new way to make quadratic equations easy
07-30-2021, 01:44 AM
Thought this might be of interest here..
https://getpocket.com/explore/item/mathe...-equations
https://www.technologyreview.com/2019/12...ions-easy/
https://www.poshenloh.com/quadratic/
07-30-2021, 11:42 AM
RE: new way to make quadratic equations easy
Simpler? I watched the video. I am not convinced. And what if the coefficients are not integers?
Max
07-30-2021, 01:46 PM
(07-30-2021 11:42 AM)Maximilian Hohmann Wrote:  Hello!
Max
If they are not integers,
I give up!
(I was/am not good at quadratics, it is sort of the reason I hang around this forum like a rock star groupie, I am so awed by people able to find i or some other negative number as the root!)
10B, 10BII, 10C, 11C, 12C, 14B, 15C, 16C, 17B, 18C, 19BII, 20b, 22, 25, 29C, 32SII, 35, 38G, 39G, 39gs, 41CV, 48G, 97
07-31-2021, 04:22 AM (This post was last modified: 07-31-2021 04:22 AM by Namir.)
Seems to work with non-integers. I wrote an HP-41CX program that takes the roots, forms the coefficients B and C of the quadratic equation, and then solves it. Input and output values match!
07-31-2021, 07:03 AM
Here is an HP41/42 Implementation using only the stack. The stack starts with C in register Y and B in register X: The two roots will be in registers X and Y.
LBL A
STO Z
2
X^2
CHS
SQRT
STO Z
X<>Y
2
CHS
STO T
X<>Y
X<>Y
RCL T
RTN
07-31-2021, 10:19 AM (This post was last modified: 07-31-2021 10:47 AM by C.Ret.)
(07-31-2021 04:22 AM)Namir Wrote:  Seems to work with non-integers.
It also works for complex roots or complex coefficients, here is an illustration for a complex capable HP-15C:
IN :   Y:  c     X:  b       from reduced quadratic equation x²+b.x+c = 0  (EQ.1)
001-       2     2                                           009-43,30, 2   g x<0 ?    (Test 2)
002-      16     CHS                                         010-43, 4, 8   g SF 8     Automaticaly set complex mode in case of complex root(s)
003-      10     ÷        Compute m = (z1+z2)/2 = -b/2       011-      11     √x       Compute u=±√(m² - z1.z2) =±√(b²/4 - c)
004-      36     ENTER                                       012-      30     -        Compute z2=m-u
005-      36     ENTER                                       013-  43  33   g R↑
006-  43  11   g x²                                          014-  43  36   g LSTx
007-  43  33   g R↑                                          015-      40     +        Compute z1=m+u
008-      30     -
                                                             OUT :   y: z2=m-u   X: z1=m+u  both solutions of (EQ.1)
Usage : Enter real or complex reduced coefficients c and b in stack at respectively level Y: and X: and run the code.
HP-15C 's complex mode automatically engage at complex value entries or when any of the two roots is complex.
This code, despite using a different method is really close to the one I post yesterday using old-school method.
Usage Example : \( (3-i).z^2+(-49+33i).z+120-90i = 0 \)
Enter c coefficient : [ 1 ][ 2 ][ 0 ][ENTER] [ 9 ][ 0 ][CHS] f[ I ] (note that the 'c' annunciators lit on)
Reduce c by a : [ 3 ][ENTER] [ 1 ][CHS] f[ I ] [ ÷ ] display reduced c : " 45.00000 c " Press f[(i)] to see imaginary part "-15.00000 c"
Enter b: [ 4 ][ 9 ][CHS][ENTER] [ 3 ][ 3 ] f[ I ]
Reduce b by a : g[LSTx] [ [ ÷ ] display reduced b : "-18.00000 c " Press f[(i)] to see imaginary part " 5.0000"
The reduced quadratic equation is now : \( z^2+(-18+5i).z+(45-15i)=0 \)
Press [R/S] to run code.
