Perimeter of the Ellipse (HP-15C)
05-25-2021, 10:05 PM
(This post was last modified: 05-26-2021 12:19 AM by Gerson W. Barbosa.)
+-----+-----+-------+-------------+-------------+ | a | b | h | result | exact | +-----+-----+-------+-------------+-------------+ | 20 | 20 | 0.000 | 125.6637062 | 125.6637061 | | 20 | 19 | 0.026 | 122.5422527 | 122.5422527 | | 20 | 18 | 0.053 | 119.4632087 | 119.4632087 | | 20 | 17 | 0.081 | 116.4300496 | 116.4300496 | | 20 | 16 | 0.111 | 113.4466716 | 113.4466716 | | 20 | 15 | 0.143 | 110.5174609 | 110.5174608 | | 20 | 14 | 0.176 | 107.6473797 | 107.6473796 | | 20 | 13 | 0.212 | 104.8420720 | 104.8420720 | | 20 | 12 | 0.250 | 102.1079954 | 102.1079955 | | 20 | 11 | 0.290 | 99.45258805 | 99.45258801 | | 20 | 10 | 0.333 | 96.88448221 | 96.88448221 | | 20 | 9 | 0.379 | 94.41378489 | 94.41378488 | | 20 | 8 | 0.429 | 92.05245051 | 92.05245038 | | 20 | 7 | 0.481 | 89.81479201 | 89.81479146 | | 20 | 6 | 0.538 | 87.71820372 | 87.71820139 | | 20 | 5 | 0.600 | 85.78422747 | 85.78421775 | | 20 | 4 | 0.667 | 84.04021830 | 84.04017816 | | 20 | 3 | 0.739 | 82.52217428 | 82.52200588 | | 20 | 2 | 0.818 | 81.28023133 | 81.27948360 | | 20 | 1 | 0.905 | 80.39234813 | 80.38851238 | | 20 | 0 | 1.000 | 80.03695848 | 80.00000000 | +-----+-----+-------|-------------+-------------+ Edited to fix a silly mistake in usage. |
05-26-2021, 07:08 AM
RE: Perimeter of the Ellipse (HP-15C)
Interesting subject , thanks for the post.
How did you get the exact value ? A computed integral (on your 15C off course) ? --- HP 48GX, Prime G2, 50G, 28S, 15c CE. SwissMicros DM42, DM15L A long time ago : 11C, 15C, 28C. |
05-26-2021, 09:29 AM
I checked the results against WolframAlpha as I did eight years ago:
https://www.hpmuseum.org/cgi-sys/cgiwrap...ead=244138 Considering the integral evaluations took about 45 seconds on the significantly faster 42S, I won’t even try it on my old 15C (perhaps I’ll try it on the 15C LE later). The approximation program takes almost seven seconds on my old15C. Regards, Gerson. |
05-26-2021, 11:49 AM
Some background on the approximations for the perimeter of an ellipse, amazing video to watch (like most of this series)
Regards, Meindert |
05-26-2021, 08:56 PM
(This post was last modified: 05-27-2021 11:28 AM by Albert Chan.)
(01-19-2020 11:00 PM)Albert Chan Wrote: \(\large p(a,b) = 2× \left( p({a+b \over 2}, \sqrt{ab}) - {\pi a b \over AGM(a,b)}\right)\) Code: from math import sqrt, pi >>> p(20,10) (96.884482205476857, 0.43130312949992861) With AGM, convergence is quadratic: p(20, 10) → p(15.0, 14.142135623730951) → p(14.571067811865476, 14.564753151219703) → p(14.56791048154259, 14.567910139395549) → p(14.56791031046907, 14.567910310469069) Last ellipse is practically a circle, thus return 2πr ≈ 91.532880019049259 Code then unwind back to the top, for p(20, 10) ≈ 96.884482205476857 Edit: code return (perimeter, 2*pi/agm(a,b)) >>> m = 0.5 # elliptic parameter m, 0 < m < 1 >>> [x/4 for x in p(1, sqrt(1-m))] # E(m), K(m) [1.3506438810476749, 1.8540746773013719] This may be why Matlab have ellipke that return both kinds of elliptic integrals. |
05-27-2021, 03:16 AM
The AGM is nice. Elliptic integrals (and their relatives) are a bit complicated.
