First python project : HP41 emulator + hints of workflow
06-11-2021, 12:28 AM
Post: #41
RE: First python project : HP41 emulator + hints of workflow
(06-11-2021 12:12 AM)Steve Simpkin Wrote: I would recommend the original HP-41C Owner's Handbook and Programming Guide. It assumes you know nothing about HP calculators and is a great example of the friendly, well written calculator manuals that HP used to write. I endorse Steve's recommendation! The later CX manuals cover more of the functions, but the original 41C manual is in many ways the peak of the great old-school HP manuals, even including some of the semi-goofy little cartoons. Starting with the 41CX manual, they took on an ever-increasing tendency towards reference books, simply explaining how the functions work (parameters, stack use, results) but not explaining how to use them. --Bob Prosperi |
06-12-2021, 10:36 PM
Post: #42
New to the hp41c review and the pyhp41e emulator.
I was able to figure out the fast/slow switch, the roll down, xyzt rpn, rpn stack and the trig/log/square/square root functions. ( I used the monkey typing on a keyboard method without using any docs) I also figured out the virtual paper tape printer. Programming it will have to wait for now. The emulator is a great rpn trainer for those who do not have any of the classic hp calculators. Thanks |
06-13-2021, 03:29 AM
(This post was last modified: 06-13-2021 01:22 PM by gfbci.)
Post: #43
First I would like to thank Olivier and this group for their generously shared knowledge.
Py41.e can work on G1 by editing lines 74-75 values of the py41.py file with something like: ... aof=100 if k==-1 else 1 if aof>=500: ... This apparently prevents the simulator from going into sleep mode when a key is released. Don't trust my explanation, but it works! Gianfranco edit: Please disregard the values, what matters is to stop the increment of aof |
06-13-2021, 02:00 PM
Post: #44
(06-13-2021 03:29 AM)gfbci Wrote: First I would like to thank Olivier and this group for their generously shared knowledge. That's not working for me... Can I check exactly what you have: py41.py lines 74-75 And nut.py line 893 (since Olivier advised changing delay here for G1) Thanks |
06-13-2021, 02:51 PM
Post: #45
(06-13-2021 02:00 PM)Stevetuc Wrote:(06-13-2021 03:29 AM)gfbci Wrote: First I would like to thank Olivier and this group for their generously shared knowledge. Forgive me for the confusion, maybe I wasn't clear in editing the first post. No values need to be changed, just edit: (74) aof+=300 if k==-1 else 1 to: (74) aof=300 if k==-1 else 1 The file nut.py has not been touched. Unfortunately I don't have a Windows machine at the moment to download the changed file, I would gladly send it. Gianfranco |
06-13-2021, 02:58 PM
Post: #46
(06-13-2021 02:51 PM)gfbci Wrote:Thanks Gianfranco you were clear, but I wanted to double check as unfortunately I tried this and it doesn't work on my G1.. not sure why(06-13-2021 02:00 PM)Stevetuc Wrote: That's not working for me... |
06-13-2021, 08:41 PM
Post: #47
(06-13-2021 02:58 PM)Stevetuc Wrote:(06-13-2021 02:51 PM)gfbci Wrote: Forgive me for the confusion, maybe I wasn't clear in editing the first post. No values need to be changed, just edit:Thanks Gianfranco you were clear, but I wanted to double check as unfortunately I tried this and it doesn't work on my G1.. not sure why The only action I had to take besides the mentioned change was the removal of all downloaded or copied apps, the reset of the native apps and the calculator itself. This was necessary after the installation of fimware 2021 05 05 to normalize its behavior. Hardware version is "C". I redid all the indicated procedure starting from scratch: it works! I hope it helps. Gianfranco |
06-13-2021, 09:06 PM
Post: #48
(06-13-2021 08:41 PM)gfbci Wrote:(06-13-2021 02:58 PM)Stevetuc Wrote: Thanks Gianfranco you were clear, but I wanted to double check as unfortunately I tried this and it doesn't work on my G1.. not sure why Thanks. It's now working but a slightly different way. I stopped the program using the "On" key and it invited me to edit py41.py I found that even though I thought I had sent the edited file previously, line 74 still contained aof+=300 if ... etc I removed the + and restarted. Now it works! |
06-24-2021, 10:25 PM
Post: #49
Is it possible to switch the py41e simulator into radians mode and back to degrees
mode? And of course how would I do it? Thanks |
08-05-2021, 07:29 PM
(This post was last modified: 08-06-2021 06:13 PM by Guenter Schink.)
