Discount Rate
04-04-2022, 01:54 PM
Discount Rate
Find attached a two-page extract from Fundamentals of Infrastructure Engineering, Appendix A (pgs. 445 & 447) with respect to Computing the Discount Rate utilizing a generic calculator adaptation of the Newton-Raphson algorithm. The article suggests this listing needs only minor alterations for RPN deployment. We all await the response from the readership to this challenge.
[attachment=10502] [attachment=10503]
BEST!
SlideRule
04-08-2022, 07:44 PM (This post was last modified: 04-09-2022 08:00 AM by Thomas Klemm.)
RE: Discount Rate
There is a bug in the listing.
When calculating
- n (i + 1)^{n - 1}
the multiplication by \( n \) is missing.
In the third column we find:
rcl 9           2
aˣ rcl 4 =      3
sto - chs       1
Instead it should be:
rcl 9           2
aˣ rcl 4 =      3
rcl × 7         2
sto - chs       1
Quote:The machine should have a capacity of 98 keystrokes to perform this routine.
With this fix we are at 100 keystrokes.
Instead of using this suggestion I would rather follow how this is done in the HP-80.
Initial Value
\[i_0 = \frac{2(n-P)}{n(n+1)}\]
Newton Iteration
\begin{align}
Z &= (1 + i)^{-n} \\
i_\text{next} &= i \left[ 1 - \frac{iP - (1 - Z)}{1 - Z - \frac{niZ}{1 + i}} \right]
\end{align}
Register
R0: n
R1: P = PV / PMT
R2: i
R3: u = 1 + i
R4: Z = u-n
R5: v = Z - 1
Program
This program is for the HP-25, but can easily be adapted for other models:
01: 24 00    : RCL 0            ; n
02: 24 01    : RCL 1            ; P
03: 41       : -                ;
04: 02       : 2                ;
05: 61       : *                ;
06: 24 00    : RCL 0            ;
07: 31       : ENTER            ;
08: 15 02    : g x^2            ;
09: 51       : +                ;
10: 71       : /                ; 2 * (n - P) / (n^2 + n)
11: 23 02    : STO 2            ; i
12: 01       : 1                ;
13: 51       : +                ;
14: 23 03    : STO 3            ; u = 1 + i
15: 24 00    : RCL 0            ; n
16: 32       : CHS              ; -n
17: 14 03    : f y^x            ;
18: 23 04    : STO 4            ; Z = u^(-n)
19: 01       : 1                ;
20: 41       : -                ;
21: 23 05    : STO 5            ; v = Z - 1
22: 24 02    : RCL 2            ; i
23: 24 01    : RCL 1            ; P
24: 61       : *                ;
25: 51       : +                ; i * P + v
26: 24 00    : RCL 0            ; n
27: 24 02    : RCL 2            ; i
28: 61       : *                ; n * i
29: 24 04    : RCL 4            ; Z
30: 61       : *                ; n * i * Z
31: 24 03    : RCL 3            ; u
32: 71       : /                ; n * i * Z / u
33: 24 05    : RCL 5            ; v
34: 51       : +                ; v + n * i * Z / u
35: 71       : /                ; (i * P + v)/(v + n * i * Z / u)
36: 01       : 1                ;
37: 51       : +                ; 1 + (i * P + v)/(v + n * i * Z / u)
38: 24 02    : RCL 2            ; i
39: 61       : *                ;
40: 74       : R/S              ; i_next
41: 13 11    : GTO 11           ;
Quote:The procedure is terminated when two successive values differ by less than a pre-set amount. This test can easily be built-in to the program by a conditional if-then-else command sequence if desired and if sufficient capacity is available. A round-off command should be programmed just prior to the test, of course.
Example: True Interest Rate of a Loan
What is the true interest rate on a 36 month loan for $3000 having monthly payments of $100?
FIX 6
36
STO 0
3000
ENTER
100
STO 1
CLEAR PRGM
R/S
0.010190
R/S
0.010207
R/S
0.010207
Thus, after only three iterations, we get the result.
We can now calculate the annual percentage rate:
FIX 2
1200
12.25
References
04-08-2022, 10:21 PM
RE: Discount Rate
Although time flow only from the present to the future, formula does not care.
We can use the *same* code, getting interest rate from PMT, FV (now, with PV=0)
Just have the code run with negative input, traveling back in time Big Grin
Example, lets try n=36, PMT=100, FV=5000, find i
lua> n = -36 -- note the negative sign, for both n and p
lua> p = -5000/100
lua> i = 2*(n-p)/(n*(n+1))
lua> i
0.022222222222222223
Guess i formula is not designed for FV, but lets use it anyway.
With better guess_i(n,pv,pmt,fv), we get guess i = 0.0179687
lua> z = (1+i)^-n
lua> i = i - i*(i*p-(1-z))/(1-z-n*i*z/(1+i))
lua> i
0.018164680329101488
lua> z = (1+i)^-n
lua> i
0.017958086653757012
lua> z = (1+i)^-n
lua> i
0.017957584809347397
04-09-2022, 12:50 PM (This post was last modified: 04-09-2022 01:24 PM by Albert Chan.)
