Question for Trig Gurus
07-29-2022, 12:59 PM
(This post was last modified: 07-30-2022 08:09 AM by Thomas Klemm.)
RE: Question for Trig Gurus
Bhaskara's Sine and Cosine Approximations gives a simple formula to approximate \(\cos^{-1}(x)\) in degrees:
\(\cos^{-1}(x) \approx 180 \sqrt{\frac{1 - x}{4 + x}}\) Here is a table to compare the results with the expected values in parentheses: 0.00 90.00 (90.00) 0.05 87.18 (87.13) 0.10 84.33 (84.26) 0.15 81.46 (81.37) 0.20 78.56 (78.46) 0.25 75.62 (75.52) 0.30 72.63 (72.54) 0.35 69.58 (69.51) 0.40 66.47 (66.42) 0.45 63.28 (63.26) 0.50 60.00 (60.00) 0.55 56.61 (56.63) 0.60 53.08 (53.13) 0.65 49.38 (49.46) 0.70 45.48 (45.57) 0.75 41.29 (41.41) 0.80 36.74 (36.87) 0.85 31.66 (31.79) 0.90 25.71 (25.84) 0.95 18.09 (18.19) For improved accuracy we can add a single Newton iteration: \(\alpha{'} = \alpha + \frac{180}{\pi} \frac{\cos(\alpha) - x}{\sin(\alpha)}\) This leads to this table with improved accuracy: 0.00 90.0000 (90.0000) 0.05 87.1340 (87.1340) 0.10 84.2608 (84.2608) 0.15 81.3731 (81.3731) 0.20 78.4631 (78.4630) 0.25 75.5225 (75.5225) 0.30 72.5424 (72.5424) 0.35 69.5127 (69.5127) 0.40 66.4218 (66.4218) 0.45 63.2563 (63.2563) 0.50 60.0000 (60.0000) 0.55 56.6330 (56.6330) 0.60 53.1301 (53.1301) 0.65 49.4584 (49.4584) 0.70 45.5731 (45.5730) 0.75 41.4098 (41.4096) 0.80 36.8701 (36.8699) 0.85 31.7886 (31.7883) 0.90 25.8422 (25.8419) 0.95 18.1952 (18.1949) Example x = 0.6 0.4 ÷ 4.6 = √ × 180 = 53.079104 And then from this to get a better approximation: cos - 0.6 ÷ 53.079104 sin × 180 ÷ \(\pi\) + 53.079104 = 53.130117 (53.130102) However it's a bit tedious to reenter the intermediate result twice due to the lack of a storage register. |
07-29-2022, 03:19 PM
(This post was last modified: 07-29-2022 03:56 PM by Albert Chan.)
(12-04-2014 02:36 AM)Gerson W. Barbosa Wrote:(12-02-2014 07:34 PM)Gerson W. Barbosa Wrote: For the range 1/2..1, we use simmetry. It is easy to reduce x, from [1/2 .. sqrt(2)/2], to [0 .. 1/2] cos(2y) = 2*cos(y)^2 - 1 2y = acos(2*cos(y)^2 - 1) = 90° - asin(1 - 2*sin(y)^2) Let y = asin(x): asin(x) = 45° - asin(1-2*x^2)/2 --- We can define asinq(x) = asin(sqrt(x)) This allowed simple transformation, using SOHCAHTOA mnemonic, H=O+A acos(√x) = acosq(x) = asinq(1-x) // O, A, H = 1-x, x, 1 atan(√x) = atanq(x) = asinq(x/(1+x)) // O, A, H = x, 1, 1+x (04-01-2022 05:49 PM)Albert Chan Wrote: Example, following above code steps. acos(0.6) = asinq(1 - 0.36) = pi/2 - asinq(0.36) = pi/2 - (pi/4 - asinq(0.0784)/2) = pi/4 + 1*asinq(0.02) = pi/4 + 2*asinq(0.005025253169416733) = pi/4 + 4*asinq(0.0012578955936787797) = pi/4 + 8*asinq(0.0003145728545004835) = pi/4 + 0.1418970546041639 = 0.9272952180016122 -- or, 53.13010235415598° Comment: code to reduce argument to 1/4 or less can be removed. Code can rely on "half-angle" reduction formula alone (i.e. without using pi) acos(0.6) = 1 * asinq(0.64) = 2 * asinq(0.2) = 4 * asinq(0.05278640450004206) = 8 * asinq(0.013375505266134917) = 16 * asinq(0.003355133235562103) = 32 * asinq(0.0008394880490750656) = 64 * asinq(0.0002099160770281613) = 0.9272952180016122 |
07-29-2022, 10:19 PM
Wikipedia has some integrals and series expansions that work. https://en.wikipedia.org/wiki/Inverse_tr..._functions
There are also some logarithmic forms and a nice continued fraction for arctan(x). |
07-30-2022, 08:26 AM
(07-29-2022 03:19 PM)Albert Chan Wrote: Example, following above code steps. Do you seriously consider this a solution to Namir's request? Are you aware of the severe limitations of this calculator? Since the trig functions return only five figures, we're probably okay with that order of accuracy for the inverse trig functions as well. |
07-30-2022, 09:38 AM
(This post was last modified: 07-30-2022 10:05 AM by Thomas Klemm.)