Post: #50
Edit:
I did of course forget something IMPORTANT. in py41.py line 24 or so, after "def loop():" and before "k=0"add proper indented a line "global addonState" I've added that to the description below. /EDIT The HP41 emulator certainly is pretty cool. It is however not so easy to remember the assignments of the keys. One solution is to have some notes handy, but that's not really cool. I tinkered around a little bit to have something available right away, by using the unused estate left and right of the printout. The display of this is toggled on/off by <SHIFT><VIEW>. Have a look at the picture. In order to make it work you have to manually do some editing yourself. Please use an editor (e.g. notepad++) that is is suitable to edit text files. 1. Unzip the attached AddOn.zip and add the file AddOn.py to your P41e.hpappdir 2. open nuts.py to edit as text file, goto line 918 "def infos(self,c)" add as next line (proper indented) "return" it should look like PHP Code: def infos(self,c): 4. open Py41.py to edit as text file 5. on top, right after "import hpprime" add a line "import AddOn" 5a.At line 24 or so, after "def loop():" and before "k=0"add proper indented a line "global addonState" 6. at bottom, after "config.init(cpu) add a line "addonState=False" 7. look upwards and find line 68 "elif k==4:" followed by "pass" 6 after that line insert a new line "elif k==9 and display.lE&0x0080:" folowed by "addonState=AddOn.addon(addonState)" followed by "cpu.togshift()" observe the indentation as in the lines already there. That now should look like: PHP Code: ### 8. save Py41e.hpappdir and send it to your real and virtual Prime. I hope I haven't forgotten anything. And remember this help is invoked (toggled) by <SHIFT><VIEW> I must admit that's not as elegant as the fine art of Olivier, but may be of great help using the 41cx emulator on the Prime. Olivier, if you read this perhaps it motivates you to include something like this in your distribution. Günter |
08-06-2021, 12:39 AM
Post: #51
I still need some kind of documentation to use the hp41 emulator.
Does a user really need to do a line by line review of the source code to use the HP41 emulator to its fullest extent? Should this emulator be reguarded as a basic rpn toy? I looked at the key.py file and see a list of binary MOD files with no docs on how to use them. A short internal help file may be of help to a small number of potential users. I would really like to reguard the HP41 emulator as a usefull tool. Thanks. |
08-06-2021, 02:32 AM
Post: #52
(08-06-2021 12:39 AM)Liamtoh Resu Wrote: I looked at the key.py file and see a list of binary MOD files with no docs on The ROM modules for an HP-41 are generally well-known in the community, and manuals for many of the modules HP sold are included in the MoHPC Document set. Other manuals can also be found on the 41-specific site: http://www.ho41.org (substitute a "p" for the "o" - the actual url can't be used here for historical reasons) And still other modern modules, from Angel Martin, Håkan Thörngren, and a few others can be found on the HP-41CL site here: http://www.systemyde.com/hp41/documents.html --Bob Prosperi |
08-06-2021, 09:06 PM
Post: #53
Thanks for your response and information, rprosperi.