RE: Discount Rate
(10-16-2020 04:02 PM)Albert Chan Wrote:  XCas> C := I*N / (1 - (1+I)^-N)       // C = |N*PMT/PV|, "compounding factor"
XCas> series(C,I,polynom)
\(1
+\frac{I(N+1)}{2}
+\frac{I^2 (N^2-1)}{12}
+\frac{I^3 (-N^2+1)}{24}
+\frac{I^4 (-N^4+20N^2-19)}{720}
+\frac{I^5 (N^4-10N^2+9)}{480}\)
This may be a better rate estimate, by dropping compounding factor O(I^2)
With previous defined P, solve for I, we have:
\(\displaystyle I ≈ \frac{2\;(N-P)}{P\;(N+1)}\)
For previous 2 examples, formula give slightly better guess rate.
Newton steps (denoted by →) converge faster.
I(N= 36, P= 3000/100) ≈ 0.010811 → 0.010203 → 0.010207
I(N=-36, P=-5000/100) ≈ 0.016000 → 0.018003 → 0.017958
04-09-2022, 05:47 PM
RE: Discount Rate
(02-13-2020 10:42 AM)Gamo Wrote:  To find the guess the HP-55 programs book used these formulas.
1. Direct Reduction Loan Interest Rate
[1 / (PV / PMT)] - [(1 / n^2) x (PV / PMT)]
Using our symbols here, we have:
\(\displaystyle I ≈ \frac{1}{P} - \frac{P}{N^2}\)
This is even better, and work well with big N.
With above guess rate formula, we have:
I(N= 36, P= 3000/100) ≈ 0.010185 → 0.010207
I(N=-36, P=-5000/100) ≈ 0.018580 → 0.017962 → 0.017958
Does anyone know how this is derived ?
This is as good as first pade approximation of reverted C, but less complicated.
\(\displaystyle I ≈ \frac{6\;(N-P)}
{N\;(N-1) + 2P\;(N+2)}\)
I(N= 36, P= 3000/100) ≈ 0.010169 → 0.010207
I(N=-36, P=-5000/100) ≈ 0.017751 → 0.017958
04-10-2022, 04:03 AM
RE: Discount Rate
(04-09-2022 05:47 PM)Albert Chan Wrote:  \(\displaystyle I ≈ \frac{1}{P} - \frac{P}{N^2}\)
This is my guess on how formula is derived, using continuous compounding.
With small I, (1+I)^-N = exp(ln(1+I)*-N) ≈ exp(-I*N)
Let x = I*N, and solve for x
C = N/P ≈ x / (1 - e^-x)
x = I*N = C + W(-C*exp(-C))            // W has 2 branches, but it does not matter here
Let y = -C*exp(-C), solve for I
I ≈ 1/P + W(y)/N
If we can show -W(y) ≈ 1/C, we have I ≈ 1/P - 1/(CN) = 1/P - P/N^2, and prove is done.
There are 2 LambertW branches, but we only want estimate when C close to 1
Both branches behave about the same, because y is very close to -1/e
C = 1 + ε      → y = 1/e * (-1 + ε^2/2 - ε^3/3 + ε^4/8 - ...)
I borrowed lyuka e^W estimation formula, replace 0.3 by 1/3, for Puiseux series.
e^W(y) ≈ 1/e + sqrt ((2/e)*(y+1/e)) + (y+1/e)/3
-W(y)
= 1 - ln(e * e^W(y))
= 1 - ln(1 + sqrt(2*(e*y+1)) + (e*y+1)/3)
= 1 - ln(1 + ε - 1/6*ε^2 + ...)
= 1 - 2*atanh(ε/2 - 1/3*ε^2 + ...)
≈ 1 - ε + 2/3*ε^2
≈ 1/(1+ε)
= 1/C            QED
To confirm math is correct, at least numerically.
lua> z = 1e-4
lua> c = 1 + z
lua> y = -c*exp(-c)
lua> -W(y), 1 - z + 2/3*z^2, 1/c
0.9999000066665401      0.9999000066666667      0.9999000099990001
04-10-2022, 12:19 PM (This post was last modified: 04-12-2022 11:16 PM by Thomas Klemm.)
RE: Discount Rate
After a closer inspection of the assembler code I noticed that in fact the following formula is used:
Newton Iteration
\begin{align}
i_\text{next} &= i \left[ 1 + \frac{P + \frac{Z - 1}{i}}{\frac{Z - 1}{i} + \frac{nZ}{1 + i}} \right]
\end{align}
This saves two multiplications by \( i \) at the cost of one division.