(07-29-2022 10:19 PM)ttw Wrote: There are also some logarithmic forms and a nice continued fraction for arctan(x). From Inverse trigonometric functions:Logarithmic_forms: \( \begin{align} \arctan(z)=-{\frac {i}{2}}\ln \left({\frac {i-z}{i+z}}\right) \end{align} \) These formulas can't be used as the calculator lacks complex numbers. From Inverse trigonometric functions:Continued fractions for arctangent: \( \begin{align} \arctan(z)={\frac {z}{1+{\cfrac {(1z)^{2}}{3+{\cfrac {(2z)^{2}}{5+{\cfrac {(3z)^{2}}{7+{\cfrac {(4z)^{2}}{9+\ddots }}}}}}}}}} \end{align} \) To get five correct figures we have to use 4 terms (i.e. the formula above without the \(\cdots\)). Example For x = 0.6 we get: 16 × 0.36 ÷ 9 + 7 ÷ 9 ÷ 0.36 = 1/x + 5 ÷ 4 ÷ 0.36 = 1/x + 3 ÷ 0.36 = 1/x + 1 ÷ 0.6 = 1/x 0.5404217 (0.5404195) And if we want the result in degrees we add: × 180 ÷ \(\pi\) = 30.963884 (30.963757) It can get a bit more tedious to enter \(x^2\) four times if \(x\) is an arbitrary number. Example Let's assume we want to calculate \(\cos^{-1}(x)\) for \(x=0.7\). As before we can use: \( \begin{align} \tan \frac{x}{2} &= \sqrt{\frac{1-\cos x}{1+\cos x}} \\ \end{align} \) 0.3 ÷ 1.7 = 0.1764706 16 × 0.1764706 ÷ 9 + 7 ÷ 9 ÷ 0.1764706 = 1/x + 5 ÷ 4 ÷ 0.1764706 = 1/x + 3 ÷ 0.1764706 = 1/x + 1 ÷ 0.1764706 √ = 1/x × 2 = 0.7953990 (0.7953988) And again if we want the result in degrees we add: × 180 ÷ \(\pi\) = 45.573005 (45.572996) As I don't have this calculator the results were just rounded to 7 places. Therefore the numbers may vary slightly. |
07-30-2022, 06:27 PM
(This post was last modified: 07-31-2022 11:02 AM by Albert Chan.)
For 5+ digits accuracy, code is simple, using only 2 square roots.