I seem to have problems mapping some of the HP41 emulator keys to the real calculator key functions and vice versa. For instance I still can't work with radians on the emulator. If you had an example of accessing one of the modules, I could figure outhow to access the rest. I will check hout the "ho41,org" site. I have looked at the docs at "literature.hpcalc.org" Thanks. |
08-06-2021, 10:35 PM
Post: #54
(08-06-2021 09:06 PM)Liamtoh Resu Wrote: I seem to have problems mapping some of the HP41 emulator keys to the real calculator key functions and vice versa.That's what my extension above is for. Alternatively go back to the download site of P41, at the bottom of that page is a layout that shows the key assignments. Quote:re: radians - as long as you don't familiarize yourself with the HP41 itself the emulator is almost useless " XEQ RAD"Günter |
08-07-2021, 03:10 AM
Post: #55
The closest thing to HP41 calculator is the V41 emulator by Warren Furlow etc.
I admit I will have spend more time with documents that are available. I was hoping someone from the Prime/HP41 communities could give me some mentoring help besides "read the manual". I looked at the "help" screen and I could not map it so I could use the PY41e emulator with the shifted keys. For a beginning, how do I access " XEQ RAD" with the PY41e emulator. It would be usefull to post even a little bit of tips to help other users who want to make dual use of the HP Prime calculator. The number of current experienced HP41 users are not getting any younger. Thanks. |
08-07-2021, 03:47 AM
(This post was last modified: 08-07-2021 03:49 AM by Liamtoh Resu.)
Post: #56
Ok Thanks Guenter for the "XEQ RAD" tip.
I used the V41 as a trainer. So on the Py41e emulator: [toolbox/Mem] brings up XEQ [Alpha] puts the Py41e in ALPHA mode. I typed [R] [A] [D] I pressed the [Alpha] to take the Py41e emulator out of Alpha mode. I pressed [ENTER] to put the Py41e into radian mode :) I tested the Py41e with 3.1415926535 [Enter] 6 / The Py41e gave the expected 0.5 result. I was then able to switch the Py41e back to degrees mode. Thanks again. |
10-07-2021, 11:15 PM
(This post was last modified: 10-10-2021 09:06 AM by Peet.)
Post: #57
Amazing program, makes the Prime an almost perfect HP-41clone. I only miss the BEEP a bit, HP should give the Prime sound output
If I see that correctly, to load a .mod or .raw currently only works via the config.py? Does anyone already have an idea for an easy way to load a .raw? With the current routine, it reloads the .raw(s) every time I start it and fills up the memory. "if '<PRG>' not in focal.listPrgms(cpu):" seems not to work. Maybe because of an type-error since focal.listPrgms(cpu) isn't a string? My calculators - former: CBM PR100, HP41CV, HP11C, HP28S - current: HP48G, HP35S, Prime, DM41X, DM42, HP12C |
10-16-2021, 11:31 PM
Post: #58
(06-11-2021 12:28 AM)rprosperi Wrote:(06-11-2021 12:12 AM)Steve Simpkin Wrote: I would recommend the original HP-41C Owner's Handbook and Programming Guide. It assumes you know nothing about HP calculators and is a great example of the friendly, well written calculator manuals that HP used to write. As a fan of HP manuals myself, as I learned a lot of programming on the HP28s thick manuals, I find it really funny on such excerpts: "Should you see MEMORY LOSTin the display the first time you turn the HP-41C on, do not worry —it means that power to the continuous memory of the calculator has been inter- rupted at some time. Merely press (5 (the correction key) to clearthe error, then continue. When power to continuous memory is interrupted, all information you placed into the HP-41C is lost." Yeah, do not worry. Everything you programmed and your data is gone forever if you did not export it someway No need to say I'm reading hp41c manual for the first time, I never had the chance to own this beast. |
09-05-2024, 04:48 PM
Post: #59
I loaded the py41e on my Prime G1 with the brand new 20240901 firmware. I'm not quite experienced enough to debug what is happening so was hoping one of you could point me in the right direction to get the app running properly.
The problem is that each time I press a key the app completely reloads and then I have to press the clear soft key on the display to get back to the main emulator display screen. I have edited the config.py and seen that uncommenting the filestuff command does make a difference (display shows up with the requisite commands). I have been able to switch between fast and slow modes. Still stuck with reloading at each key press. |