Register
R0: n
R1: P = PV / PMT
R2: i
R3: u = 1 + i
R4: Z = u-n
R5: v = (Z - 1) / i
Program
It allows to reduce the program by 2 steps:
01: 24 00    : RCL 0
02: 24 01    : RCL 1
03: 41       : -
04: 02       : 2
05: 61       : *
06: 24 00    : RCL 0
07: 31       : ENTER
08: 15 02    : g x^2
09: 51       : +
10: 71       : /
11: 23 02    : STO 2
12: 01       : 1
13: 51       : +
14: 23 03    : STO 3
15: 24 00    : RCL 0
16: 32       : CHS
17: 14 03    : f y^x
18: 23 04    : STO 4
19: 01       : 1
20: 41       : -
21: 24 02    : RCL 2
22: 71       : /
23: 23 05    : STO 5
24: 24 01    : RCL 1
25: 51       : +
26: 24 00    : RCL 0
27: 24 04    : RCL 4
28: 61       : *
29: 24 03    : RCL 3
30: 71       : /
31: 24 05    : RCL 5
32: 51       : +
33: 71       : /
34: 01       : 1
35: 51       : +
36: 24 02    : RCL 2
37: 61       : *
38: 74       : R/S
39: 13 11    : GTO 11
04-10-2022, 11:29 PM (This post was last modified: 04-10-2022 11:29 PM by Eddie W. Shore.)
RE: Discount Rate
HP 32S/HP 32SII code:
N = n (R0)
P = PV/PMT (R1)
I = i (R2)
U = 1+i (R3)
Z = u^(-n) (R4)
V = Z - 1 (R5)
1. Press XEQ I, enter N, enter PV
N = n; P = PV/PMT (or)
N = -n; P = -FV/PMT
2. Press XEQ J
3. Keep pressing R/S until desired accuracy is reached
I01 LBL I
I02 INPUT N
I03 INPUT P
I04 -
I05 2
I06 ×
I07 RCL N
I08 ENTER
I09 x^2
I10 +
I11 ÷
I12 STOP
J01 LBL J
J02 STO I
J03 1
J04 +
J05 STO U
J06 RCL N
J07 +/-
J08 y^x
J09 STO Z
J10 1
J11 -
J12 STO V
J13 RCL I
J14 RCL× P
J15 +
J16 RCL N
J17 RCL× I
J18 RCL× Z
J19 RCL÷ U
J20 RCL+V
J21 ÷
J22
J23 +
J24 RCL× I
J25 STOP
J26 GTO J
Size:
I: 18.0 bytes, Checksum 32SII: 82BD
J: 39.0 bytes, Checksum 32SII: 3EBB
57 bytes total
04-11-2022, 01:18 AM
RE: Discount Rate
(04-10-2022 12:19 PM)Thomas Klemm Wrote:  Newton Iteration
\begin{align}
\end{align}
When interest rate converging to true rate, numerator goes 0, or (Z-1)/i = -P
I was reading https://brownmath.com/bsci/loan.htm#Newton.
It's rate newton formula actually replaced denominator (Z-1)/i by -P
The formula quoted above is good when guess rate is under-estimated.
This explained why it has i0 = 2*(n-p)/(n*(n+1)) instead of 2*(n-p)/(p*(n+1))
Too high a guess can make Newton's step diverge.
Example, with N=36, P=30, guess rate of 0.08, it barely able to converge.
0.08 → -0.071887 → -0.041499 → -0.014129 → 0.003911 → 0.009742 → 0.010205 → 0.010207
"-P" version had the opposite problem, and preferred over-estimated guess.
Again, with N=36, P=30, guess rate of 0.004, it totally diverged
0.004 → -0.009120 → -0.003414 → -0.000780 → -0.000059 ...
A better option is to solve NPMT=0 instead (now used for rate search in Plus42, see tvm_eq())
From NPMT=0 based loan_rate(n, pv, pmt, fv, i), simplified with FV=0, we get this:
\( \displaystyle \large
i_\text{next} = i \left[
1 -
\frac{(\frac{Z - 1}{i})/P + 1}
{(\frac{nZ}{1 + i})/(\frac{Z - 1}{i}) +1} \right] \)
This version, convergence is slightly faster, and *very* stable for guess i
Again, with N=36, P=30, but ridiculous rate guess:
10+10 → 0.033333 → 0.012232 → 0.010228 → 0.010207
10−10 → 0.000231 → 0.010782 → 0.010209 → 0.010207
04-11-2022, 02:37 AM
RE: Discount Rate
(04-10-2022 11:29 PM)Eddie W. Shore Wrote:
J20 RCL+ V
J21 ÷
J22
J23 +
J24 RCL× I
There's a 1 missing in line J22.
Using my 2nd program could possibly save a byte or two.
You could also consider using the solver.
This made me wonder if there's a programmable HP calculator with recall arithmetic but without a solver (generic or specific for the TVM problem).
04-11-2022, 03:11 PM (This post was last modified: 04-12-2022 03:53 PM by Albert Chan.)
