Improper integral
06-11-2014, 06:01 PM
Improper integral
Just got an odd result for the improper integral evaluated from 0 to 33 of 1/(5th root of x-1). It should evaluate to 75/4 or 18.75. In home, I get 18.7479519638 after a busy spell hourglass. In CAS, I get a choice of 155/4 (way off!) or 18.750007847.
The HP 39gii after awhile has ER: Invalid Input.
The TI NSpire immediately produces 75/4.
06-11-2014, 06:11 PM
RE: Improper integral
...and when I enter it in as the addition of 2 integrals, one from 0 to 1, the other from 1 to 33, I get a better result in home, 18.7499999293, but still a rather odd result in CAS of a choice of 40 or 18.7499843203.
06-11-2014, 06:20 PM (This post was last modified: 06-11-2014 07:03 PM by Onkel Otto.)
Hmmm, using (x-1)^(-1/5) works fine in Home as well in CAS.
Buggy n-th root function ?
06-11-2014, 06:42 PM
I think it's freaking out because for the region between 0 and 1 the radical is imaginary.
06-11-2014, 06:50 PM
Thinking this is the actual problem... Am I right?
$$\Large\int_{0}^{33} \frac{1}{\sqrt[5]{x-1}} dx$$
06-11-2014, 06:50 PM (This post was last modified: 06-11-2014 07:02 PM by Onkel Otto.)
Even integrating from 2 to 33 shows the same error.
06-11-2014, 06:56 PM
Wolfram Alpha has...
06-11-2014, 07:01 PM (This post was last modified: 06-11-2014 07:03 PM by HP67.)
The 50g says (21.01127123, -.734731565365) if my understanding matches ndzied1's. Which looks pretty close to Wolfram.
Why does the op say it should be 75/4?
It ain't OVER 'till it's 2 PICK
06-11-2014, 07:15 PM
(06-11-2014 06:20 PM)Onkel Otto Wrote:  Hmmm, using (x-1)^(-1/5) works fine in Home as well in CAS.
You may be right...
06-11-2014, 07:16 PM
But not as buggy as the TI N-Spire? Wink
06-11-2014, 07:22 PM (This post was last modified: 06-11-2014 07:28 PM by Mark Hardman.)
(06-11-2014 07:01 PM)HP67 Wrote:  The 50g says (21.01127123, -.734731565365) if my understanding matches ndzied1's. Which looks pretty close to Wolfram.
The asymptote is at x=1, I'm not sure why the OP thinks there would be a real solution in the interval 0..1.
For a reasonable endpoint, the improper integral (1..33) we get a solution of exactly 20.
This requires we use fractional powers in CAS rather than nthroot. I thought those issues had been resolved in the latest release. I guess not.
Ceci n'est pas une signature.
06-11-2014, 08:21 PM
(06-11-2014 07:16 PM)HP67 Wrote:  But not as buggy as the TI N-Spire? Wink
No problems with Ti Nspire in this case :-)
06-11-2014, 09:13 PM
(06-11-2014 06:01 PM)lrdheat Wrote:  The TI NSpire immediately produces 75/4.
Except that the result should be 21.0113 - 0.734732i.
06-11-2014, 09:55 PM
I only get the correct, complex result if , in CAS, I integrate separately from 0. to 1. and then from 1. to 33. (note the real upper and lower limits; the integer limits 0 and 33 return 75/4).
06-11-2014, 09:58 PM (This post was last modified: 06-11-2014 10:23 PM by Onkel Otto.)
(06-11-2014 08:21 PM)Onkel Otto Wrote:  No problems with Ti Nspire in this case :-)
That is what you get using the Nspire - even in exact notation !
06-11-2014, 10:26 PM
(06-11-2014 09:58 PM)Onkel Otto Wrote:  That is exactly what you get using the Nspire !
Lacking a TI NSpire, I have to trust the OP's claim the it gives a result of 75/4. I'm curious why his result is different from yours. Some CAS setting that he or she missed?
Damn, I just gave myself justification for buying one and have already started an eBay search.
I need professional help.
06-11-2014, 10:46 PM (This post was last modified: 06-11-2014 10:55 PM by Onkel Otto.)
It simply depends on your Real/Complex setting :
Like using the Prime with (x-1)^(-1/5) you will receive in Real-Mode :
That's GAS (Gear Acquisition Syndrome) ! ... I do know, what I'm talking about :-).
06-11-2014, 11:09 PM
You can ask for almost ANY kind of help here. Except that kind. No one here is able to grasp the real problem, hence solutions evade us...
06-12-2014, 01:45 AM (This post was last modified: 06-12-2014 01:46 AM by Mark Hardman.)
(06-11-2014 10:46 PM)Onkel Otto Wrote:  It simply depends on your Real/Complex setting :
I'm still trying to wrap my mind around how we arrive at 75/4 for the "real" result.
Graphing the real and imaginary portions of the function reinforces the need to integrate over two intervals: 0..1 and 1..33.
As posted above, the interval between 1 and 33 gives us an exact real answer of 20. The interval between 0 and 1 gives us an approximate imaginary answer of 1.01127 - 0.734732i. The magnitude of this imaginary number is exactly 5/4.
The question remaining in my mind is: Why is the magnitude of the integration between 0 and 1 treated as a negative value? -(5/4)+20=75/4.
(06-11-2014 10:46 PM)Onkel Otto Wrote:  > I need professional help.
If I tell my wife that I've got GAS, she's going to reply, "So, what else is new?"
Maybe I have CAS (CAS Calculator Acquisition Syndrome).
06-12-2014, 06:47 AM
(06-12-2014 01:45 AM)Mark Hardman Wrote:  I'm still trying to wrap my mind around how we arrive at 75/4 for the "real" result.
Perhaps the real arithmetic nth root function is being used.
