiv3 works for fractional a and b, too, no? function idiv3(a,b) -- assumed b > 0 local q, c = floor(a/b), b+1 a, b = a%b - a%c, q%c -- a-b = [2-2c, c-2] if a==b or a==b-c then return q end return q-1 end Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-14-2020, 04:12 PM
(12-14-2020 10:10 AM)Werner Wrote: At the risk of being proven wrong again.. Yes, fractions still work! ![]() a = (a//b)*b + (a%b) = q*(c-1) + (a%b) → a%b - a%c - q%c ≡ 0 (mod c) If c=b+1 is exact, and q is correct, above identity holds. And, optimization for (mod c) by 2 comparisons also hold. Checking range of each terms (note, I use opened end intervals here): a1 = (a%b) - (a%c) = [0, c-1) + (-c, 0] = (-c, c-1) b1 = (q%c) = [0, c) a1 - b1 = (-c,c-1) + (-c,0] = (-2c, c-1) a1 - b1 ≡ 0 (mod c) → a1 - b1 = 0, or -c But, a1 - b1 = -c implied we need room, such that c+ulp(c) ≠ c So, we switched it around, and test: (a1==b1) or (a1==b1-c) --- c=b+1 (exactly) is equivalent to test: (b+1-1-b == 0) and (b+1-b-1 == 0) With b>0, ulp(b) = ulp(c) = some multiples of machine epsilon. This is lua 5.4 implmentation for floor-mod, from llimits.h PHP Code: #define luai_nummod(L,a,b,m) \ For our situation, m and b have the same sized ulp. Even if it needed sign correction, (m) += (b), there no no cancellation errors. ULP consideration is needed. Unlike truncated fmod, floor-mod might not be exact. Eli Bendersky's post showed why fmod is exact: Computing Remainders by Doubling We need to watch out for cancellation errors, when floor-mod fix the sign. lua> eps = 1e-10 lua> x, y = eps%1, -eps%1 lua> x, y 1e-10 0.9999999999 lua> x+y, 1-y-x -- x+y rounded to 1, but not exactly equal 1 1 8.274037096265818e-018 |
12-14-2020, 06:01 PM
(12-14-2020 04:12 PM)Albert Chan Wrote: a = (a//b)*b + (a%b) = q*(c-1) + (a%b) I forget to show what happened if q is not correct. In other words, if q is correct, show: a%b - a%c - (q±1)%c ≠ 0 (mod c) Assumed what is to proof is actually true, subtract, we get: ±1 ≠ 0 (mod c) Since b > 0, c = b+1 > 1, this is always true ⇒ assumption is true too. |
12-15-2020, 10:37 AM
(12-14-2020 04:12 PM)Albert Chan Wrote: ULP consideration is needed. Unlike truncated fmod, floor-mod might not be exact. For idiv3(a, b), with tiny negative a, indeed we may hit with cancellation bug. lua> a = -0.09 lua> b = 1.1 - 1 -- so c = b+1 is exact lua> idiv3(a , b) -- should be -1 -2 For negative tiny a = -ε a1 = a%b - a%c = (b-ε) - (c-ε) = -1 + error b1 = q%c = q = 0, or -1 It is this error that make idiv3 failed. If the problem scaled to integers, the problem goes away. lua> A, B = a*0x1p56, b*0x1p56 lua> C = B+1 lua> A%B - A%C -1 lua> idiv3(A,B) -1 |
12-15-2020, 12:43 PM
Yes, but that is only with binary floating point, not with decimal, as in HP calcs ;-)
12-15-2020, 02:51 PM
(This post was last modified: 12-16-2020 08:30 PM by Albert Chan.)
(12-15-2020 12:43 PM)Werner Wrote: Yes, but that is only with binary floating point, not with decimal, as in HP calcs ;-) Not true. When floor-mod "fix" sign, subtraction cancellation may occur, binary or decimal. But, the fix is easy. (your code already fixed this, by using IP) The trick is to start with q = ceil(a/b), or IP(a/b) For a<0, |a|<b: min(a/b) = min(ulp(b)-b)/b) = min(ulp(b)/b) - 1 > -1 Confirm: Free42 Binary: 2 53 X^Y 1 - 1/X 1 - → -9.999999999999999e-1 Free42 Decimal: 1E34 1 - 1/X 1 - → -9.999999999999999999999999999999999e-1 This guaranteed q start with 0, for negative tiny a. (12-15-2020 10:37 AM)Albert Chan Wrote: For negative tiny a = -ε If error = 0, this always work, nothing to fix. If error ≠ 0, and q = 0, we get this: a1 == b1 test : -1 + error == 0 → error == 1 a1==b1-c test: -1 + error == -c → error == -b Since error is tiny, error(b-ε) ≤ ½ulp(b), error(c-ε) ≤ ½ulp(c), both tests failed. This force correction, returning corrected q-1 = -1 This is revised idiv3 should work with non-integer inputs, if c = b+1 is exact. I also added a fast-path, to speed things up. PHP Code: function idiv3c(a,b) -- assumed b > 0 |
12-16-2020, 03:30 PM
(This post was last modified: 12-17-2020 12:35 AM by Albert Chan.)