05-27-2021, 02:47 PM
(05-25-2021 10:05 PM)Gerson W. Barbosa Wrote: Please replace steps 3 through 15 with these: Code:
Now 0 ENTER 0 f E will return “Error 0” (no problem, we all know the result is 0). On the other hand 0.5 ENTER 0.5 f E will return 3.141592654 comme il faut, instead of a division by zero error. |
05-27-2021, 06:02 PM
I have develop a program for HP67 to calculate perimeter, surface and volume of an ellipse. The inputs are diameters, but for calculation uses radius. When the 3 diameters are the same figure the body transforms into an sphere. The input and outputs can be printed or screen flashes (HP97/67), but also the results remains in the stack
In the attach PDF (3 pages A4) includes: a) program listing, b) formulas, c) Instructions, d) PGRM Crd diagram, e) example and calculation comparison for sphere using ellipse program (differences in the 8th. decimal only, dif.=+-1) |
05-27-2021, 09:59 PM
(05-27-2021 06:02 PM)PedroLeiva Wrote: (differences in the 8th. decimal only, dif.=+-1) Have you tested it for ellipses with h greater than 0.6? Although that statement should be valid for the extreme case in my examples (a = 20 and b = 0), the errors would show up starting from the fifth and sixth decimals (a =20; b = 19 and b = 18, respectively - anyway, that’s one more exact digit when compared to the approximation I have used, for these two examples). You are using Cantrell-Ramanujan approximation, described at the end of this article. Regards, Gerson. |
05-27-2021, 11:28 PM
(05-27-2021 09:59 PM)Gerson W. Barbosa Wrote:I am using Ramanujan II-Cantrell: here a & b are radius (in my PDF the input is diameter)(05-27-2021 06:02 PM)PedroLeiva Wrote: (differences in the 8th. decimal only, dif.=+-1) H= [(a- b) / (a + b)]^2 P= π * (a+b) * [ 1 + 3H / (10+ SQRT(4-3H)) + (4/π - 14/11) * H^12] For ellipses with H>0.6, here the examples: a= 20 ----H= 0.546313800 b= 3 ----P= 82.52178335 a= 20 ---H= 0.669421488 b= 2 ---P= 81.27883093 a= 20 ---H= 0.904818560 b= 0.5 ---P= 80.11412754 For the other combinations of the radius, the results are: a= 20 ---H= 1 b= 0 ---P= 80 a= 20 ---H= 0.0006557462 b= 19 ---P= 122.5422527 a= 20 ---H= 0.00277083 b= 18 ---P= 119.4632087 Please let me know your conclusions, Pedro |
05-28-2021, 03:31 AM
(This post was last modified: 05-28-2021 04:08 AM by Gerson W. Barbosa.)
(05-27-2021 11:28 PM)PedroLeiva Wrote: I am using Ramanujan II-Cantrell: here a & b are radius (in my PDF the input is diameter) I was thinking of h = [(a - b) / (a + b)], not h = [(a - b) / (a + b)]^2. That is, I was actually interested in ellipses with h greater than 0.36, not 0.6. Ramanujan-Cantrell is more accurate than Ramanujan-II, but only for very eccentric ellipsis (h close to 1). I should have included a direct comparison between Ramanujan-Cantrell and Modified Muir approximations, but the spreadsheets below might give an idea on how these three approximations perform when compared to the exact results. |
05-30-2021, 01:36 AM
In my last reply something was not completely correct. Willy Kunz let me know that there was a mix of Ellipse and Ellipsoid concepts in calculation. For example, Perimeter and Area belongs to Ellipse; surface (not calculated before) and volume to Ellipsoid. So this new version of the program considers both: a) bottom row Crd for data and ellipse calculations, b) upper row Crd for ellipsoid calculations.
