Viète à grande Vitesse or Accelerated Viète (kind of)
06-23-2024, 06:00 PM
RE: Viète à grande Vitesse or Accelerated Viète (kind of)
(06-23-2024 03:00 AM)Gerson W. Barbosa Wrote:  \(\pi \approx \pi{'} \left[1+\frac{1}{6}\left(\frac{\pi{'}}{2^{n+1} }\right)^2\right]\left[1+\frac{3}{40}\left(\frac{\pi{'}}{2^{n+1} }\right)^4\right]\left[1+\frac{9}{280}\left(\frac{\pi{'}}{2^{n+1} }\right)^6\right] \)
Correction factor had error of O(z^8), where z=pi'/2^(n+1)
If we use Horner's scheme, we might as well use correct z^8 coefficient.
It made code shorter (less terms), also more accurate, error = O(z^10)
XCas> expand( (1+1/6*z^2) * (1+3/40*z^4) * (1+9/280*z^6) )
1 + 1/6*z^2 + 3/40*z^4 + 5/112*z^6 + 3/560*z^8 + 27/11200*z^10 + 9/22400*z^12
Replaced this with asin(z)/z, upto z^8 only
XCas> expand( 1+1/6*z^2 * (1+3²/(4*5)*z^2 * (1+5²/(6*7)*z^2 * (1+7²/(8*9)*z^2))) )
1 +1/6*z^2 + 3/40*z^4 + 5/112*z^6 + 35/1152*z^8
To make code stack-only, we can't store n, and had to recover 2^(n+1) factor.
Code was using 2^(n+1) = IP((355/113)/z), but this will fail if n is too big.
Instead, I use log to recover n from z (Yes, this is stupid, all we need is to store n)
z = pi' / 2^(n+1)
log2(z) = log2(pi') - (n+1)
-(n+1) ≈ log2(z) - 1.6515
-(n+1) = IP(log2(z)) - 2
n=1 --> IP(log2(z)) - 2 = IP(-0.50) - 2 = -2
n=9 --> IP(log2(z)) - 2 = IP(-8.35) - 2 = -10
n=99 --> IP(log2(z)) - 2 = IP(-98.35) - 2 = -100
n=999 --> IP(log2(z)) - 2 = IP(-998.35) - 2 = -1000
00 { 79-Byte Prgm }
01▸LBL "Vh"
02 2
03 0
04 SIGN
05▸LBL 00
06 2
07 STO× ST Z
08 RCL+ ST L
09 SQRT
10 ×
11 DSE ST Z
12 GTO 00
13 1/X          @ z = sin(pi/2^(n+1)) = pi'/2^(n+1)
14 X↑2
15 ENTER
16 ENTER
17 ENTER
18 49
19 ×
20 72
21 ÷
22 ×
23 +
24 25
25 ×
26 42
27 ÷
28 ×
29 +
30 .45
31 ×
32 ×
33 +
34 6
35 ÷            @ eps ≈ asin(z)/z - 1
36 X<>Y
37 SQRT
38 ENTER
39 LN           @ ln(z)   z   eps
40 2
41 LN
42 ÷            @ log2(z) z   eps   eps
43 IP
44 2
45 -
46 LASTX
47 X<>Y
48 Y↑X
49 ÷            @ pi'   eps   eps   eps
50 ×
51 LASTX
52 +
53 END
  1 XEQ "Vh" --> 3.138316846974900201597524772067293
10 XEQ "Vh" --> 3.141592653589793238462643383274432
11 XEQ "Vh" --> 3.141592653589793238462643383279499
12 XEQ "Vh" --> 3.141592653589793238462643383279504
06-24-2024, 09:42 PM
I could have used up to four correction terms in the format I’ve been using, but I have used only three as I wanted to compare the results with those of another program using COMB, as that one is limited to only three factors. But my program would be even longer, so it’s great to know there’s a way to do it more compactly.
(06-23-2024 06:00 PM)Albert Chan Wrote:  To make code stack-only, we can't store n, and had to recover 2^(n+1) factor.
z = pi' / 2^(n+1)
IP((355/113)/z) works for the small n we would need for maximum accuracy, 14 or 15 in my example with three factors. This starts to fail at n=23. Also, if more factors are used even less iterations are required (11 or 12 in your example).
