Report problems with CAS and its interface.
04-02-2024, 01:46 PM
(This post was last modified: 04-08-2024 11:19 PM by compsystems.)
Hello, CAS operation on hp-prime is not synchronized with the system GUI. I will report these problematic situations in this thread.
We hope that there can be a work team that can solve these problems. 1: When entering the following algebraic expression it works fine, but when retrieving the input expression in the input expressions line, certain arguments are not printed legibly because there is a vertical offset in the arguments. a*x^2+b*x+c | (a = -6,b = -4,c = 2) [ENTER] returns -6*x^2-4*x+2 everything on the left side of the symbolic operator | It is considered the expression to be evaluated and everything on the right side is the values of the substitution. ![]() 2: The following situation happens very rarely When executing the following algebraic expression, the exact coeficient numbers are changed to decimal numbers, that is, a point is added. subst(a*x^2+b*x+c,[a = -6,b = -4,c = 2]) [ENTER] returns -6*x^2-4*x+2 Run it a few times and you will most likely see the following: -6. *x^2 -4. *x + 2.0 ![]() |
04-07-2024, 03:51 AM
RE: Report problems with CAS and its interface.
3: The (-) sign is not centered with respect to the horizontal division bar.
04-08-2024, 01:27 PM
Try the other operator. The prime has *2* negation operators. The "minus" and unary minus as selected by the +/- key.
The size and vertical justification are used to tell them apart. |
04-08-2024, 08:15 PM
It is good to differentiate them at the input, but by signal law at the output they must align with the horizontal bar of the division,
04-08-2024, 08:25 PM
When you copy symbols to the character input line, the bottom part is hidden.
![]() Another improvement would be to store the last position of the scanned character when the character table is reopened. |
04-08-2024, 09:39 PM
(04-02-2024 01:46 PM)compsystems Wrote: 1: When entering the following algebraic expression it works fine, but when retrieving the input expression in the input expressions line, certain arguments are not printed legibly because there is a vertical offset in the arguments. The Where function requires a list for multiple variables. Use this: a*x^2+b*x+c|({a = -6,b = -4,c = 2} instead of this: (a*x^2+b*x+c) | (a = -6,b = -4,c = 2) and that behavior is not observed. -road |
04-08-2024, 11:33 PM
The following input statement is interpreted as everything to the left of the operator | is the input expression and everything to the right is the substitutions
a*x^2+b*x+c | a=-6,b=-4,c=2 [Enter] -6*x^2-4*x+2 ok with curved parentheses should be enough a*x^2+b*x+c | (a=-6,b=-4,c=2) [Enter] -6*x^2-4*x+2 ok or (a*x^2+b*x+c) | (a=-6,b=-4,c=2) [Enter] -6*x^2-4*x+2 ok |
04-18-2024, 01:02 AM
(04-02-2024 01:46 PM)compsystems Wrote: Hello, CAS operation on hp-prime is not synchronized with the system GUI. I will report these problematic situations in this thread. Thanks! I thought I'd try to add some comments from this thread to the bug tracker I've set up. Quote:⋮ I've tried to recreate this on both HP Prime Virtual Calculators and on a physical HP Prime, with a variety of different settings for Entry mode and Simplification, but could not reproduce it. While writing this post (after writing the sentence just before this one), I did try the above subst, but with an "a" variable set to "-6.", and then (repeatedly) got the -6. in the output. Some more information might help. Are you seeing this with behaviour with the latest public release (2.1.14732 (2023 04 21))? (Does it occur even with a completely fresh / blank calculator?) |
04-18-2024, 07:51 AM
RE: Report problems with CAS and its interface. | |||
04-18-2024, 08:04 AM
(This post was last modified: 04-18-2024 08:05 AM by parisse.)
subst does not quote it's arguments, therefore if a is assigned say to 2
subst(a*x^2+b*x+c,[a = -6,b = -4,c = 2]) will eval a*x^2+b*x+c to 2*x^2+b*x+c, as well as a=-6 to 2=-6, and a will not be replaced by -6. A warning is displayed in the terminal. |
04-19-2024, 12:51 AM
In HP-Prime, sometimes the outputs, integers, have a dot added.
Another problem is that when there is an expression in the input line, and if you later go to the [help] menu and search for something, when you return the expression in the input line is cut off. ![]() |
04-20-2024, 06:29 AM
(This post was last modified: 04-21-2024 08:33 AM by komame.)
(04-08-2024 08:25 PM)compsystems Wrote: When you copy symbols to the character input line, the bottom part is hidden. I managed to reproduce this issue. It's related to the font size settings in Home Settings on page 2. This issue affects every edit field (anywhere, in any view/application where edit fields are present) when the font is set to "Small Font". For the other font sizes, the problem does not occur. (04-19-2024 12:51 AM)compsystems Wrote: In HP-Prime, sometimes the outputs, integers, have a dot added. I managed to reproduce this bug as well. I've filed a ticket for this issue in the bug tracker. Piotr Kowalewski |
04-26-2024, 03:28 PM
(04-20-2024 06:29 AM)komame Wrote: [...] I've filed a ticket for this issue in the bug tracker. ..and the bug got fixed! ![]() Thank you, Jeff. Piotr Kowalewski |
05-02-2024, 11:51 AM
Hello
When typing '(x^m)^n^p' and executing the input, and then retrieving it on the input line of the expression, when trying to step down from the exponent 'n' to include a parenthesis, the cursor location jumps to the end of the expression, it must be located before the variable 'p' not after '(x^m)^n|^p' => '(x^m)^n^p|' ![]() |
05-02-2024, 11:57 AM
(This post was last modified: 05-02-2024 12:27 PM by compsystems.)
Hello
Typing (x^m)^n:; and executing the input, then retrieving it on the input line of the expression and executing it again does not interpret the nodisp() function The nodisp() function is synonymous with ( :; ), that is, it does not display the result of the input. ![]() |
05-02-2024, 02:14 PM
05-02-2024, 05:34 PM
This is not the only function that is not well interpreted, there are several similar ones.
05-12-2024, 02:52 AM
(05-02-2024 11:51 AM)compsystems Wrote: Hello A similar sort of issue arises if one enters 1^2^3 and then tries to select the 1^2 portion. It is fairly typical for equation editors to apply / enforce / create / assume some structure to the input that is not visibly shown (e.g., with 1^2^3 there could be a tree structure in memory; the top node being "^" with a left child node of "1" and a right child node of "2^3"). I’m glad the the HP Prime editor does less of this than some editors I’ve experienced. If one instead enters (1^2)^3 and then removes the parentheses, one can then reinsert them around the 1^2 (the top "^" node has "1^2" as the left child and "3" as the right child). (With this structure, selecting and copying the visible 2^3 ends up copying "^2^3".) Note that this equation editor structure does not override evaluation rules (one can try 3^3^3 with both editing structure — direct entry and by entering (3^3)^3 and then removing the parentheses). Playing around with this just now, I do see something I’ll add to the bug tracker. (Enter "(1^2)" and then delete just the "1".) |
05-25-2024, 03:18 PM
Sometimes the TRUE/FALSE logic output is set to a numeric value, creating confusion.
05-29-2024, 08:54 PM
An improvement in the graphic engine:
The cursor should change color not only in the intersection, but also in all its shape, because it is not well displayed (it is almost hidden). ![]() |
