Emu48 Binary to ASCII
05-16-2021, 01:22 AM
I'm having difficulties converting a binary file to an ASCII format for the purpose of documenting the program. I'm using ASCII to Binary Converter 2.0 by Eric Rechlin, John H Meyers, and Christoph Gießelink.
My steps are as follows: (1) Create a program \<< 10 * \>>; store it in variable 'X10.' (2) Load ASCIIBIN.48; store it in variable 'ASCIIBIN.' (3) Put 'X10' on the stack and execute 'ASCIIBIN.' I get "%%HP: T(1)A(D)F(.);■'X10'" on the stack. Where is \<< 10 * \>>? Why is there a line feed character in the resulting string? |
05-16-2021, 06:35 AM
RE: Emu48 Binary to ASCII
It looks like it's encoding the name object 'X10' instead of its contents. What happens if you run ASCIIBIN on X10's contents instead of on 'X10'?
<0|ɸ|0> -Joe- |
05-16-2021, 06:57 AM
The linefeed is the final character of the header, which otherwise contains the "magic value" %%HP at the start, as well as three settings that affect parsing (trigraph translation, angle mode, fraction mark; the characters in parentheses encode the setting values).
The part after the linefeed is the actual object, in this case: 'X10', since you requested that variable name to be converted. There is no \<< 10 * \>> because that's not part of the variable name, and you didn't do a RCL on that before converting. |
05-16-2021, 09:38 AM
RE: Emu48 Binary to ASCII | |||
05-16-2021, 09:46 AM
05-16-2021, 10:37 AM
If I want to clean up
"%%HP: T(1)A(D)F(.);■ \<< 10 *■ \>>" so it can be posted on a forum, or saved as a text file, I have to remove the quotation marks and the line feed characters. Also, replace << with \<< and >> with \>>. I thought I saw some code to do that on comp.sys.hp48. |
05-16-2021, 02:04 PM
The tool uses the current ASCII translation mode, so you'll want to change that from 1 to 3 (in right-shift-1 [I/O], Transfer, Xlat) to handle the << and >> characters.
05-16-2021, 03:31 PM
(This post was last modified: 05-16-2021 03:34 PM by MNH.)
(05-16-2021 02:04 PM)Eric Rechlin Wrote: The tool uses the current ASCII translation mode, so you'll want to change that from 1 to 3 (in right-shift-1 [I/O], Transfer, Xlat) to handle the << and >> characters. Please see the attached image of what I currently have set. I don't understand how to set XLAT to 3; it isn't one of the choices on the XLAT drop-down list. |
05-16-2021, 11:41 PM
(05-16-2021 03:31 PM)MNH Wrote:(05-16-2021 02:04 PM)Eric Rechlin Wrote: The tool uses the current ASCII translation mode, so you'll want to change that from 1 to 3 (in right-shift-1 [I/O], Transfer, Xlat) to handle the << and >> characters. Set the XLAT option to ->255. Alternative method: Executing 3 TRANSIO will do it (benefit: it's programmable). Keyboard access on the 48G/GX: Left-shift 1 (I/O), IOPAR, 3, TRAN (the last soft menu key). <0|ɸ|0> -Joe- |
05-16-2021, 11:51 PM
If all you want is to do is translate an RPL program into postable text, these tiny programs will do it:
HP 48 (S or G series): \<< \->STR 3. TRANSIO #2FEDDh SYSEVAL \>> HP 50g: \<< \->STR 3. TRANSIO #2F34Eh SYSEVAL \>> <0|ɸ|0> -Joe- |
05-17-2021, 12:09 AM
05-17-2021, 12:22 AM