Pedro |
06-02-2021, 10:19 PM
Another method (under test)
p ~ π(a - b)(y + 1/(4y - 1/(4y - 3/(4y - 3/(4y - 4/(4y)))))) where y = (a + b)/(a - b) HP-75C, HP-71B program: Code:
An HP-15C version could be slightly more accurate and perhaps faster than my first program. |
06-03-2021, 09:43 AM
(This post was last modified: 06-03-2021 02:52 PM by C.Ret.)
Great idea, but I am a bit lazy this morning to type so many lines of program on my quite full of stuff HP-71B. \( P(a,b)=\pi(a-b)(y+\frac{1}{4y-\frac{1}{4y-\frac{3}{4y-\frac{3}{4y-\frac{4}{4y-\frac{3}{4y-\frac{2}{4y-\frac{2}{4y-\frac{5}{4y-0}}}}}}}}}) \) with \( y=\frac{a+b}{a-b} \) Here is a version where coefficients don't have to be copied in an array; existing in program as DATA at once is enough and spare memory : HP-71B version: 9 DATA 5,2,2,3,4,3,3,1,1 10 INPUT "ELIPSE RADII a,b ";A,B @ IF A<>B THEN Y=(A+B)/(A-B) ELSE P=2*PI*A @ GOTO 30 20 C=0 @ FOR I=1 TO 9 @ READ N @ C=N/(4*Y-C) @ NEXT I @ P=PI*(A-B)*(Y+C) 30 DISP USING 40;A,B,P 40 IMAGE "P("K",",K")=",4D.6D Typical sample value: P(20,20)= 125.663706 P(20,19)= 122.542253 P(19,20)= 122.542253 P(20,10)= 96.884482 P(20,1)= 80.388512 P(20,.2)= 80.016633 P(20,.1)= 79.998004 P(20,0)= 79.986832 HP-15C / HP-11C version: Code: 001- ►LBL E Usage : a [ENTER^] b [ f ][ E ] returns ellipse perimeter P. Registers: R0: \( -y=\frac{a+b}{b-a} \) R1: \( (b-a) \) Edited several times to correct english, missing sentences and code typos. |
06-03-2021, 04:25 PM
(This post was last modified: 06-04-2021 05:17 AM by Gerson W. Barbosa.)
Thank you, C.Ret, for the optimization.
It appears the actual approximation should be π(a - b)(y + 1/(4y - 1/(4y - 3/(4y - 3/(4y - 11/(12y - 149/(57y))))))) where y = (a + b)/(a - b) Code:
P(20, 0) = 79.9786371734 More terms would help or perhaps an optimization of the numerators so that the lower half of the table becomes more accurate. P. S.: The error in the length of the orbit of Halley’s Comet is about only 117 km. P(2667950000, 678281900) = 11 464 318 867.1 km ( actual result with these data: 11 464 318 984.1 km ) P. P. S.: Unlike the previous program, the following will work also on the HP-75C. Code:
06-03-2021, 05:58 PM
(This post was last modified: 06-03-2021 06:02 PM by Albert Chan.)
A simple formula that gives perimeter of ellipse with max rel error of 7ppm
h = ((a-b)/(a+b))^2 \(\displaystyle P(a,b) ≈ \pi (a+b) \left( \frac{.001312}{1.2534-h} + \frac{.85111}{3.8631-h} + .192145\,h + .77864 \right) \) |
06-04-2021, 07:00 AM
(06-03-2021 09:43 AM)C.Ret Wrote: HP-15C / HP-11C version:Encore une solution élégante de C.Ret You play with LBL 1 through LBL 2 without RTN, subtle. Tested on DM42. I forgot that there was a R^ on 15C. --- HP 48GX, Prime G2, 50G, 28S, 15c CE. SwissMicros DM42, DM15L A long time ago : 11C, 15C, 28C. |
06-04-2021, 06:12 PM
(This post was last modified: 06-04-2021 08:23 PM by Gerson W. Barbosa.)
