New firmware 2.1.14596 (2021-10-01)
10-02-2021, 09:54 AM
I was surfing in hpcalc.org, and discovered an unexpected new firmware version, but I cannot find the new features:
G1: https://www.hpcalc.org/details/7469 G2: https://www.hpcalc.org/details/7783 |
10-02-2021, 03:51 PM
RE: New firmware 2.1.14596 (2021-10-01)
Interesting and unexpected.
The WAIT(-1) bug on G1 is still there, so back to (2020-01-16) version if you have any programs that use that command. |
10-02-2021, 04:57 PM
Can’t go to computer to update until Monday…any new capabilities, fixes since May update for U.S. folks, or is this mainly impacting European users?
10-02-2021, 09:27 PM
(10-02-2021 04:57 PM)lrdheat Wrote: Can’t go to computer to update until Monday…any new capabilities, fixes since May update for U.S. folks, or is this mainly impacting European users? So far no one seems to know exactly what changes and/or fixes are in it. I updated all my Primes (A, C old kb, C new kb, and D) anyway just because I like being on the current version. Tom L Cui bono? |
10-02-2021, 11:10 PM
I am aware of two fixes in it:
10-03-2021, 06:03 AM
This is a nice surprise!
10-03-2021, 08:24 AM
(This post was last modified: 10-03-2021 06:00 PM by StephanP.)
The Connectivity Kit (new or old version) does not appear to pick up the firmware update automatically. I downloaded it separately from https://www.hpcalc.org/prime/pc/ and manually replaced the files in the Firmware folder.
10-03-2021, 01:20 PM
Attention MacOS users
I was able to successfully download this latest version onto my G2 Prime using MacOS.
Pre-prequisites
Install steps
The upgrade should be quite quick - less than a minute to transfer the firmware (during which the Prime will display a "Do not disconnect" warning) and then 30 seconds or so to update the firmware on the Prime (during which a 3 row progress bar chart is shown). If the calc appears to do nothing, locks up or goes back to input mode (so you can enter numbers on the keyboard for example) then you have gone wrong. |
10-03-2021, 03:10 PM
(10-02-2021 09:54 AM)akmon Wrote: I was surfing in hpcalc.org, and discovered an unexpected new firmware version, but I cannot find the new features: Bonjour Merci pour l'information. Hello Thank you for the information. Sorry for my english |
10-03-2021, 07:43 PM
(10-03-2021 01:20 PM)BruceH Wrote: I was able to successfully download this latest version onto my G2 Prime using MacOS. Awesome, Bruce, it worked! Thanks a lot! I'm up-to-date! |
10-03-2021, 08:18 PM
(10-03-2021 07:43 PM)metawops Wrote: A USB-2 hub Notice it says some USB 3 ports, not all. This bug was fixed in version 1.2 and we're up to 2.1 now so it shouldn't be a problem unless you haven't updated since an ancient version. Tom L Cui bono? |
10-04-2021, 01:39 AM
There's no 20211001 firmware on the HP FTP server; the newest is 20210505, and 20210609 for the emulator. There's also no new information in the release_info.txt in either firmware release. It's strange that they would release it with no info---in fact, where did it come from if it's not on HP's servers? Was it uploaded to hpcalc.org by a member of the software team themselves?
I see no discernable difference between this version and the last one, so it's probably just a routine bugfix update. I upgraded my G2, and its VERSION string shows "Software Version: 2.1.14596 (2021 10 01) Hardware Version: D CAS Version 1.5.0 Operating System: V2.060.650". Unfortunately, I don't remember what the last version's VERSION string was; does anyone else have it? I have a dim recollection of a different Operating System number in particular. |
10-04-2021, 09:49 AM
This is due to a small error in the LOGB function we've come accross in The Netherlands. LOGB in PPL was not understood by the CAS, who is doing the derivative for the extremum function. Detecting LOGB in the PPL to CAS convertor fixed the problem. Some other small fixes were done in the same time. This is a first BETA update, the official one will follow soon. Product Manager HP for MORAVIA Consulting, the EMEA & AP Licensee for HP Calculators. http://www.hpcalcs.com |
10-04-2021, 12:36 PM
RE: New firmware 2.1.14596 (2021-10-01) | |||
10-04-2021, 10:04 PM
(10-03-2021 08:18 PM)toml_12953 Wrote:(10-03-2021 07:43 PM)metawops Wrote: A USB-2 hub Firstly, "some ports" might be true for Windows, but most Macs seem affected. Secondly, the fact that the bug was fixed in v1.2 is only relevant for those who bought their Prime with an OOTB version >= 1.2. Anyone with an earlier version and hit by the USB bug would be unable to upgrade from their ancient version, unless they knew the USB2 trick. |
10-05-2021, 04:58 AM
10-05-2021, 02:49 PM
Waiting for complete cas commands, these are the ones that can be executed by the calculator.
10-05-2021, 10:14 PM
I'm a little bit confused by this software update.
I downloaded the link for G1 Here (10-02-2021 09:54 AM)akmon Wrote: I was surfing in hpcalc.org, and discovered an unexpected new firmware version, but I cannot find the new features: I installed it on my G1. The top of the release notes, I mean these are the top release notes, highest, assumedly latest, even if the date of update isn't correct, is should be October, right?: Quote:HP Prime – Release Notes So, back to which one doesn't work on mines. That contained (fixed bugs): 5. ABS(1/3+1/3+1/3) was not 1 But I can definitely tell you, that if I type (and I use the little vertical line instead of ABS, yeah?) ABS(1/3+1/3+1/3) and then hit Enter, then I get the result of 0.9999999999. Was that not one of the fixes? Quote:fixed bugs: Point 5 should have sorted out for me: But if I search the manual |
10-05-2021, 10:35 PM
(10-05-2021 10:14 PM)matalog Wrote: I'm a little bit confused by this software update. The release notes have not been updated for this release. In CAS I get 1 for abs(1/3+1/3+1/3) In Home I get .9999999999 Tom L Cui bono? |
10-06-2021, 12:17 AM
(10-05-2021 10:35 PM)toml_12953 Wrote: The release notes have not been updated for this release. Eric posted some minor notes from CdB above; looks like a very small bug-fix release. As for your results, they both look correct to me. --Bob Prosperi |
