WP 34S Modulo Bug
06-23-2014, 01:45 PM
Post: #41
RE: WP 34S Modulo Bug
So the story goes happily to bed with a bug fix.
Farewell, you were an interesting thread. Not much use to me personally, can't reflash the operating system. Still "A nod's as good as a wink to a blind horse". |
06-23-2014, 05:40 PM
Post: #42
(06-23-2014 01:45 PM)Gerald H Wrote: So the story goes happily to bed with a bug fix. You need a serial cable that is not available anymore. Or you may contact Eric asking for the reflashing service. Jose Mesquita RadioMuseum.org member |
06-23-2014, 06:13 PM
Post: #43
(06-23-2014 08:34 AM)Gerald H Wrote:(06-23-2014 07:31 AM)walter b Wrote: I don't see that. If you think there's a need to convince him, feel free to do it yourself. If these were your cogent arguments I don't want to hear your sardonic ones... Cheers Andreas |
06-23-2014, 06:50 PM
Post: #44
(06-23-2014 09:19 AM)Paul Dale Wrote: I already fixed this bug -- circa twelve hours ago now. Walter doesn't touch the code. That's for me and Marcus. As for the numeric code, it is almost exclusively me.A new build can be found in the SVN repository. Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
06-23-2014, 07:27 PM
Post: #45
RE: WP 34S Modulo Bug | |||
06-23-2014, 09:48 PM
Post: #46
06-23-2014, 10:09 PM
(This post was last modified: 06-23-2014 10:59 PM by pito.)
Post: #47
(06-23-2014 01:45 PM)Gerald H Wrote: Not much use to me personally, can't reflash the operating system.Go to a mobile phone accessory shop (or m.phone service center) and ask for the "CA-42" USB data cable (the cheap clone with blue connectors, not the original Nokia one(!)). It costs almost nothing. Cut the mobile phone side connector off, there are only 3 wires inside: Code: Blue - GND Disclaimer: do it at your own risk, no warranties of any kind |
