SERIOUS PROBLEM WITH THE 41CL ***SOLVED***
03-27-2024, 09:12 AM
(This post was last modified: 03-28-2024 10:18 AM by yann.)
Hi, I just updated the 41CL to the new rom_files_240325.zip.
The entire update did not cause any kind of problems. I upgrade using the 9PRG MMU, which contains the YUPS module. Once the update is finished, I try to go back to my 9CFA: I run XEQ MMUDIS The "terrible answer" I get is NON EXISTENT. I think the update had a problem and I run XEQ YRES, hoping to get a basic system, but as soon as I try to install YFNX, here is the real "cold shower": the answer I get is NO IMDB!!! How can I solve this problem? Thank you very much! |
03-27-2024, 10:21 PM
RE: SERIOUS PROBLEM WITH THE 41CL
How are you installing YFNX, with PLUG1U? Did you try an MMU clear?
from my notes: Code:
Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
03-27-2024, 11:34 PM
Hello Yann,
(03-27-2024 09:12 AM)yann Wrote: Hi, I just updated the 41CL to the new rom_files_240325.zip.I just updated one of my 41CLv5 to the same version as you and I get the same result. It seems that there is a problem with the latest IMDB.ROM file, I will post a workaround soon. Sylvain Sylvain Côté |
03-28-2024, 12:10 AM
(This post was last modified: 03-28-2024 10:40 AM by Sylvain Cote.)
Hello Yann,
The following procedure will downgrade your 41CL to the 2024-03-05 package.
edit: typos Sylvain Côté |
03-28-2024, 02:52 AM
I just uploaded a revised rom_files_240325.zip with IMDB.ROM and IMDB_V2.ROM repaired. It "should" be okay now. Sorry about that. It has been a while since I edited the image database and I accidentally made a bad edit.
03-28-2024, 08:14 AM
Many thanks for your help. Everything went well.
Only little problem, I didn't find the CDEXP instruction, but the CDBEXP instruction and I used it. Unfortunately in an attempt to solve the problem, before asking you for help, I sent the 41CL to memory clear, so now I have to reinstall everything! But I'm happy to see that even problems that seem difficult to solve are solved quite easily on 41CL!!! With best regards. Yann |
03-28-2024, 10:17 AM
This is just to let you know that I updated my 41CL to rom_files_240325.zip without any problem!
Thanks again for the help. Yann |
03-28-2024, 10:40 AM
RE: SERIOUS PROBLEM WITH THE 41CL ***SOLVED***
(03-28-2024 08:14 AM)yann Wrote: Many thanks for your help. Everything went well.Great! (03-28-2024 08:14 AM)yann Wrote: Only little problem, I didn't find the CDEXP instruction, but the CDBEXP instruction and I used it.Sorry for the typo, but you found the instruction I meant. Sylvain Côté |
