MAXX Module news
12-15-2023, 03:09 PM
MAXX Module news
Hi, just wanted to check if anyone has any news about the MAXX Module with regards to availability, functionality, etc.
Cheers PeterP Cheers, PeterP |
12-15-2023, 06:57 PM
RE: MAXX Module news
(12-15-2023 03:09 PM)PeterP Wrote: Hi, just wanted to check if anyone has any news about the MAXX Module with regards to availability, functionality, etc. I expect to start shipping before too long. Sylvain is nearly finished with his very thorough beta testing. I will be patching the included Time module code to fix the recently re-discovered bug in Time-1C. The manual is available here: https://www.systemyde.com/pdf/maxx-4d_manual.pdf Monte |
12-15-2023, 07:33 PM
(12-15-2023 06:57 PM)Monte Dalrymple Wrote: I expect to start shipping before too long. Sylvain is nearly finished with his very thorough beta testing. I will be patching the included Time module code to fix the recently re-discovered bug in Time-1C. The manual is available here: https://www.systemyde.com/pdf/maxx-4d_manual.pdf That is great news Monte, you'll get my order as soon as you say the word. |
12-16-2023, 12:01 PM
That is excellent news, as soon as you like it I’d love to place my order!
Cheers, PeterP |
01-02-2024, 08:36 PM
Sylvain finished his beta testing, but found a "feature" in some of the YREG functions that I lifted from Angel's work. Angel has supplied the fixes, but since there is no room in the MAXX ROM I need to replace some code by making changes to the hardware. This is easy to do with FPGA technology, but it means also redoing some of the testing. I have designed the hardware changes but haven't yet started incorporating Angel's software changes. Bottom line: A little longer...
01-02-2024, 10:32 PM
Thanks Monte. I am sure it is worth the wait.
Namir |
01-05-2024, 09:41 AM
Thanks for the update Monte!
Cheers, PeterP |
01-10-2024, 05:21 PM
It means, now (soon) we can buy a cheap second hand HP41C without any module instead an expensive HP41CX? (and just wait Monte parts to buy them).
HP71B 4TH/ASM/Multimod, HP41CV/X/Y & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X |
01-11-2024, 11:56 AM
(This post was last modified: 01-11-2024 11:59 AM by Ángel Martin.)
(01-10-2024 05:21 PM)floppy Wrote: It means, now (soon) we can buy a cheap second hand HP41C without any module instead an expensive HP41CX? (and just wait Monte parts to buy them).it brings the 41C to a 41CV + TIME + X-Fns + 2x X-Mem... + 1024 regs of ExPanded memory. That for me is better than a CX 'AM "To live or die by your own sword one must first learn to wield it aptly." |
01-11-2024, 02:22 PM
(01-11-2024 11:56 AM)Ángel Martin Wrote:+ 12x 4K 10-bit SRAM memory that can hold ROMs and/or be used as QROM.(01-10-2024 05:21 PM)floppy Wrote: It means, now (soon) we can buy a cheap second hand HP41C without any module instead an expensive HP41CX? (and just wait Monte parts to buy them).it brings the 41C to a 41CV + TIME + X-Fns + 2x X-Mem... + 1024 regs of ExPanded memory. Sylvain Côté |
01-11-2024, 03:07 PM
I cant wait.
Cheers, PeterP |
01-11-2024, 04:44 PM
Oh. Its means we have a new HP41 business cartell situation? :-)
- Diego is making battery systems - Monte is making MAXX (which overtake the Nov64d content?) .. Or lets be nicer in my question: how are Diego Nov64d/clonix interacting with the MAXX in the same machine? HP71B 4TH/ASM/Multimod, HP41CV/X/Y & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X |
01-11-2024, 06:36 PM
(01-11-2024 04:44 PM)floppy Wrote: Or lets be nicer in my question: how are Diego Nov64d/clonix interacting with the MAXX in the same machine? As far as I understand they have some overlap on functionality, with the MAXX being a superset. It also represents a great alternative for those like myself that are late to the MLDL party. I've been learning MCODE trying things out on V41, really antsy to try it out in the real thing! |
01-12-2024, 08:56 PM
(This post was last modified: 01-14-2024 12:35 PM by Sylvain Cote.)
(01-11-2024 04:44 PM)floppy Wrote: Oh. Its means we have a new HP41 business cartell situation? :-)Available hardware:
(01-11-2024 04:44 PM)floppy Wrote: Or lets be nicer in my question: how are Diego Nov64d/clonix interacting with the MAXX in the same machine?Perfectly, use BOTH ! (Clonix-D + MAXX) or (NoV-64d + MAXX) Diego modules are fantastic for holding ROM modules and the NoV-64d has the best HEPAX emulation. While Monte MAXX module is first and foremost a system module that
edit 1: small correction on Diego module spec. edit 2: last paragraph Sylvain Côté |
01-14-2024, 06:55 PM
(This post was last modified: 01-17-2024 04:42 PM by Sylvain Cote.)
Example showing how to load and use the RAMBox32 ROM image with the MAXX module.
Hardware/Software needed:
edit: reformating Sylvain Côté |
01-19-2024, 12:35 PM
Would love to pre-order; pre-fund this effort. Half nut CX that I rescued from the trash needs to be rewarded for surviving battery corrosion and neglect. The CL is appealing but still on the hunt for a donor that’s a good candidate.
04-01-2024, 07:19 AM
Hi Monte, have you worked out pricing yet?
I'm in Australia so international shipping estimate would be good to know too. Thanks (01-02-2024 08:36 PM)Monte Dalrymple Wrote: Sylvain finished his beta testing, but found a "feature" in some of the YREG functions that I lifted from Angel's work. Angel has supplied the fixes, but since there is no room in the MAXX ROM I need to replace some code by making changes to the hardware. This is easy to do with FPGA technology, but it means also redoing some of the testing. I have designed the hardware changes but haven't yet started incorporating Angel's software changes. Bottom line: A little longer... Calculator Clique on YouTube |
04-01-2024, 05:00 PM
(04-01-2024 07:19 AM)dmh Wrote: Hi Monte, have you worked out pricing yet?MAXX is $135 if you supply a module housing, $155 if not. With international shipping what it is, it doesn't make sense for international customers to try to supply the module housing. Shipping to Australia is $23 for First Class and $48 for Priority Mail. UPS and FEDEX are slightly more expensive than Priority Mail. I am waiting the final go-ahead from Sylvain's testing. Monte |
04-01-2024, 05:24 PM
(This post was last modified: 04-01-2024 06:38 PM by Sylvain Cote.)
(04-01-2024 05:00 PM)Monte Dalrymple Wrote: I am waiting the final go-ahead from Sylvain's testing.Arrggg .... available free time and priorities. Diego testing is done for now, still need to report the result to him though. Meindert project is on hold, so building a breadboard test setup for his upcoming module can wait a bit. Mike is waiting for his NoV module, so his configuration can also wait. Putting you back on top. HEPAX works, edge cases still need to be tested, we are almost there. Monte, have you fix the issue I have found several weeks ago ? Sylvain Côté |
04-01-2024, 07:37 PM
(This post was last modified: 04-01-2024 07:38 PM by Monte Dalrymple.)
(04-01-2024 05:24 PM)Sylvain Cote Wrote:Sylvain, no need to do that. I am trying to get the batch of 41CL boards ready right now anyway. I think I have fixed everything. Which issue are you referring to?(04-01-2024 05:00 PM)Monte Dalrymple Wrote: I am waiting the final go-ahead from Sylvain's testing.Arrggg .... available free time and priorities. |
