(15/42/47): Floor and Ceiling Functions
11-04-2023, 12:46 AM
(This post was last modified: 12-23-2023 01:32 AM by Eddie W. Shore.)
HP 15C
(not accurate for -1 < x < 0) Three labels are used: D: floor function E: ceiling function 1: used in calculation for both (roll stack down one extra time when frac(x)≠0) Code assumed starts from line 000. Code: step #: key code : key DM 42 Code: 00 { 16-Byte Prgm } HP 27S Code: FLOOR=X-MOD(X:1) Sources: Wolfram Research, Inc. "Floor Function". Path: Integer Functions > Floor[z] > Representations through equivalent functions > With related functions. Retrieved October 30, 2023. https://functions.wolfram.com/IntegerFun.../27/01/05/ Wolfram Research, Inc. "Ceiling Function". Path: Integer Functions > Ceiling[z] > Representations through equivalent functions > With related functions. Retrieved October 30, 2023. https://functions.wolfram.com/IntegerFun.../27/01/05/ |
12-22-2023, 08:28 AM
RE: (15/42/47): Floor and Ceiling Functions
Hello Eddie;
I'm afraid the 15C versions are not correct; both FLOOR and CEIL fail for X=-0.5, returning 0 and 1 respectively. Here's what I've been able to come up with for FLOOR; CEIL is similar 2 stack levels, 9 bytes without LBL and RTN. Using, but not changing I In: L.XYZT Out: X.FYZ- with F=FLOOR(X) INT X<> I LASTX FRAC TEST 2 ( X<0? ) DSE I ( always skips ) CHS ( nop ) Rv X<> I Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
12-22-2023, 01:55 PM
RE: (15/42/47): Floor and Ceiling Functions | |||
12-24-2023, 10:08 AM
(12-22-2023 01:55 PM)Albert Chan Wrote:(12-22-2023 08:28 AM)Werner Wrote: Here's what I've been able to come up with for FLOOR; CEIL is similar ... Hi Albert; yes but that uses a subroutine level ;-) Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
03-23-2024, 03:47 PM
A modest contribution
1) Some Curious Sequences Involving floor & ceiling functions: The American Mathematical Monthly; Vol. 109, No. 6 (Jun. - Jul., 2002) pp. 559-564 2) Solving Recurrence Relations involving floor & ceiling functions: Electronics Letters; 18th August 1994 Vol. 30 No. 17, pp.1391-1393 3) a Summation Formula for Sequences Involving floor & ceiling functions: ROCKY MOUNTAIN JOURNAL OF MATHEMATICS; Volume 36, Number 5, 2006, pp. 1595-1602 BEST! SlideRule |
05-17-2024, 08:01 PM
Hi.
So, after the smoke clears, what would the CEIL and FLOOR code for the 15C, 34C and 42S? Thanks. |
05-24-2024, 11:02 AM
(This post was last modified: 05-24-2024 11:03 AM by dm319.)
For 42s something like:
Code: 00 { 15-Byte Prgm } Code: 00 { 32-Byte Prgm } |
05-24-2024, 07:43 PM
(This post was last modified: 05-24-2024 09:15 PM by Matt Agajanian.)
(05-24-2024 11:02 AM)dm319 Wrote: For 42s something like: An excellent approach. Well, yours is one more in my programming toolkit. Thanks! For comparison, here’s what I cobbled together for an HP-67 or RPN-67SD: *LBL A: [Floor(x)] 001: 31 25 11 LBL A 002: 31 71 x<0? 003: 22 01 GTO 1 [006] 004: 31 83 INT 005: 35 22 RTN LBL 1: 006: 31 25 01 LBL 1 007: 31 83 INT 008: 01 1 009: 51 - 010: 35 22 RTN *LBL B: [Ceil(x)] 011: 31 25 12 LBL B 012: 31 51 x=0? 013: 35 22 RTN 014: 31 71 x<0? 015: 22 02 GTO 2 [020] 016: 31 83 INT 017: 01 1 018: 61 + 019: 35 22 RTN LBL 2: 020: 31 25 02 LBL 2 021: 31 83 INT 022: 35 22 RTN Even though my version trims off five steps, yours seems a bit more efficient and straightforward. |
