HP33s: Quotient & Remainder
04-25-2023, 01:02 PM
Q & R
For input of integers
Y
X
The programme returns the quotient of Y/X
Q
to the stack & stores RMDR(Y:X) in R & quotient in Q.
Does not disturb stack.
1.    LBL P
2.    STO R
3.    x<>y
4.    STO Q
5.    x<>y
6.    RMDR
7.    x<> R
8.    RCL Q
9.    RCL- R
10.    x<>y
11.    /
12.    STO Q
13.    RTN
H: LN = 39
04-29-2023, 09:15 PM
RE: HP33s: Quotient & Remainder
This should also work but I don’t have a 33s to test it:
 1.    LBL P
 2.    x<>y
 3.    STO R
 4.    x<>y
 5.    RMDR
 6.    x<>R
 7.    Lastx
 8.    INT÷
 9.    STO Q
10.    RTN
04-30-2023, 03:58 AM
Yes, programme gives correct answers on real 33s, Bravo Didier!
LN= 30 CK= 4CF7
05-01-2023, 09:20 AM
(04-29-2023 09:15 PM)Didier Lachieze Wrote:  This should also work but I don’t have a 33s to test it:
 1.    LBL P
 2.    x<>y
 3.    STO R
 4.    x<>y
 5.    RMDR
 6.    x<>R
 7.    Lastx
 8.    INT÷
 9.    STO Q
10.    RTN
Running this code on my 35S:
2E12 3 XEQ P
--> Q= 666666666667 incorrect !
      R= 2 correct
The culprit is the INT÷ function !
Curiously this bug is not in the 35S bug list.
Can someone confirm the 33S is correct or not for this test case?
J-F
05-01-2023, 03:53 PM
(05-01-2023 09:20 AM)J-F Garnier Wrote:  Running this code on my 35S:
2E12 3 XEQ P
      R= 2 correct
J-F
The 33s also gets it wrong.
<0|ɸ|0>
-Joe-
05-02-2023, 08:19 AM (This post was last modified: 05-02-2023 08:22 AM by Gerald H.)
While the answer is certainly wrong I don't use Q & R functions on 33s for numbers greater than (10^12)-1, for which the results are correct.
Incorrect answer also given for (2e12)+17.
