SERIOUS PROBLEM WITH THE 41CL ***SOLVED***
03-27-2024, 09:12 AM (This post was last modified: 03-28-2024 10:18 AM by yann.)
Hi, I just updated the 41CL to the new rom_files_240325.zip.
The entire update did not cause any kind of problems.
I upgrade using the 9PRG MMU, which contains the YUPS module.
Once the update is finished, I try to go back to my 9CFA:
I run XEQ MMUDIS
The "terrible answer" I get is NON EXISTENT.
I think the update had a problem and I run XEQ YRES,
hoping to get a basic system, but as soon as I try to install YFNX, here is the real "cold shower":
the answer I get is NO IMDB!!!
How can I solve this problem?
Thank you very much!
03-27-2024, 10:21 PM
RE: SERIOUS PROBLEM WITH THE 41CL
How are you installing YFNX, with PLUG1U? Did you try an MMU clear?
from my notes:
XEQ YRES             # disable MMU; from TMOD
XEQ MMU?             # ensure MMU is disabled; if not, try backspace-ON and repeat
XEQ MMUCLR           # initialise MMU registers in RAM
"YFNX" XEQ PLUG1U    # plug YFNX to port 1 upper, page 9
XEQ MMUEN            # enable MMU
XEG PLUG
   ?IMG ?            # check ROM page layout; should show: YFNX 9
Cambridge, UK
Casio, Rockwell 18R
03-27-2024, 11:34 PM
Hello Yann,
(03-27-2024 09:12 AM)yann Wrote:  Hi, I just updated the 41CL to the new rom_files_240325.zip.
... but as soon as I try to install YFNX, here is the real "cold shower": the answer I get is NO IMDB!!!
I just updated one of my 41CLv5 to the same version as you and I get the same result.
It seems that there is a problem with the latest IMDB.ROM file, I will post a workaround soon.
Sylvain
Sylvain Côté
03-28-2024, 12:10 AM (This post was last modified: 03-28-2024 10:40 AM by Sylvain Cote.)
Hello Yann,
The following procedure will downgrade your 41CL to the 2024-03-05 package.
  • 41CL Calculator Manual, section "Plug into Port/Unplug from Port Functions" (p.24 to p29) describe how to map a ROM image with its page address
  • 41CL Memory Reference allow you to map the IMDB ID to/from its Flash page address
  • download the previous archive file: rom_files_240305.zip
  • plug the serial port between the 41CL and your computer
  • start the clupdate program with the previous archive file (rom_files_240305.zip)
  • 41CL: configure without IMDB
    MMUDIS
    MMUCLR
    "00A-RAM"   // YFNX address in Flash
    PLUG1L
    "062-RAM"   // YUPS address in Flash
    PLUG1U
    MMUEN
    CAT 2       // ... "-YFNX 4C" ... "UPDAT 4D" ...
  • 41CL: downgrade
    CMOPEN
    CPONLY
    FLCHK?
    FLUPD
    CDBEXP      // update list should be empty
    CMCLOSE
  • 41CL: validation & cleanup
    FDBVER?     // 03/05/2024
    CDBDEL
    MMUDIS
    MMUCLR
  • PLUG functions should now works with IMDB names
Sylvain
edit: typos
Sylvain Côté
03-28-2024, 02:52 AM
I just uploaded a revised rom_files_240325.zip with IMDB.ROM and IMDB_V2.ROM repaired. It "should" be okay now. Sorry about that. It has been a while since I edited the image database and I accidentally made a bad edit.
03-28-2024, 08:14 AM
Many thanks for your help. Everything went well.
Only little problem, I didn't find the CDEXP instruction, but the CDBEXP instruction and I used it.
Unfortunately in an attempt to solve the problem, before asking you for help, I sent the 41CL to memory clear, so now I have to reinstall everything! But I'm happy to see that even problems that seem difficult to solve are solved quite easily on 41CL!!!
With best regards.
Yann
03-28-2024, 10:17 AM
This is just to let you know that I updated my 41CL to rom_files_240325.zip without any problem!
Thanks again for the help.
Yann
03-28-2024, 10:40 AM
RE: SERIOUS PROBLEM WITH THE 41CL ***SOLVED***
(03-28-2024 08:14 AM)yann Wrote:  Many thanks for your help. Everything went well.
Great!
(03-28-2024 08:14 AM)yann Wrote:  Only little problem, I didn't find the CDEXP instruction, but the CDBEXP instruction and I used it.
Sorry for the typo, but you found the instruction I meant.
Sylvain Côté