00 { 79-Byte Prgm }
01▸LBL "Vh"
02 2
03 0
04 SIGN
05▸LBL 00
06 2
07 STO× ST Z
08 RCL+ ST L
09 SQRT
10 ×
11 DSE ST Z
12 GTO 00
14 X↑2
15 ENTER
16 ENTER
17 ENTER
18 49
19 ×
20 72
21 ÷
22 ×
23 +
24 25
25 ×
26 42
27 ÷
28 ×
29 +
30 .45
31 ×
32 ×
33 +
34 6
36 X<>Y
37 SQRT
38 ENTER
39 LN           @ ln(z)   z   eps
40 2
41 LN
43 IP
44 2
45 -
46 LASTX
47 X<>Y
48 Y↑X
50 ×
51 LASTX
52 +
53 END
I don’t understand why one would want to run this for n=10000+ on Free 42. You code would be even more compact if is limited to 20 or so. Anyway, if that is desired you can save at least one more step. They say engineers round \(\pi\) to 4 just in case. Being an engineer, that’s exactly what I have done at step 42 :-)
00 { 79-Byte Prgm }
01▸LBL "VH"
02 2
03 0
04 SIGN
05▸LBL 00
06 2
07 STO× ST Z
08 RCL+ ST L
09 SQRT
10 ×
11 DSE ST Z
12 GTO 00
13 1/X
14 X↑2
15 ENTER
16 ENTER
17 ENTER
18 49
19 ×
20 72
21 ÷
22 ×
23 +
24 25
25 ×
26 42
27 ÷
28 ×
29 +
30 .45
31 ×
32 ×
33 +
34 6
35 ÷
36 LN1+X
37 E↑X
38 X<>Y
39 SQRT
40 ×
41 2
42 4             @ pi ~ 4
43 LASTX
44 ÷
45 LN
46 2
47 LN
48 ÷
49 IP
50 Y↑X
51 ×
52 END
06-25-2024, 12:41 AM
(06-24-2024 09:42 PM)Gerson W. Barbosa Wrote:  They say engineers round \(\pi\) to 4 just in case.
pi = 4 ... and it actually work! Big Grin
Turns out I don't need to recover 2^(n+1). It was already there!
This version is going for simplicity, which turns out pretty good.
ε = asin(z)/z - 1 ≈ z^2/6 / (1 - 9/20*z^2) = 1 / (6/z^2 - 2.7)
00 { 38-Byte Prgm }
01▸LBL "Vh"
02 2
03 0
04 SIGN
05▸LBL 00
06 2
07 STO× ST Z
08 RCL+ ST L
09 SQRT
10 ×
11 DSE ST Z
12 GTO 00       @ 1/z     2^(n+1)
13 ÷
14 2.7
15 6
16 LASTX        @ 1/z     6     2.7   pi'
17 X↑2
18 ×
19 -            @ -1/eps  pi'   pi'   pi'
20 ÷
21 -
22 END
1   --> 3.132559073643629893044600829969869
17 --> 3.141592653589793238462643383279402
18 --> 3.141592653589793238462643383279501
19 --> 3.141592653589793238462643383279502
06-25-2024, 01:19 PM
(06-25-2024 12:41 AM)Albert Chan Wrote:  [quote='Gerson W. Barbosa' pid='188722' dateline='1719265376']
05▸LBL 00
06 2
07 STO× ST Z
08 RCL+ ST L
09 SQRT
10 ×
11 DSE ST Z
13 …
Yes, except that it is difficult to use it when we need all the stack for something else afterwards. Unless, of course, we use a numbered register, as in Vh and Vf below. The latter uses a formula to generate the coefficients in the format (1 + n/d), but this works only for the three first coefficients.
