Replace 9114 FDD with Floppy USB Emulator?
04-25-2021, 06:36 AM
(This post was last modified: 04-25-2021 06:42 AM by Mark Power.)
Has anyone tried replacing the Sony floppy disk drive in a 9114 with a floppy emulator that allows you to plug in USB memory sticks?
The Gotek SFRM72-U100 floppy emulator allows 1000 partitions of 720K on a single USB stick, selectable by push button. See this advert on eBay. FlashFloppy with the Gotek drive already supports many unique retro drives. |
04-25-2021, 07:41 AM
(This post was last modified: 09-21-2021 02:53 AM by Garth Wilson.)
RE: Replace 9114 FDD with Floppy USB Emulator?
Or how 'bout SD card? (SD card is much, much simpler than USB, particularly in SPI mode.) (Edited for typo.)
http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, at http://wilsonminesco.com/links.html#hp41 ) |
04-25-2021, 10:15 AM
(This post was last modified: 04-25-2021 10:17 AM by Martin Hepperle.)
Mark,
I have replaced the infamous early SONY drives with a HxC (slim) emulator. At the time, no alternative firmware for the Gotek drives was available. Such a replacement should also be possible for the later models in the 9114, but so far I have had no reason to do this (fingers crossed). You can find some notes in PDF format on my web site https://www.mh-aerotools.de/hp/. Martin |
09-20-2021, 11:15 PM
(04-25-2021 06:36 AM)Mark Power Wrote: Has anyone tried replacing the Sony floppy disk drive in a 9114 with a floppy emulator that allows you to plug in USB memory sticks? Mark, did you try this with a Gotek floppy emulator? I'm also interested in doing this on my 9114b. Try CC41! |
05-01-2024, 09:59 PM
Hi Craig, I haven’t tried doing this as both my 9114s are working correctly after a bit of TLC.