HP-71B, HP-75B:
p(a, b) ~ π(a - b)(y + 1/(4y - 1/(4y - 3/(4y - 3/(4y - 11/(12y - (4/(2y - 1) + 1/3))))))) where y = (a + b)/(a - b) This approximation could be set up to return exact results for y = 1, but it would be needlessly longer. I have yet to see how this approximation compares to Albert Chan's formula above. If I am not mistaken P(20, 1) and P(20, 0) in this approximation are better, but only very slightly. Also, every digit in his formula takes one step on the HP-15C, but it is probable that an HP-15C version of this program takes up even more. The results on the HP-71B have been rounded to 10 figures in the table. An HP-15C version might return occasional differences in the last significant digit. +-----+-----+-------+-------------+-------------+ | a | b | h | result | exact | +-----+-----+-------+-------------+-------------+ | 20 | 20 | 0.000 | 125.6637061 | 125.6637061 | | 20 | 19 | 0.026 | 122.5422527 | 122.5422527 | | 20 | 18 | 0.053 | 119.4632087 | 119.4632087 | | 20 | 17 | 0.081 | 116.4300496 | 116.4300496 | | 20 | 16 | 0.111 | 113.4466716 | 113.4466716 | | 20 | 15 | 0.143 | 110.5174608 | 110.5174608 | | 20 | 14 | 0.176 | 107.6473797 | 107.6473796 | | 20 | 13 | 0.212 | 104.8420720 | 104.8420720 | | 20 | 12 | 0.250 | 102.1079955 | 102.1079955 | | 20 | 11 | 0.290 | 99.45258801 | 99.45258801 | | 20 | 10 | 0.333 | 96.88448221 | 96.88448221 | | 20 | 9 | 0.379 | 94.41378489 | 94.41378488 | | 20 | 8 | 0.429 | 92.05245041 | 92.05245038 | | 20 | 7 | 0.481 | 89.81479158 | 89.81479146 | | 20 | 6 | 0.538 | 87.71820187 | 87.71820139 | | 20 | 5 | 0.600 | 85.78421973 | 85.78421775 | | 20 | 4 | 0.667 | 84.04018649 | 84.04017816 | | 20 | 3 | 0.739 | 82.52204269 | 82.52200588 | | 20 | 2 | 0.818 | 81.27965719 | 81.27948360 | | 20 | 1 | 0.905 | 80.38937724 | 80.38851238 | | 20 | 0 | 1.000 | 80.03695848 | 79.99959924 | +-----+-----+-------|-------------+-------------+ ——————— This will return exact results when y = 1: p(a, b) ~ π(a - b)(y + 1/(4y - 1/(4y - 3/(4y - 3/(4y - 11/(12y - (4/(2y - 1) + (2592-825π)/(588-187π)))))))) Code:
06-04-2021, 07:14 PM
(This post was last modified: 06-04-2021 08:38 PM by Albert Chan.)
Here is Ellipse perimeter, AGM based version, without recursion.
10 DEF FNP(A,B) @ S=A*A+B*B @ T=1 20 REPEAT @ G=B @ K=(A-B)/2 @ B=SQRT(A*B) @ A=A-K @ T=T+T @ S=S-T*K*K @ UNTIL G=B 30 FNP = S/B*PI @ END DEF > FNP(20,1) 80.3885123826 Comment: we can test convergence of S instead. This may reduce loop count by 1. 20 REPEAT @ K=(A-B)/2 @ B=SQRT(A*B) @ A=A-K @ T=T+T @ K=T*K*K @ S=S-K @ UNTIL S=S+K |
06-04-2021, 09:28 PM
(This post was last modified: 06-04-2021 09:36 PM by C.Ret.)
Code: 001- ►LBL E Code: 029- ►LBL.2 12 GTO 0 ; ── ─── ─── d=12 ─┐ Code: 047- ►LBL 8 2 * ; Compute P(a,a)=2πa |