Real part of first root is " 15.00000 "
Press and hold f[(i)] key to see imaginary part of first root: "-5.00000 "
Press [X↔Y] to display the second root real part : " 3.00000 "
Press and hold f[(i)] to display the second root’s imaginary part: " 0.00000 "
The quadratic equation \( (3-i).z^2+(-49+33i).z+120-90i = 0 \) have one complex root \(z_1=15-5i\) and one real root \(x_2=3 \)
08-01-2021, 07:56 AM
Updated version (using stack only) to handle real and complex solutions for real values of B and C.
LBL A
CF 00
STO Z
2
X^2
CHS
X<0?
GTO 00
SQRT
STO Z
X<>Y
2
CHS
STO T
X<>Y
X<>Y
RCL T
RTN
LBL 00
CHS
SQRT
X<>Y
-2
SF 00
RTN
If flag 00 remains clear at the end of the calculations you have two real roots in the X and Y registers. If flag 00 is set at the end of the calculations thenn you have the solutions:
x1 = regX + i regY
x2 = regX - i regY
Namir
08-01-2021, 03:08 PM (This post was last modified: 08-01-2021 07:55 PM by Albert Chan.)
(07-31-2021 10:19 AM)C.Ret Wrote:  ... The reduced quadratic equation is now : \( z^2+(-18+5i).z+(45-15i)=0 \)
We can also solve quadratics with half-angle formula, see (HP-67) Barkers's Equation
Let c = cot(θ/2)       → cot(θ) = (c²-1) / (2c)       → c² - 2*cot(θ)*c - 1 = 0
x² - 2*cot(θ)*x - 1 = (x - c)*(x + 1/c)
Let x = z/n, to scale constant term to -n², instead of -1.
In other words, solve for z² - 2*m*z - n² = 0
XCas> m,n := (-18.+5i)/-2, sqrt(-(45.-15i))
XCas> proot([1, -2m, -n*n])                                    → [3.0, 15.0-5.0*i]
XCas> -n*tan(atan(n/m)/2), n/tan(atan(n/m)/2)       → [3.0, 15.0-5.0*i]
Or, with "built-in" quadratic solver, asinh:
sinh(x) = (e^x - e^-x)/2       → (e^x)² - 2*sinh(x)*e^x - 1 = 0
XCas> -n/exp(asinh(m/n)), n*exp(asinh(m/n))         → [3.0, 15.0-5.0*i]
Since asinh(x) is odd function, z = ±n*exp(asinh(m/±n))
We can also solve for z² - 2*m*z + n² = 0
XCas> m,n := (-18+5i)/-2., sqrt(45.-15i)
XCas> proot([1, -2m, n*n])                                    → [3.0, 15.0-5.0*i]
XCas> n*tan(asin(n/m)/2), n/tan(asin(n/m)/2)        → [3.0, 15.0-5.0*i]
XCas> n/exp(acosh(m/n)), n*exp(acosh(m/n))        → [3.0, 15.0-5.0*i]
Again, combine both roots, z = n*exp(±acosh(m/n))
08-04-2021, 04:57 AM
I was surprised to learn that roots for quadratic equations could be solved using a slide rule, described in the manual for the Post Versalog:
Quote:If any quadratic equation is transformed into the form x^2 + Ax + B = 0, the roots or values of the unknown x may be determined by a simple method, using the slide rule scales. We let the correct roots be -x_1 and -x_2. By factoring, (x + x_1)(x + x_2) = 0. The terms -x_1 and -x_2 will be the correct values of x providing the sum x_1 + x_2 = A and the product of x_1 * x_2 = B. An index of the CI scale may be set opposite the number B on the D scale. With the slide in this position, no matter where the hairline is set, the product of simultaneous CI and D scale readings or of simultaneous CIF and DF scale readings is equal to B. Therefore it is only necessary to move the hairline to a position such that the sum of the simultaneous CI and D scale readings, or the sum of the simultaneous CIF and DF scale readings, is equal to the number A.