RE: Discount Rate
(04-11-2022 01:18 AM)Albert Chan Wrote:  The formula [OP] is good when guess rate is under-estimated.
To be more precise, OP formula preferred rate magnitude under-estimated.
Plotting errors of both rate estimate, error(n version) ≈ -2 * error(p version)
In other words, this is much better rate estimate.
\(\displaystyle I_0 = \frac{2\;(N-P)}{N+1}
\left( \frac{{1 \over N} + {2 \over P}}{3} \right)
Examples:
I0(N= 36, P= 30) = .010210      // true rate = .010207
I0(N=-36, P=-50) = .018074     // true rate = .017958
Nice. But, for OP formula, we wanted guess rate under-estimated.
Perhaps give up some accuracy for safety in convergence, and make ratio 1:1 ?
While we are at it, why not assume N+1 ≈ N, to simplify further ?
\(\displaystyle I_0 = \frac{2\;(N-P)}{N}
\left( \frac{{1 \over N} + {1 \over P}}{2} \right)
= \frac{1}{P} - \frac{P}{N^2}
This may be how I0 = 1/P - P/N² comes from Smile
Update: Perhaps formula designed also to match asymptote, when C is big.
When compounding factor C is big, literally all payments goes to paying interest.
C = N/P = I*N/(1-(1+I)^-N) ≈ N*I      → I = 1/P
Rate formula matched this behavior: I0 = 1/P - P/N^2 = (1 - 1/C^2)/P ≈ 1/P
For better estimate, we can use continuous compouding for I, derived earlier.
(04-10-2022 04:03 AM)Albert Chan Wrote:  Let y = -C*exp(-C), solve for I
I ≈ 1/P + W(y)/N
When C = N/P is big, y is small, we have W(y) ≈ y
I ≈ C/N + (-C*exp(-C))/N = (1-exp(-N/P)) / P
04-11-2022, 03:57 PM
RE: Discount Rate
(04-11-2022 03:11 PM)Albert Chan Wrote:  Plotting errors of both rate estimate, error(n version) ≈ -2 * error(p version)
Instead of looking at plots, lets look at reverted series of I, from C = N/P
More specifically, from u = (C-1)/(N+1)
From A Series of Interest, by David W. Cantrell
I = (2*u)*(1 - (N-1)/3*u * (1 - (2*N+1)/3*u * (1 - (11*N+7)/15*u * (1 - ...
Assume 2 terms of I is good enough for estimating true I
Assume N big enough, so that N+1 ≈ N-1 ≈ N
Let C = 1 + ε
I/(2u) ≈ 1 − (N/3) * (ε/N) = 1 − 1/3*ε
I/(2u/C) ≈ (1+ε) * (1-ε/3) ≈ 1 + 2/3*ε
Rate guess, p version is (2u), n version is (2u/C), rel error ratio ≈ -2      QED
04-11-2022, 08:48 PM
RE: Discount Rate
Comparing the code in HP Journal to the US patent, I noticed something slightly interesting:
In the US patent DOWN ROTATE is used twice in several places, while in HP Journal a JSB DR2 is used.
Here are the corresponding code snippets for comparison:
US Patent
L3222:   .....1...1      → L3004               JSB XTY
L3223:   11..1.1...                            DOWN ROTATE
L3224:   .1..1.1...                            C → STACK
L3225:   111..1.1.1      → L3345               JSB MPY
L3226:   ..1...111.                            B → C[W]
L3227:   11..1.1...                            DOWN ROTATE
L3230:   11..1.1...                            DOWN ROTATE
L3231:   111...11.1      → L3343               JSB DIV
L3232:   11..1.1...                            DOWN ROTATE
L3233:   11..1.1...                            DOWN ROTATE
L3234:   .1...11..1      → L3106               JSB ONE
L3235:   .11.1.1..1      → L3152               JSB SUB
L3236:   1.1.1.1...                            M → C[W]
L3237:   111...11.1      → L3343               JSB DIV
L3240:   11..1.1...                            DOWN ROTATE
L3241:   11..1.1...                            DOWN ROTATE
L3242:   .11.1.1..1      → L3152               JSB SUB
HP Journal
L3224:   .....1...1      → L3004               JSB XTY
L3225:   11..1.1...                            DOWN ROTATE
L3226:   .1..1.1...                            C → STACK
L3227:   111..1...1      → L3344               JSB MPY
L3230:   ..1...111.                            B → C[W]
L3231:   ...1.1.1.1      → L3025               JSB DR2
L3232:   111...11.1      → L3343               JSB DIV
L3233:   ...1.1.1.1      → L3025               JSB DR2
L3240:   ...1.1.1.1      → L3025               JSB DR2
L3241:   .11.1.1..1      → L3152               JSB SUB
While I couldn't find the DR2 label in ROM 3 of the US patent, I was able to find similar code in ROM 5:
L5071:   11..1.1...                    DOWN3 : DOWN ROTATE
L5072:   11..1.1...                    DOWN2 : DOWN ROTATE
L5073:   11..1.1...                            DOWN ROTATE
L5074:   ....11....                            RETURN
Both DOWN2 and DOWN3 are used in this ROM.