Code: function atand(x) -- = deg(atan(x)), |x| <= 1, 5+ digits accuracy Assume we have signed zero, atand(x) = sign(x)*90 - atand(1/x) --> maximum error (both absolute and relative) at x = ±1 lua> r3 = sqrt(3) lua> atand(1/(2+r3)), atand(1/r3), atand(1) 15.000000161153318 30.000021200229554 45.00037955691671 Update: for |x| = 1/√3 .. √3, we can map it within ±1/√3, getting 6+ digits accuracy atand(x) = sign(x)*45 - atand((1-x*x)/(2*x)) / 2 --- Code based on sequence ak = (x/2^k) / tan(atan(x)/2^k) see An algorithm for computing Logarithms and ArcTangents, by B. C. Carlson a0 = x/x = 1, g0 = sqrt(1+x*x), a1 = (x/2) / tan(atan(x)/2) = (a0+g0)/2, g1 = sqrt(a1*g0) a2 = (x/4) / tan(atan(x)/4) = (a1+g1)/2 We use Richardson extrapolation to extrapolate for a∞ = x / atan(x) Since we don't care intermediate values, we can apply weight directly. We just need to know what weight to use ... CAS> [1] CAS> 4^len(Ans)*Ans - extend([0],Ans) [4, -1] [64, -20, 1] [4096, -1344, 84, -1] [1048576, -348160, 22848, -340, 1] ... 45*a∞ ≈ (a0 - 20*a1 + 64*a2) = (a0 - 20*a1 + 32*(a1+g1)) = (a0 + 12*a1 + 32*g1) |
07-31-2022, 11:08 AM
(07-30-2022 06:27 PM)Albert Chan Wrote: see An algorithm for computing Logarithms and ArcTangents, by B. C. Carlson This reminded me of: A Unified Algorithm for Elementary Functions Thanks for posting this paper. Inverse Tangent Example x = 0.6 0.6 an 2 + 1 = √ 1.1661904 + 1 ÷ 2 = 1.0830952 × 1.1661904 = √ × 32 = 35.964003 12 × 1.0830952 + 35.964003 + 1 ÷ 45 ÷ 0.6 = 1/x × 180 ÷ \(\pi\) = 30.963783 (30.963757) Inverse Cosine It turns out that we can not use \(d(2, 2)\) here as well to get 5 correct figures. So we need to compute \(d(3, 3)\). Code Here's a Python program: Code: def arccos(x): Example 1 + 0.7 ÷ 2 = 0.85 √ 0.9219544 + 0.85 ÷ 2 = 0.8859772 × 0.9219544 = √ × 2048 = 1850.9554 704 × 0.8859772 = 623.72795 1 - 0.7 an 2 = √ 0.7141428 84 × 0.85 - 0.7 + 623.72795 + 1850.9554 ÷ 2835 ÷ 0.7141428 = 1/x × 180 ÷ \(\pi\) = 45.5729906 (45.572996) Of course we could use this formula again and then the above method to calculate \(\tan^{-1}(x)\): \( \begin{align} \tan \frac{x}{2} &= \sqrt{\frac{1-\cos x}{1+\cos x}} \\ \end{align} \) Conclusion In both cases, I assumed that the calculator only works in chain mode. Unfortunately, this means that in calculations similar to a scalar product, we often have to write down and re-enter intermediate results. An accumulator in which these products could be added would be beneficial. |
07-31-2022, 09:54 PM
(07-31-2022 11:08 AM)Thomas Klemm Wrote: Inverse Cosine There is no difference in convergence rate, whether we pick atan, asin, or acos All based on extrapolation of sequence ak = (c1/2^k) / tan(c2/2^k) ⇒ a∞ = c1/c2 Basing all from atan(x) is better, because acot(x) = atan(1/x), without using square roots. Using d(3,3), and atan argument reduced to within to ±1/√3, we get 9+ correct digits. (with simpler d(2,2), we have 6+ digits accuracy) Code: function atand(x) -- = deg(atan(x)), 9+ digits accuracy lua> function asind(x) return atand(x/sqrt(1-x*x)) end -- range = -90 .. 90 lua> function acosd(x) return 90 - asind(x) end -- range = 0 .. 180 lua> deg(atan(0.6)) , atand(0.6) 30.96375653207352 30.963756534561696 lua> deg(acos(0.6)) , acosd(0.6) 53.13010235415598 53.13010235413812 lua> deg(acos(0.7)) , acosd(0.7) 45.5729959991943 45.5729959991943 |
08-01-2022, 05:19 AM
(This post was last modified: 08-02-2022 05:05 AM by Thomas Klemm.)
