Computer Programming App
09-21-2022, 08:58 PM
Are there any computer science/programming helper apps that you know of? Something like a HP 16c simulation, being able to quickly change from Hex to Dec to Bin, shift left/right, rotate etc?
09-21-2022, 09:28 PM
(This post was last modified: 09-21-2022 10:05 PM by Didier Lachieze.)
RE: Computer Programming App | |||
09-21-2022, 09:58 PM
(09-21-2022 09:28 PM)Didier Lachieze Wrote: An app for which OS? I had assumed that being posted in the HP Prime group, then it would be known I meant an app for that calculator. Yes, I would consider a CM-100, but I would need to know that it can be modded to accept a battery as well as its solar power. |
09-21-2022, 10:03 PM
09-22-2022, 01:09 PM
09-22-2022, 01:45 PM
09-22-2022, 01:52 PM
09-22-2022, 11:12 PM
The Prime has a built-in integer editor capable of base conversion and bit shifting. To access it, press [Shift] + [-].