00 { 92-Byte Prgm }
01▸LBL "Vh"
02 2
03 0
04 SIGN
05▸LBL 00
06 2
07 STO× ST Z
08 RCL+ ST L
09 SQRT
10 ×
11 DSE ST Z
12 GTO 00
13 1/X
14 ×
15 STO 01
16 LASTX
17 X↑2
18 ENTER
19 ENTER
20 ENTER
21 9
22 ×
23 22400
24 ÷
25 27
26 11200
27 ÷
28 +
29 ×
30 3
31 560
32 ÷
33 +
34 ×
35 5
36 112
37 ÷
38 +
39 ×
40 3
41 40
42 ÷
43 +
44 ×
45 6
46 1/X
47 +
48 ×
49 1
50 +
51 RCL× 01
52 END
00 { 85-Byte Prgm }
01▸LBL "Vf"
02 2
03 0
04 SIGN
05▸LBL 00
06 2
07 STO× ST Z
08 RCL+ ST L
09 SQRT
10 ×
11 DSE ST Z
12 GTO 00
13 1/X
14 ×
15 STO 01
16 LASTX
17 X↑2
18 3
19▸LBL 01
20 X<>Y
21 3
22 RCL ST Z
23 +/-
24 NOT
25 Y↑X
26 RCL ST Y
27 R↑
28 Y↑X
29 STO× ST Y
30 CLX
31 2
32 LASTX
33 Y↑X
34 STO÷ ST Y
35 X<> ST L
36 ENTER
37 SIGN
38 STO+ ST Y
39 X<> ST L
40 STO+ ST Y
41 COMB
42 STO÷ ST Y
43 R↓
44 LASTX
45 SIGN
46 STO+ ST Y
47 R↓
48 STO× 01
49 X<> ST L
50 DSE ST X
51 GTO 01
52 X<> 01
53 END
06-25-2024, 02:46 PM
(06-25-2024 12:41 AM)Albert Chan Wrote:  This version is going for simplicity, which turns out pretty good.
Here is for next pade approximation
ε = asin(z)/z - 1 ≈ z^2/6 * (1 + 9/20*z^2 / (1 - 25/42*z^2))
ε ≈ (1 + 2.7/(x-25/7)) / x , where x = 6/z^2
00 { 50-Byte Prgm }
01▸LBL "Vh"
02 2
03 0
04 SIGN
05▸LBL 00
06 2
07 STO× ST Z
08 RCL+ ST L
09 SQRT
10 ×
11 DSE ST Z
13 ÷
14 LASTX
15 X↑2
16 6
17 ×            @ x = 6/z^2
18 DUP
19 .28
20 1/X          @ 25/7    x    x    pi'
21 -
22 2.7
23 X<>Y
24 ÷
25 LN1+X
26 E↑X
27 ÷            @ 1/eps   pi'  pi'  pi'
28 ÷
29 +
30 END
13 --> 3.141592653589793238462643383279481
14 --> 3.141592653589793238462643383279502
07-01-2024, 05:49 AM (This post was last modified: 07-01-2024 06:00 AM by Gerson W. Barbosa.)
(06-23-2024 06:00 PM)Albert Chan Wrote:  ...
00 { 79-Byte Prgm }
01▸LBL "Vh"
02 2
03 0
04 SIGN
05▸LBL 00
06 2
07 STO× ST Z
08 RCL+ ST L
09 SQRT
10 ×
11 DSE ST Z
12 GTO 00
14 X↑2
15 ENTER
16 ENTER
17 ENTER
18 49
19 ×
20 72
21 ÷
22 ×
23 +
24 25
25 ×
26 42
27 ÷
28 ×
29 +
30 .45
31 ×
32 ×
33 +
34 6
36 X<>Y
37 SQRT
38 ENTER
39 LN           @ ln(z)   z   eps
40 2
41 LN
43 IP
44 2
45 -
46 LASTX
47 X<>Y
48 Y↑X
50 ×
51 LASTX
52 +
53 END
Same results:
 1 4 XEQ "VCW" --> 3.138316846974900201597524772067292
10 4 XEQ "VCW" --> 3.141592653589793238462643383274435
11 4 XEQ "VCW" --> 3.141592653589793238462643383279500
12 4 XEQ "VCW" --> 3.141592653589793238462643383279504
Now with eight coefficients:
1 8 XEQ "VCW" --> 3.141497389177767990537566794077536
2 8 XEQ "VCW" --> 3.141592652530259569168830657515667
6 8 XEQ "VCW" --> 3.141592653589793238462643383279186
7 8 XEQ "VCW" --> 3.141592653589793238462643383279508
8 8 XEQ "VCW" --> 3.141592653589793238462643383279503
No optimization attempt at this stage. No coin flipping for program label – it looks better this way:-)
Formulae later, if I find a suitable LaTeX editor (tired of editing these by hand).