As an example, the equation x^2 + 10x + 15 = 0 will be used. We set the left index of CI opposite the number 15 on the D scale. We then move the hairline until the sum of CI and D scale readings, at the hairline, is equal to 10. This occurs when the hairline is set at 1.84 on D, the simultaneous reading on CI being 8.15. The sum x_1 + x_2 = 1.84 + 8.15 = 9.99, sufficiently close to 10 for slide rule accuracy. Roots or values of x are therefore -x_1 = -1.84 and -x_2 = -8.15. Obviously the values of x solving the equation x^2 – 10x + 15 = 0 will be +1.84 and +8.15 since in this case A is negative, equal to -10.
As a second example the equation x^2 – 12.2x - 17.2 = 0 will be used. The left index of CI is set on 17.2 on the D scale. Since this number is actually negative, -17.2, and since it is the product of x_1 and x_2, obviously one root must be positive, the other negative. Also the sum of x_1 and x_2 must equal -12.2. We therefore move the hairline until the sum of simultaneous scale readings is equal to -12.2. This occurs when the hairline is set on 13.5 on the DF scale, the simultaneous reading at the hairline on CIF being 1.275. x_1 is therefore -13.5 and x_2 is 1.275, since x_1 + x_2 = -13.5 +1.275 = -12.225, sufficiently close to -12.2 for slide rule accuracy. The values of x solving the equation are therefore -x_1 = 13.5 and -x_2 = -1.275.
08-06-2021, 12:40 AM (This post was last modified: 08-06-2021 03:36 AM by Namir.)
Interseting article. I do have a "small" collection of slide rules. I used them in high school and during the first part of my engineering education until I got a Sharp scientific calculator and soon after than an HP-55 (in 1975).
My favorite slide rule is a big Aristo (with a two-piece support stand) that my father bought me from Lausanne, Switzerland, in 1971. I only brought it to final exams. I never brought the HP-55 to college.
I think slide rules are amazing in their own right. But, the HP-35 ushered their demise.
Namir
08-06-2021, 02:22 PM
(08-06-2021 12:40 AM)Namir Wrote:  Interseting article. I do have a "small" collection of slide rules. [...]
Namir
I think my "collection" is <30, it includes a concrete calculator given to customers of a Ready-Mix company, and an Addiator, oh, and a paper flight slide rule (Jeppeson?)
I did buy a non-functioning slide rule tie tack on TAS a while back, so I don't think that counts.
08-06-2021, 05:32 PM (This post was last modified: 08-07-2021 09:49 AM by C.Ret.)
(08-04-2021 04:57 AM)Benjer Wrote:  I was surprised to learn that roots for quadratic equations could be solved using a slide rule, described in the manual for the Post Versalog:
I was also really surprise, so I grasp my father's Graphoplex REITZ n°620 and it's very short manual where no mention about how to solve a quadratic equation is present. So I reinserted this manual in the red cardboard box and try the two examples.
Here is a capture for the resolution of the first example : \( x^2+10x+15=0 \) . The trick is to mentally add value form the CI and the D scale. I get a hard time to found at which position I have to start seeking. To help me, I move the hairline (the middle hairline in red) to look for a sum as close as 10 as possible. Finally, the position of the middle hairline indicate the two roots on the CI and D scale respectively.
[attachment=9708]
(Note: the HP-15C armed with quadratic solving code is only showing one root at a time).
For the second example of equation \( x^2–12.2x-17.2=0 \), I check with an HP Prime to have the two roots on the display. I only realize after a few attempts, that since there is no CIF and DF scale on this slide rule I need to use the right index of CI set on 17.2 on the D scale. Then, the procedure is usingthe D and CI scales but the substraction have to match 12.2 as close as possible.
[attachment=9709]
P.S.: Please note that on this slide rule, scale CI and D have respectively black B and red a labels (original Graphoplex: French Règle à Calculs).
EDIT:
Is that a new way to make the quadratic equation solving esay ?
- new ? With a slide rule from 1958 ?
- easy ? scanning for adding or substrating values on D and CI scale ?