I wasn't aware of several ROM versions of the HP-80.
Based on Bernhard's statement I assume that the code from the US patent is used in the HP-80:
Quote:I compared my HP-80 ROM code and found, that is was correct.
While some of the ROMs can be downloaded, the HP-80 unfortunately is missing.
Therefore I can not verify that.
If anyone can shed some light on the subject I would be very grateful.
04-12-2022, 11:11 PM
RE: Discount Rate
(04-10-2022 12:19 PM)Thomas Klemm Wrote:  After a closer inspection of the assembler code I noticed that in fact the following formula is used:
For this I wrote a simulator for the CPU, similar to the Code Analyzer for HP Calculators:
@trace
def ADD(): # 03153
    global A, B, C, D, E, F, M
    B = A
    A = C = A + C
@trace
def SUB(): # 03152
    B = A
    A = C = A - C
@trace
def MPY(): # 03345
    B = A
    A = C = A * C
@trace
def DIV(): # 03343
    B = C
    A = C = A / C
@trace
def XTY(): # 03004
    B = A
    D = C
    A = C = A**C
@trace
def ONE(): # 03106
    A, C = C, 1
@trace
def CSN(): # 03321
    E = - E
@trace
def DOWN_ROTATE():
    C, D, E, F = D, E, F, C
@trace
def STACK_A():
    A, D, E = D, E, F
@trace
def C_STACK():
    D, E, F = C, D, E
@trace
def A_EXCHANGE_B():
    A, B = B, A
@trace
def B_EXCHANGE_C():
    B, C = C, B
@trace
def C_EXCHANGE_M():
    C, M = M, C
@trace
def B_C():
    C = B
@trace
def C_A():
    A = C
@trace
def M_C():
    C = M
@trace
def TEN6(): # 03354
    C = M
    C *= 100
    A *= 10000
def trace(operation):
    def fmt(s):
        return str(s)
    def wrapper():
        operation()
        if SYMBOLIC:
            print((
              f"A: {fmt(A):<45s}    "
              f"B: {fmt(B):<45s}    "
              f"C: {fmt(C):<45s}    "
              f"D: {fmt(D):<45s}    "
              f"E: {fmt(E):<45s}    "
              f"F: {fmt(F):<45s}    "
              f"M: {fmt(M):<45s}    "
              f": {operation.__name__}  "
        else:
            print((
              f"A: {A:< 20.12e}    "
              f"B: {B:< 20.12e}    "
              f"C: {C:< 20.12e}    "
              f"D: {D:< 20.12e}    "
              f"E: {E:< 20.12e}    "
              f"F: {F:< 20.12e}    "
              f"M: {M:< 20.12e}    "
    return wrapper
First we create some symbols:
from sympy import symbols, simplify, expand, latex
n, PMT, PV, P, i, Z, Δi = symbols("n PMT PV P i Z Δi")
Then we reset the registers:
A, B, C, D, E, F, M = [0] * 7
SYMBOLIC = True
And now we just follow the assembler code.
From time to time, we reassign variables to keep the expressions simple.
PS: I had to split this post since it was too big.
04-12-2022, 11:13 PM (This post was last modified: 04-13-2022 01:26 AM by Thomas Klemm.)
RE: Discount Rate
C, D, E = PV, PMT, n
C_STACK()
STACK_A()
DOWN_ROTATE()
DIV()
A: 0                                                B: 0                                                C: PV                                               D: PV                                               E: PMT                                              F: n                                                M: 0                                                : C_STACK  
A: PV                                               B: 0                                                C: PV                                               D: PMT                                              E: n                                                F: n                                                M: 0                                                : STACK_A  
A: PV                                               B: 0                                                C: PMT                                              D: n                                                E: n                                                F: PV                                               M: 0                                                : DOWN_ROTATE  
A: PV/PMT                                           B: PMT                                              C: PV/PMT                                           D: n                                                E: n                                                F: PV                                               M: 0                                                : DIV  
print(latex(C))
\frac{PV}{PMT}
P = \frac{PV}{PMT}
A = C = P
C_EXCHANGE_M()
DOWN_ROTATE()
C_STACK()
ONE()
ADD()
A_EXCHANGE_B()
MPY()
C_EXCHANGE_M()
STACK_A()
C_STACK()
CSN()
DOWN_ROTATE()
SUB()
ADD()
C_EXCHANGE_M()
DIV()
A: P                                                B: PMT                                              C: 0                                                D: n                                                E: n                                                F: PV                                               M: P                                                : C_EXCHANGE_M  
A: P                                                B: PMT                                              C: n                                                D: n                                                E: PV                                               F: 0                                                M: P                                                : DOWN_ROTATE  
A: P                                                B: PMT                                              C: n                                                D: n                                                E: n                                                F: PV                                               M: P                                                : C_STACK  
A: n                                                B: PMT                                              C: 1                                                D: n                                                E: n                                                F: PV                                               M: P                                                : ONE  
A: n + 1                                            B: n                                                C: n + 1                                            D: n                                                E: n                                                F: PV                                               M: P                                                : ADD  
A: n                                                B: n + 1                                            C: n + 1                                            D: n                                                E: n                                                F: PV                                               M: P                                                : A_EXCHANGE_B  
A: n*(n + 1)                                        B: n                                                C: n*(n + 1)                                        D: n                                                E: n                                                F: PV                                               M: P                                                : MPY  
