HP97 The journey begins
03-10-2024, 02:58 AM
(This post was last modified: 03-10-2024 02:59 AM by teenix.)
Post: #781
RE: HP97 The journey begins
Just taking advantage of one of the new program steps working on the Woodstock board with the HP-29 running. https://teenix.org/msg29c.mp4 cheers Tony |
03-20-2024, 02:44 AM
(This post was last modified: 03-20-2024 07:44 AM by teenix.)
Post: #782
Almost there, just have to check the battery charger. The LED display will give an indication when the battery is being charged. Edit. Just added an image showing the USB cable connected which is running the calculator and charging the battery. Charge indication is the mantissa sign digit, segment D lit. cheers Tony |
03-20-2024, 09:33 AM
Post: #783
Hi Tony
it is good news! one question about the battery, Can I use AA size battery x2 in original battery case of wookstock (V1.2 DC x2) ? Thanks! |
03-20-2024, 10:32 AM
(This post was last modified: 03-20-2024 10:33 AM by teenix.)
Post: #784
(03-20-2024 09:33 AM)zixingcheche Wrote: one question about the battery, Can I use AA size battery x2 in original battery case of wookstock (V1.2 DC x2) ? The cpu board does not use a step up voltage circuit. It was designed for the small LiPo battery which outputs around 4V, 800mAh, model No. 802540. cheers Tony |
03-20-2024, 11:09 AM
Post: #785
Understood. It is same as spice CPU, right?
03-20-2024, 11:13 AM
Post: #786
04-07-2024, 03:56 AM
Post: #787
A bit of a mishap. I manage to accidently short the circuit board while fiddling with it and got a few puffs of smoke and a dead board. I rebuilt a new one and while fiddling some more, the board stopped responding to the communications channel. Then it worked, but the re-flash failed. It is a bit frustrating trying to figure out the problem, new board, bad part, solder joint, software bug etc etc. After some more fiddling, it turned out the battery was discharged enough to get the processor to reset occasionally. What threw me was the display was still working. Then I thought: why wasn't the low battery indicator working. It was just a tweak of the programmable reference setting. Anyway, the battery was put on charge and it now works. The charge LED shows through the main display window. I added a printer interface to the 29C model which sends print data to the PC via Bluetooth and the CalCom program will print the info using the original printer font style similar to the 19C. You can also print a hard copy as well. The attached image shows Dave Eatons USB cable plugged into the Woodstock charger port and the print output of a small running program. Hopefully just some final testing then done. cheers Tony |
04-07-2024, 06:33 AM
Post: #788
Reassembled Woodstock battery pack with LiPo installed.
04-07-2024, 02:03 PM
Post: #789
Good news.
Is it possible to add spice series ROM? The key number is the same and just add an overlay. HP35 HP45 HP55 HP65 HP67 HP21 HP25 HP29C HP19C HP97 HP10C HP11C HP12C HP15C HP16C HP31E HP32E HP33E HP33C HP34C HP37E HP38E HP38C HP41 |
04-07-2024, 07:54 PM
Post: #790
04-08-2024, 12:14 AM
Post: #791
Hmmm, no smoke lately, might be finished :-)
Greeting screen if it works ok when first assembled. cheers Tony |
04-20-2024, 12:03 PM
Post: #792
I added a Black Jack (aka 21) game to the Woodstock CPU board. It might while away an hour or two of otherwise boredom. Pesky processor thinks it can win all the time, but it can't :-) I have just put it back on charge after 2 weeks of almost daily development time. cheers Tony |
04-20-2024, 10:58 PM
Post: #793
Mike T. HP21, HP25, HP32E, HP33C, HP34C, HP10C, HP11C, HP12C, HP32S, HP22S |
04-21-2024, 04:50 AM
(This post was last modified: 04-21-2024 04:52 AM by teenix.)