(12-13-2020 07:43 PM)Thomas Okken Wrote:(12-13-2020 06:41 PM)Albert Chan Wrote: It would be nice if Free42 exposed FMA(a,b,c) to the user ... Free42 FMA already work in progress ! ![]() https://github.com/thomasokken/free42 With FMA, idiv simplified to this. (code optimized for speed, and removed b>0 requirement) PHP Code: function idiv5(a,b) |
12-17-2020, 08:53 AM
(12-15-2020 02:51 PM)Albert Chan Wrote: I also added a fast-path, to speed things up. That fast path wouldn't be useful in my case: I wanted to use integer division to correctly split Cc00 = Qq*Xx + Rr, where each letter is a half-length integer and Cc<Xx For instance, in a 2-digit calculator: 2300 = 57*40 + 20, but 2300/40=58 2700 = 37*72 + 36 What I did up till now is determine Q and q separately with Cc0 = Q*Xx + Aa Aa0 = q*Xx + Rr and each split Yy0=Q*Xx+Rr is carried out as Q := Yy0/Xx; Rr := MOD(Yy0,Xx); if FRC(Q) >0 then Q := INT(Q); else if Rr>0 then Q := ROUND(Q - Rr/Xx,0); end; end; sadly, that still is faster than the integer division - mainly because the rounding part is almost never reached, certainly not in the 34-digit Free42.. Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-17-2020, 10:20 AM
(This post was last modified: 12-17-2020 10:50 AM by Werner.)
the rounding part I do as
if R>X-R then Q:= Q-1; for inputs Cc0 and Xx, and Cc<Xx, if FP(Cc0/Xx)=0, R # X-R (round-to-even does not occur, while in Cc00/Xx it does) Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-17-2020, 12:42 PM
(This post was last modified: 12-17-2020 07:28 PM by Werner.)
Actually that code works for Cc00 = Qq*Xx + Rr, too, save for the round-to-even cases, that are very rare.
So I can do Code: Qq := Cc00/Xx; and the test for Rr>0 is not necessary either Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-17-2020, 06:41 PM
(12-17-2020 12:42 PM)Werner Wrote: Actually that code works for Cc00 = Qq*Xx + Rr, too, save for the round-to-even cases, that are very rare. Your half-way-case had a typo. It should be b := Qq % c If Qq is correct, we have: Cc00 = Qq*Xx + Rr = Qq*c - Qq + Rr Qq = Qq*c + Rr - Cc00 We take (mod c) for both side, b = LHS, a = RHS, and do the test. --- If remainder() is available, we can replace (mod c) test with it. PHP Code: function remainder(x, y) -- assumed x >=0, y > 0 remainder() guaranteed that halfway case have even quotient. For half-way case, Qq must be even (example, 11.5 -> 12, 12.5 -> 12) We can use sign of remainder, for the half-way case correction: → if remaider(Cc00, Xx) < 0 then Qq := Qq - 1; --- If Cc00/Xx fractional part is 0.5, it implied Cc000 / Xx is integer, ends in 5. To "remove" 3 0's, and turn last digit to 5, Xx = 8*k (Cc00 ± 100) / Xx will *not* be half-way case, since 100/8 = 12.5, not an integer. We can use gap test to check for half-way case. This work on a 2-digits calculator: → if (Cc00+100)/Xx - Qq < Qq - (Cc00-100)/Xx then Qq := Qq - 1; Example, if Cc00 = 900, Xx = 40, Qq = round(22.5) = 22 LHS = high gap = 25 - 22 = 3 RHS = low gap = 22 - 20 = 2 This meant Qq were already rounded-down, and no correction needed for it. |
12-17-2020, 07:50 PM
(12-17-2020 06:41 PM)Albert Chan Wrote: Your half-way-case had a typo. It should be b := Qq % c Thanks, I corrected it. Quote:If Cc00/Xx fractional part is 0.5, it implied Cc000 / Xx is integer, ends in 5. No.. each 0 is the length of a half integer, so for a 12 digit machine it is 000000 and for Free42/DM42 it's 17 zeroes ;-) Cc00 = Qq*Xx + Rr is the first part of dividing a multiprecision number stored in sequential registers by a number not exceeding a single register: R1 R2 R3 R4 R5 Aa Bb Cc Dd Ee ... / Xx At each step you have the carry from the previous step, Cc, and so you have to do CcYY = Qq*Xx + Rr with Rr next step's Cc. We can only work with 2 letters at the same time, so first Cc00 = Qq*Xx + Rr (as previously covered) t := Yy-Xx+Rr; (because Yy+Rr may overflow) Cc := MOD(t,Xx); IF t>0 then Qq := Qq + (t-Cc)/Xx + 1; end; Yy := Qq; Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-17-2020, 10:03 PM
(This post was last modified: 12-17-2020 10:29 PM by Albert Chan.)