A: n*(n + 1)                                        B: n                                                C: P                                                D: n                                                E: n                                                F: PV                                               M: n*(n + 1)                                        : C_EXCHANGE_M  
A: n                                                B: n                                                C: P                                                D: n                                                E: PV                                               F: PV                                               M: n*(n + 1)                                        : STACK_A  
A: n                                                B: n                                                C: P                                                D: P                                                E: n                                                F: PV                                               M: n*(n + 1)                                        : C_STACK  
A: n                                                B: n                                                C: P                                                D: P                                                E: -n                                               F: PV                                               M: n*(n + 1)                                        : CSN  
A: n                                                B: n                                                C: P                                                D: -n                                               E: PV                                               F: P                                                M: n*(n + 1)                                        : DOWN_ROTATE  
A: -P + n                                           B: n                                                C: -P + n                                           D: -n                                               E: PV                                               F: P                                                M: n*(n + 1)                                        : SUB  
A: -2*P + 2*n                                       B: -P + n                                           C: -2*P + 2*n                                       D: -n                                               E: PV                                               F: P                                                M: n*(n + 1)                                        : ADD  
A: -2*P + 2*n                                       B: -P + n                                           C: n*(n + 1)                                        D: -n                                               E: PV                                               F: P                                                M: -2*P + 2*n                                       : C_EXCHANGE_M  
A: (-2*P + 2*n)/(n*(n + 1))                         B: n*(n + 1)                                        C: (-2*P + 2*n)/(n*(n + 1))                         D: -n                                               E: PV                                               F: P                                                M: -2*P + 2*n                                       : DIV    
print(latex(simplify(C)))
\frac{2 \left(- P + n\right)}{n \left(n + 1\right)}
i = \frac{2 \left(- P + n\right)}{n \left(n + 1\right)}
A = C = i
C_EXCHANGE_M()
DOWN_ROTATE()
C_EXCHANGE_M()
STACK_A()
ONE()
ADD()
C_STACK()
C_STACK()
B_C()
C_EXCHANGE_M()
XTY()
A: i                                                B: n*(n + 1)                                        C: -2*P + 2*n                                       D: -n                                               E: PV                                               F: P                                                M: i                                                : C_EXCHANGE_M
A: i                                                B: n*(n + 1)                                        C: -n                                               D: PV                                               E: P                                                F: -2*P + 2*n                                       M: i                                                : DOWN_ROTATE  
A: i                                                B: n*(n + 1)                                        C: i                                                D: PV                                               E: P                                                F: -2*P + 2*n                                       M: -n                                               : C_EXCHANGE_M  
A: PV                                               B: n*(n + 1)                                        C: i                                                D: P                                                E: -2*P + 2*n                                       F: -2*P + 2*n                                       M: -n                                               : STACK_A  
A: i                                                B: n*(n + 1)                                        C: 1                                                D: P                                                E: -2*P + 2*n                                       F: -2*P + 2*n                                       M: -n                                               : ONE  
A: i + 1                                            B: i                                                C: i + 1                                            D: P                                                E: -2*P + 2*n                                       F: -2*P + 2*n                                       M: -n                                               : ADD  
A: i + 1                                            B: i                                                C: i + 1                                            D: i + 1                                            E: P                                                F: -2*P + 2*n                                       M: -n                                               : C_STACK  
A: i + 1                                            B: i                                                C: i + 1                                            D: i + 1                                            E: i + 1                                            F: P                                                M: -n                                               : C_STACK  
A: i + 1                                            B: i                                                C: i                                                D: i + 1                                            E: i + 1                                            F: P                                                M: -n                                               : B_C  