Post: #794
I got a game similar to Tetris going on the Woodstock board too. It's probably the first time ever that a Woodstock has played the Tetris tune :-) It's a bit squeaky because of the tiny Piezo transducer but the notes and timing are correct, and of course, it can be turned off. cheers Tony |
04-21-2024, 12:03 PM
Post: #795
If you're going to have Woodstock sounds, I'm afraid you'll have to have it play "Foxy Lady" like Hendrix did at Woodstock. It's just a must do...
--Bob Prosperi |
04-21-2024, 01:15 PM
Post: #796
(04-21-2024 12:03 PM)rprosperi Wrote: If you're going to have Woodstock sounds, I'm afraid you'll have to have it play "Foxy Lady" like Hendrix did at Woodstock. It's just a must do... ![]() Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
04-22-2024, 12:19 AM
Post: #797
(04-21-2024 12:03 PM)rprosperi Wrote: If you're going to have Woodstock sounds, I'm afraid you'll have to have it play "Foxy Lady" like Hendrix did at Woodstock. It's just a must do... That'd be cool, but I don't think the little peeper of a sound generator would do it justice, probably like Hendrix on a ukulele :-) |
04-22-2024, 11:48 AM
Post: #798
(04-22-2024 12:19 AM)teenix Wrote:(04-21-2024 12:03 PM)rprosperi Wrote: If you're going to have Woodstock sounds, I'm afraid you'll have to have it play "Foxy Lady" like Hendrix did at Woodstock. It's just a must do... A steep hill to be sure, I'll assume the folks making the sound generator never imagined such a challenge. As for music, I'd probably prefer Hendrix on a ukulele over much of today's music. Gotta run, I need to go tell some kids to get off my lawn... --Bob Prosperi |
04-25-2024, 06:01 AM
(This post was last modified: 04-25-2024 06:04 AM by teenix.)
Post: #799
It looks like the Woodstock is finally done, except for bugs no doubt ;-). Here are its features... Supported models HP-21, HP-22, HP-25C, HP-27, HP-29C Continuous Memory storage for all models - requires no battery power Storage: HP-25C, 207 program files. HP29C, 360 files, either program or data Continuous memory has reset Bluetooth connectivity Internal USB battery charger with charge indicator, can run calculator as well LiPo battery powered Selectable low battery reference Constant current LED driver Text editor for creating names for stored programs Turbo Mode, fast code execution Decimal/Binary/Hex/Octal convertor Option to display program text instead of original key numbers Real time clock with alarm, +/- 5 PPM Separate count up and count down timers with alarm Selectable DDMMYY, MMDDYY, YYMMDD or Text date format Clock display in numeric or text format - 5 Past 3, 29 to 11, Noon, etc Menu activated right switch (in case user's model does not have one) Selectable key de-bounce Beeper - selectable Off, Loud or Soft Display setting – Bright or Dim 29C printer interface via Bluetooth link to PC - NRM or TRC modes, font is same as 97 Power on model display Temperature display Version display 3 extra programmable functions for the HP-25C -Beep -GSB 49 - RTN 6 extra programmable functions for the HP-29C -Random Number -Constants -Beep -Data Swap -File access - load programs or load/save data files (similar to 67/97) - Notes Display PC interface for transferring options and programs Compatible with Teenix Woodstock emulator Reprogrammable via Bluetooth, USB Serial Port Module or PIC ICSP programmer 2 inbuilt games, Tetris and 21 with music and sound effects I'll try to get it on the web page in the next day or so. cheers Tony |
04-25-2024, 12:11 PM
Post: #800
WOW!!
I've been following this thru its gestation, but honestly missed or forgotten some of the features, or some smaller details of features, but this is quite amazing, Tony, very well done!! A couple questions: A. Why does the 25C support fewer program files than the 29C? Given the same platform, one would think they could support the same. Unless simply because the 25C was less capable than a 29C and that's how things must be, which I could understand and support. B. Can the original power adapter be used to charge the LiPo battery and operate the device? C. Does the new battery fit in an original, or 3D printed equivalent, battery pac? D. Purpose of new GSB 49 instruction? E. It appears installation consists of simply opening the unit, replacing the old board with the new one, and reassembling, is that correct? Looking forward to one of these... --Bob Prosperi |