(12-17-2020 06:41 PM)Albert Chan Wrote: If Cc00/Xx fractional part is 0.5, it implied Cc000 / Xx is integer, ends in 5. (12-17-2020 07:50 PM)Werner Wrote: No.. each 0 is the length of a half integer, so for a 12 digit machine it is 000000 and for Free42/DM42 it's 17 zeroes ;-) I misunderstood. "0" = h zeroes, not 1 zero (*) But, the logic holds. Just replace "hidden" 1 with h \(\large{CcOO \over Xx}\) is half-way cases → \(Xx = 2^{2h+1} \cdot k\) \(\large{CcOO\;±\;IOO \over Xx}\) will *not* be half-way case, since \( \large{10^{2h} \over 2^{2h+1}} = {5^{2h} \over 2}\), not an integer. Gap test work with with "half-integers" too. (*) I had assumed "0" = 1 zero, on a 2-digit calculator, and checked how the code perform. Code: Cases % Types |
12-18-2020, 12:08 AM
(This post was last modified: 12-19-2020 12:56 AM by Albert Chan.)
remainder() based idiv is very elegant.
PHP Code: function idiv6(a, b) -- assumed b > 0 Above is similar to this (6a version possibly faster, only tried to get remainder sign) PHP Code: function idiv6a(a, b) -- assumed b > 0 All the code for mod/half-way test is the last if line. R < h: if residual is less than half of b, q had rounded-down. For floor divide, no need for correction. r == h: if residual is half of b, q (because of round-to-even) is even. But, r also guaranteed even q -> no need for correction. Update: slightly faster version 6b, removed R, and r shifted, with range = [-2h, 2h) PHP Code: function idiv6b(a, b) -- assumed b > 0 |
12-19-2020, 03:14 AM
(This post was last modified: 12-20-2020 11:09 AM by Albert Chan.)
The chance of hitting half-way cases are small.
We can do the remainder check by then. This made the code simpler too. PHP Code: function idiv6c(a, b) -- assumed b > 0 Example, for 2-digit calculator, above/below halfway decides how to correct q a/b = 700/22 = 31.81..., rounded to q = 32 ulp = (a%b)/b = 18/22 ≈ 0.81 ULP, above halfway, return q-1 = 31 a/b = 700/23 = 30.43..., rounded to q = 30 ulp = (a%b)/b = 10/23 ≈ 0.43 ULP, below halfway, return q = 30 --- For halfway case, r is updated, r = a % (b+b) Previously, r = b, this implied updated r = b/2, or 3b/2 To maintain even q, and remainder range of ±b, 3b/2 got shifted down 2b, to -b/2 Only -b/2 remainder require correction: a/b = q - 1/2, rounded-up to q, floor-divide should be q-1 Example, for 2-digit calculator a/b = 460/40 = 11.5, rounded to q = 12 (half-way to even) r = (a%b)*2 = 40 = b --> signal halfway case r = a%(b+b) = 60 --> signal remainder = -20, floor-divide should return q-1 = 11 Reuse the code for non-halfway: return r > b and q-1 or q For above example, r=60, b=40, thus it return q-1 = 11, as expected Update: removed variable h=b/2. This made the code more robust. Previously, we had r = a%b, followed by r = a%(b+b) if halfway. Last line was return r > h and q-1 or q For halfway case, we may hit with *slight* floor-mod rounding. If a is negative, a % (b+b) = (b+b) - |a| % (b+b) = 4h - 3h = h But, 3h term might not be exact, thus last h may have *slight* rounding error. Update 2: fix a typo for halfway test, r == 0 should be r == b |
