41 users: what's your SIZE?
12-29-2021, 01:23 PM
Purely out of idle curiosity, I was wondering what everyone else typically keeps SIZE set to on their 41. I used to go with 50 as a nice round default, but that's way more than I usually need, so now I tend to stick with 32 since that's how much you can fit on two sides of a magnetic card. Anyone else have any specific preference?
12-29-2021, 02:04 PM
RE: 41 users: what's your SIZE?
100, since that's the default SIZE for the 41CX. I just leave it as-is.
<0|ɸ|0>
-Joe-
12-29-2021, 02:17 PM
(12-29-2021 02:04 PM)Joe Horn Wrote:  100, since that's the default SIZE for the 41CX. I just leave it as-is.
Same here.
Dave
RPN rules!
12-29-2021, 02:32 PM
Interesting, two votes for the default. I never need anywhere near that many data registers, so I always reclaim at least half that so I can stuff in more programs. Wink
12-29-2021, 02:51 PM
Since I started on a C (with, later on, one memory module) I usually kept it @30.
12-29-2021, 05:38 PM (This post was last modified: 12-29-2021 06:04 PM by DaveBr.)
(12-29-2021 02:32 PM)Dave Britten Wrote:  Interesting, two votes for the default. I never need anywhere near that many data registers, so I always reclaim at least half that so I can stuff in more programs. Wink
I NEVER use more than about a dozen data registers, but 219 program registers has always been plenty for me.
Dave
RPN rules!
12-29-2021, 05:49 PM
SIZE 026 as a carry-over from the HP-67.
PSIZE-controlled most of the time though.
12-29-2021, 06:02 PM
Normal usage : SIZE 017 → data storage (00 to 10) and stat registers (11 to 16) which leaves 2118 bytes for programs (302 registers + 4 bytes)
12-29-2021, 07:39 PM
26 here. I don't remember which of my many programs needed that much, but I always have memory pretty full, and then when I need to write another program and don't have enough room, I'm looking for which one(s) I can delete or move to extended memory.
12-29-2021, 08:52 PM
SIZE 30 as default since my first 41CV, 41 years ago.
My calculators - former: CBM PR100, HP41CV, HP11C, HP28S - current: HP48G, HP35S, Prime, DM41X, DM42, HP12C
12-29-2021, 09:32 PM
30
12-30-2021, 02:39 AM
Always 40, though I've no recall at all why that number. I have a vague memory that some program used long ago (and probably never since) needed 40 so I set it and left it that way.
I should load a WALL file saved on a tape in 1984 to see what my 'normal' configuration really was then. Digital records are often more reliable than (my) memory! Smile
12-30-2021, 11:22 AM
How to recall value of SIZE?
After few RCLs 20. (41CV)
On my 15C 15 regs kept (20 too much)
12-30-2021, 12:36 PM
(12-30-2021 02:39 AM)rprosperi Wrote:  Always 40, though I've no recall at all why that number. I have a vague memory that some program used long ago (and probably never since) needed 40 so I set it and left it that way.
Ha, I'm impressed that you've kept good backups all that time. Smile
12-30-2021, 01:14 PM
(12-30-2021 11:22 AM)Csaba Tizedes Wrote:  How to recall value of SIZE?
Some of the possible ways include these: The extended function SIZE? recalls the current SIZE setting to the stack. You have that function if you have a 41CX or an extended function module. The PPC ROM contains a synthetic program called S? which returns the same value. A standard program could do it too, using flag 25 and a binary search, but it would be slow.
<0|ɸ|0>
-Joe-
12-31-2021, 03:37 AM
100. Since RCL asks for two digits and for some reason I like to STO at address 99.
01-01-2022, 07:35 PM
50 ...
01-02-2022, 05:04 PM
About 173...
01-04-2022, 05:23 AM
Size 100. For speed similar to agarza. In technical class exams I would store intermediary problem computation results in registers 11, 22, 33, 44 and so forth since double pressing one key was the fastest way to STO results during an exam.
Where useful, for each STOred result I'd note the register number in the margin of my engineering notepad paper so I could later either double-check my computations or use partial results to work another solution path for a problem. Also, I had keyboard overlays with constants/conversions for specific classes and I'd pre-store these numbers in the top row 77 88 99, or for classes with lots of constants in 01, 02, 03 ... .
Unnecessary today with tables etc. in Excel. But, these days if I'm away from my PC I use Free42 on my phone and I have 5 softkey presets to store to, or I revert to double-pressing a number to STO.
01-04-2022, 06:06 AM
(01-04-2022 05:23 AM)g8241CV Wrote:  Size 100. For speed similar to agarza. In technical class exams I would store intermediary problem computation results in registers 11, 22, 33, 44 and so forth since double pressing one key was the fastest way to STO results during an exam.
Remember you can use the top two rows of keys to enter 01, 02, ...10, so STO 01 is STO ∑+, STO 02 is STO 1/X, etc., so you don't need to do two keypresses for register numbers 1 through 10. Same thing goes for RCL, FIX, SCI, ENG, VIEW, TONE, LBL, GTO, and lots more.