(07-31-2022 09:54 PM)Albert Chan Wrote: There is no difference in convergence rate, whether we pick atan, asin, or acos That's not what I meant. If we use \(d(2, 2)\) in the implementation of \(\cos^{-1}\) we have the following function: Code: def arccos(x): This leads to the following result: 0.0: 87.024464 (90.000000) 0.1: 81.877941 (84.260830) 0.2: 76.582001 (78.463041) 0.3: 71.086883 (72.542397) 0.4: 65.326413 (66.421822) 0.5: 59.207517 (60.000000) 0.6: 52.589501 (53.130102) 0.7: 45.237511 (45.572996) 0.8: 36.695075 (36.869898) 0.9: 25.782656 (25.841933) 1.0: 0.000000 ( 0.000000) This does not produce 5 correct figures. Whereas using the previous implementation we get: 0.0: 89.999750 (90.000000) 0.1: 84.260698 (84.260830) 0.2: 78.462975 (78.463041) 0.3: 72.542366 (72.542397) 0.4: 66.421808 (66.421822) 0.5: 59.999995 (60.000000) 0.6: 53.130101 (53.130102) 0.7: 45.572996 (45.572996) 0.8: 36.869898 (36.869898) 0.9: 25.841933 (25.841933) 1.0: 0.000000 ( 0.000000) That's why I used \(d(3, 3)\) in this case. |
08-01-2022, 02:36 PM
(This post was last modified: 08-02-2022 10:35 AM by Albert Chan.)
Hi, Thomas Klemm
Thanks for clearing this up. d(3,3) were used for 5+ digits accuracy, because there is no argument reduction. Here is a version that use simpler d(2,2), but reduce asind() argument to 0 .. 1/2 a0=√(1-x²) , g0=1, a1=(g0+a0)/2, g1=√(a1*g0) 45 a∞ ≈ a0 - 20*a1 + 64*a2 = a0 + 12*a1 + 32*g1 Code: function asind(s,c) -- deg(asin(s)), 6+ digits accuracy lua> for i=0,10 do x=i/10; printf('%.1f: %.6f (%.6f)\n', x, acosd(x), deg(acos(x))) end 0.0: 90.000000 (90.000000) 0.1: 84.260830 (84.260830) 0.2: 78.463041 (78.463041) 0.3: 72.542396 (72.542397) 0.4: 66.421818 (66.421822) 0.5: 59.999979 (60.000000) 0.6: 53.130102 (53.130102) 0.7: 45.572996 (45.572996) 0.8: 36.869898 (36.869898) 0.9: 25.841940 (25.841933) 1.0: 0.000000 (0.000000) Update: Here is pade(asin(x),x,10,6) version Code: function asind(x) -- deg(asin(s)), 6+ digits accuracy acosd(x) results, using Pade version asind(x) 0.0: 90.000000 (90.000000) 0.1: 84.260830 (84.260830) 0.2: 78.463041 (78.463041) 0.3: 72.542397 (72.542397) 0.4: 66.421824 (66.421822) 0.5: 60.000037 (60.000000) 0.6: 53.130102 (53.130102) 0.7: 45.572996 (45.572996) 0.8: 36.869898 (36.869898) 0.9: 25.841926 (25.841933) 1.0: 0.000000 (0.000000) |
08-02-2022, 06:35 AM
(08-01-2022 02:36 PM)Albert Chan Wrote: … because there is no argument reduction. That's always a good thing. I just mentioned that here: (07-31-2022 11:08 AM)Thomas Klemm Wrote: Of course we could use this formula again and then the above method to calculate \(\tan^{-1}(x)\): We just have to keep in mind that we have to multiply the result by the factor \(2\). We can also have a look at the manual of the Texas Instruments SR-16 where we can find the following formulas: Inverse Trigonometric Functions Arc Sine \( \begin{matrix} \arcsin a = \left[ \left( -\frac{9}{20} a^2 + 1 \right)^{-1} \times 10 + 17 \right] \frac{a}{27} & 0 < a < \frac{1}{2} \end{matrix} \) 0.00: 0.000000 ( 0.000000) 0.05: 2.865984 ( 2.865984) 0.10: 5.739170 ( 5.739170) 0.15: 8.626925 ( 8.626927) 0.20: 11.536951 (11.536959) 0.25: 14.477471 (14.477512) 0.30: 17.457448 (17.457603) 0.35: 20.486835 (20.487315) 0.40: 23.576884 (23.578178) 0.45: 26.740526 (26.743684) 0.50: 29.992861 (30.000000) For greater accuracy \( \begin{matrix} \arcsin a = \left\{ \left[ \left(-\frac{25}{42} a^2 + 1 \right)^{-1} \times 189 + 61 \right] \frac{a^2}{1500} + 1 \right \} a \end{matrix} \) 0.00: 0.000000 ( 0.000000) 0.05: 2.865984 ( 2.865984) 0.10: 5.739170 ( 5.739170) 0.15: 8.626927 ( 8.626927) 0.20: 11.536959 (11.536959) 0.25: 14.477511 (14.477512) 0.30: 17.457598 (17.457603) 0.35: 20.487294 (20.487315) 0.40: 23.578102 (23.578178) 0.45: 26.743443 (26.743684) 0.50: 29.999316 (30.000000) Arc Tangent \( \begin{matrix} \arctan a = \left[ \left( \frac{3a^2}{5} + 1 \right)^{-1} \times 5 + 4 \right] \frac{a}{9} & 0 < a < \frac{1}{2} \end{matrix} \) 0.00: 0.000000 ( 0.000000) 0.05: 2.862405 ( 2.862405) 0.10: 5.710593 ( 5.710593) 0.15: 8.530768 ( 8.530766) 0.20: 11.309948 (11.309932) 0.25: 14.036315 (14.036243) 0.30: 16.699491 (16.699244) 0.35: 19.290736 (19.290046) 0.40: 21.803065 (21.801409) 0.45: 24.231287 (24.227745) 0.50: 26.571956 (26.565051) For greater accuracy \( \begin{matrix} \arctan a = \left\{ \left[ \left(\frac{5 a^2}{7} + 1 \right)^{-1} \times 21 + 4 \right] \frac{a^2}{-75} + 1 \right \} a \end{matrix} \) 0.00: 0.000000 ( 0.000000) 0.05: 2.862405 ( 2.862405) 0.10: 5.710593 ( 5.710593) 0.15: 8.530766 ( 8.530766) 0.20: 11.309932 (11.309932) 0.25: 14.036242 (14.036243) 0.30: 16.699236 (16.699244) 0.35: 19.290014 (19.290046) 0.40: 21.801309 (21.801409) 0.45: 24.227475 (24.227745) 0.50: 26.564407 (26.565051) |
08-02-2022, 05:28 PM
(12-01-2014 07:49 PM)Namir Wrote: The machine has trigonometric functions but not their inverse counterpart. sin(x) = x - 1/6*x^3 + 1/120*x^5 - 1/5040*x^7 + ... asin(x) = x + 1/6*x^3 + 3/40*x^5 + 5/112*x^7 + ... (sin(x)*asin(x))/x^2 = 1 + x^4/18 + x^6/30 + ... RHS x^2 term get cancelled, as expected; this made RHS ≈ 1 We flip LHS, because then ... terms get smaller in size. x^2/(sin(x)*asin(x)) = 1 - x^4/18 - x^6/30 - ... ≈ 1 - x^4/18 / (1 - 3/5*x^2) asin(x) ≈ (x^2)/sin(x) / (1 - x^4/(18 - (k = 10.8) * x^2)) Above formula, we have deg(asin(1/2)) ≈ 29.999857. If we limit x within ±1/2, we already have 5+ digits accuracy. If we back solve for k, for asin(1/2) = pi/6, we have k = 10.8709 For x within ±1/2, we can get 6+ digits accuracy, if we pick k = 10.87 If we don't have sin function, 4 terms are needed, for 6 digits accuracy. To save computations, we use 3 terms: sin(x) ≈ x - x^3/3! + x^5/5! k is adjusted to compensate, to still maintain 6+ digits accuracy. Trial and errors gives k = 10.914 \( \arcsin(x) ≈ \Large \frac{x} { \left(1 - \frac{x^2}{6} \left(1 - \frac{x^2}{20}\right) \right) \;×\; \left(1 - \frac{x^4}{18\;-\;10.914\;x^2}\right) }\) Code: function asind(x) -- deg(asin(s)), 6+ digits accuracy acosd(x) result, using above asind(x) 0.0: 90.000000 (90.000000) 0.1: 84.260830 (84.260830) 0.2: 78.463041 (78.463041) 0.3: 72.542395 (72.542397) 0.4: 66.421813 (66.421822) 0.5: 60.000010 (60.000000) 0.6: 53.130103 (53.130102) 0.7: 45.572996 (45.572996) 0.8: 36.869897 (36.869898) 0.9: 25.841944 (25.841933) 1.0: 0.000000 (0.000000) |
08-03-2022, 04:42 PM
RE: Question for Trig Gurus | |||