A: i + 1                                            B: i                                                C: -n                                               D: i + 1                                            E: i + 1                                            F: P                                                M: i                                                : C_EXCHANGE_M  
A: (i + 1)**(-n)                                    B: i + 1                                            C: (i + 1)**(-n)                                    D: -n                                               E: i + 1                                            F: P                                                M: i                                                : XTY  
print(latex(C))
\left(i + 1\right)^{- n}
Z = \left(i + 1\right)^{- n}
A = C = Z
DOWN_ROTATE()
C_STACK()
MPY()
B_C()
DOWN_ROTATE()
DOWN_ROTATE()
DIV()
DOWN_ROTATE()
DOWN_ROTATE()
ONE()
SUB()
M_C()
DIV()
DOWN_ROTATE()
DOWN_ROTATE()
SUB()
STACK_A()
C_STACK()
B_EXCHANGE_C()
ADD()
DOWN_ROTATE()
B_EXCHANGE_C()
DOWN_ROTATE()
B_EXCHANGE_C()
DIV()
M_C()
MPY()
C_EXCHANGE_M()
A: Z                                                B: i + 1                                            C: -n                                               D: i + 1                                            E: P                                                F: Z                                                M: i                                                : DOWN_ROTATE  
A: Z                                                B: i + 1                                            C: -n                                               D: -n                                               E: i + 1                                            F: P                                                M: i                                                : C_STACK  
A: -Z*n                                             B: Z                                                C: -Z*n                                             D: -n                                               E: i + 1                                            F: P                                                M: i                                                : MPY  
A: -Z*n                                             B: Z                                                C: Z                                                D: -n                                               E: i + 1                                            F: P                                                M: i                                                : B_C  
A: -Z*n                                             B: Z                                                C: -n                                               D: i + 1                                            E: P                                                F: Z                                                M: i                                                : DOWN_ROTATE  
A: -Z*n                                             B: Z                                                C: i + 1                                            D: P                                                E: Z                                                F: -n                                               M: i                                                : DOWN_ROTATE  
A: -Z*n/(i + 1)                                     B: i + 1                                            C: -Z*n/(i + 1)                                     D: P                                                E: Z                                                F: -n                                               M: i                                                : DIV  
A: -Z*n/(i + 1)                                     B: i + 1                                            C: P                                                D: Z                                                E: -n                                               F: -Z*n/(i + 1)                                     M: i                                                : DOWN_ROTATE  
A: -Z*n/(i + 1)                                     B: i + 1                                            C: Z                                                D: -n                                               E: -Z*n/(i + 1)                                     F: P                                                M: i                                                : DOWN_ROTATE  
A: Z                                                B: i + 1                                            C: 1                                                D: -n                                               E: -Z*n/(i + 1)                                     F: P                                                M: i                                                : ONE  
A: Z - 1                                            B: Z                                                C: Z - 1                                            D: -n                                               E: -Z*n/(i + 1)                                     F: P                                                M: i                                                : SUB  
A: Z - 1                                            B: Z                                                C: i                                                D: -n                                               E: -Z*n/(i + 1)                                     F: P                                                M: i                                                : M_C  
A: (Z - 1)/i                                        B: i                                                C: (Z - 1)/i                                        D: -n                                               E: -Z*n/(i + 1)                                     F: P                                                M: i                                                : DIV  
A: (Z - 1)/i                                        B: i                                                C: -n                                               D: -Z*n/(i + 1)                                     E: P                                                F: (Z - 1)/i                                        M: i                                                : DOWN_ROTATE  
A: (Z - 1)/i                                        B: i                                                C: -Z*n/(i + 1)                                     D: P                                                E: (Z - 1)/i                                        F: -n                                               M: i                                                : DOWN_ROTATE  
A: Z*n/(i + 1) + (Z - 1)/i                          B: (Z - 1)/i                                        C: Z*n/(i + 1) + (Z - 1)/i                          D: P                                                E: (Z - 1)/i                                        F: -n                                               M: i                                                : SUB  
A: P                                                B: (Z - 1)/i                                        C: Z*n/(i + 1) + (Z - 1)/i                          D: (Z - 1)/i                                        E: -n                                               F: -n                                               M: i                                                : STACK_A  
A: P                                                B: (Z - 1)/i                                        C: Z*n/(i + 1) + (Z - 1)/i                          D: Z*n/(i + 1) + (Z - 1)/i                          E: (Z - 1)/i                                        F: -n                                               M: i                                                : C_STACK  
A: P                                                B: Z*n/(i + 1) + (Z - 1)/i                          C: (Z - 1)/i                                        D: Z*n/(i + 1) + (Z - 1)/i                          E: (Z - 1)/i                                        F: -n                                               M: i                                                : B_EXCHANGE_C  
A: P + (Z - 1)/i                                    B: P                                                C: P + (Z - 1)/i                                    D: Z*n/(i + 1) + (Z - 1)/i                          E: (Z - 1)/i                                        F: -n                                               M: i                                                : ADD  
A: P + (Z - 1)/i                                    B: P                                                C: Z*n/(i + 1) + (Z - 1)/i                          D: (Z - 1)/i                                        E: -n                                               F: P + (Z - 1)/i                                    M: i                                                : DOWN_ROTATE  
A: P + (Z - 1)/i                                    B: Z*n/(i + 1) + (Z - 1)/i                          C: P                                                D: (Z - 1)/i                                        E: -n                                               F: P + (Z - 1)/i                                    M: i                                                : B_EXCHANGE_C  
A: P + (Z - 1)/i                                    B: Z*n/(i + 1) + (Z - 1)/i                          C: (Z - 1)/i                                        D: -n                                               E: P + (Z - 1)/i                                    F: P                                                M: i                                                : DOWN_ROTATE  
A: P + (Z - 1)/i                                    B: (Z - 1)/i                                        C: Z*n/(i + 1) + (Z - 1)/i                          D: -n                                               E: P + (Z - 1)/i                                    F: P                                                M: i                                                : B_EXCHANGE_C  
A: (P + (Z - 1)/i)/(Z*n/(i + 1) + (Z - 1)/i)        B: Z*n/(i + 1) + (Z - 1)/i                          C: (P + (Z - 1)/i)/(Z*n/(i + 1) + (Z - 1)/i)        D: -n                                               E: P + (Z - 1)/i                                    F: P                                                M: i                                                : DIV  
A: (P + (Z - 1)/i)/(Z*n/(i + 1) + (Z - 1)/i)        B: Z*n/(i + 1) + (Z - 1)/i                          C: i                                                D: -n                                               E: P + (Z - 1)/i                                    F: P                                                M: i                                                : M_C  
A: i*(P + (Z - 1)/i)/(Z*n/(i + 1) + (Z - 1)/i)      B: (P + (Z - 1)/i)/(Z*n/(i + 1) + (Z - 1)/i)        C: i*(P + (Z - 1)/i)/(Z*n/(i + 1) + (Z - 1)/i)      D: -n                                               E: P + (Z - 1)/i                                    F: P                                                M: i                                                : MPY  
A: i*(P + (Z - 1)/i)/(Z*n/(i + 1) + (Z - 1)/i)      B: (P + (Z - 1)/i)/(Z*n/(i + 1) + (Z - 1)/i)        C: i                                                D: -n                                               E: P + (Z - 1)/i                                    F: P                                                M: i*(P + (Z - 1)/i)/(Z*n/(i + 1) + (Z - 1)/i)      : C_EXCHANGE_M  
print(latex((M)))
\frac{i \left(P + \frac{Z - 1}{i}\right)}{\frac{Z n}{i + 1} + \frac{Z - 1}{i}}
\Delta i = \frac{i \left(P + \frac{Z - 1}{i}\right)}{\frac{Z n}{i + 1} + \frac{Z - 1}{i}}
A = M = Δi
ADD()
C_EXCHANGE_M()
A: i + Δi                                           B: Δi                                               C: i + Δi                                           D: -n                                               E: P + (Z - 1)/i                                    F: P                                                M: Δi                                               : ADD  
A: i + Δi                                           B: Δi                                               C: Δi                                               D: -n                                               E: P + (Z - 1)/i                                    F: P                                                M: i + Δi                                           : C_EXCHANGE_M  
print(latex((M)))
i + Δi
i_\text{next} = i + \Delta i
04-18-2022, 01:58 PM
RE: Discount Rate
(04-11-2022 08:48 PM)Thomas Klemm Wrote:  If anyone can shed some light on the subject I would be very grateful.
Meanwhile I found the following comment in asm/80.asm of nonpareil:
Quote:; The code from the patent may not match released code in actual HP-80
; calculators. It does not match the interest rate calculation code
; listed in Figure 3 of the article "A Pocket-Sized Answer Machine for
; Business and Finance" in the May 1973 issue of the Hewlett-Packard
; Journal. The patent application was filed on October 7, 1972, so
; the code in the Journal code might be more recent.
Obviously I'm not the first to notice this discrepancy.
04-18-2022, 06:41 PM
RE: Discount Rate
On (far too) many occasions, when I think I may be the first to discover something, upon checking, I have found that Eric had found it, documented it, shared it, and just as likely forgotten it, long before I got there.
Same with Joe Horn...
<sigh>...
04-18-2022, 07:03 PM
RE: Discount Rate
Well, it's not the first time I've taken a close look at the assembly code from this patent.
Interestingly the bug is still there in asm/80.asm:
dd2:    shift right c[w]
    p - 1 -> p
    if p # 14
         then go to dd2
    if c[x] = 0
         then go to err71
05-11-2022, 06:22 PM
RE: Discount Rate
Examples:
There are better ways to compensate the 1:2 error ratio.
I recently updated guess_i(n, pv, pmt, fv) that keep C series terms upto I^2
Converting it with FV=0, I1 = guess_i(N, P, -1, 0):
Rough estimate: \(\displaystyle I_0 = \frac{2\;(N-P)}{P(N+1)} \)
With correction: \(\displaystyle I_1
= I_0 \left( \frac{6 + 1\;(n-1)\;I_0}{6 + 2\;(n-1)\;I_0} \right)
= I_0 - \frac{I_0}{2 + \large \frac{6}{(N-1)\;I_0}} \)
Redo examples:
N= 36, P= 30     → I0 = .010811      → I1 = .010205
N=-36, P=-50    → I0 = .016000      → I1 = .017967