00 { 108-Byte Prgm }
01▸LBL "VCW"
02 STO 01
03 X<>Y
04 2
05 STO 02
06 0
07 SIGN
08 STO 03
09▸LBL 00
10 2
11 STO× ST Z
12 RCL+ ST L
13 SQRT
14 ×
15 DSE ST Z
16 GTO 00
17 1/X
18 ×
19 X<> 01
20 LASTX
21 X↑2
22 STO 04
23 1ᴇ-3
24 RCL× ST Z
25 1
26 +
27 X<>Y
28 0.5
29▸LBL 01
30 STO+ ST X
31 RCL ST Z
32 IP
33 STO÷ ST Y
34 STO+ ST X
35 +/-
36 NOT
37 ×
38 LASTX
39 SIGN
40 STO+ ST X
41 RCL+ ST L
42 RCL× 02
43 X<>Y
44 RCL÷ ST Y
45 X<>Y
46 X<> ST L
47 X<> ST Z
48 ×
49 STO+ 03
50 X<> ST L
51 RCL× 04
52 X<>Y
53 4
54 STO× 02
55 R↓
56 ISG ST Z
57 GTO 01
58 RCL 01
59 RCL× 03
60 END
Edit to change Subject – this looks indeed accelerated although further tests are still needed.
07-01-2024, 07:53 PM (This post was last modified: 07-03-2024 12:37 PM by Gerson W. Barbosa.)
DECIMAL BASIC PROGRAM
! Accelerated Viète by Chan-Wasicki Method
OPTION ARITHMETIC DECIMAL_HIGH
INPUT  PROMPT "number of decimal digits: ":nd
LET tm = TIME
LET n = CEIL(4/3*SQR(nd))         ! n = number of factors in Viète's Product
LET m = n                         ! m = number of coefficients in the correction polynomial
PRINT "n, m: ";n
LET p = 2
LET s = 0
LET v = 1
FOR k = 1 TO n
   LET s = SQR(2 + s)
   LET v = s*v
   LET p = p + p
NEXT k
LET pv = p/v
LET n = 1
LET w = 1/(v*v)
LET x = w
LET c = 1
LET p = 4
FOR k = 1 TO m
   LET n = 2*n*(2*k - 1)/k         ! n = coefficient numerator
   LET d = p*(2*k + 1)             ! d = coefficient denominator
   LET c = c + n*x/d
   LET x = x*w
   LET p = 4*p
NEXT k
LET r = TIME - tm
LET r$ = STR$(pv*c - INT(pv*c))
PRINT
PRINT STR$(INT(pv*c));
PRINT r$(0:1);
FOR i = 2 TO nd + 1
   PRINT r$(i:i);
   IF MOD((i - 1),10) = 0 THEN PRINT " ";
   IF MOD((i - 1),50) = 0 THEN
      PRINT USING " (%%%%)": i - 1
      PRINT REPEAT$(" ",1 + LEN(STR$(INT(pv*c))));
   END IF
NEXT i
IF MOD (i - 2,50) <> 0  OR nd = 0 THEN PRINT
PRINT
PRINT "Runtime: ";
PRINT  USING "0.##": r;
PRINT " seconds"
END
number of decimal digits: 1000
n, m:  43
3.1415926535 8979323846 2643383279 5028841971 6939937510  (0050)
  5820974944 5923078164 0628620899 8628034825 3421170679  (0100)
  8214808651 3282306647 0938446095 5058223172 5359408128  (0150)
  4811174502 8410270193 8521105559 6446229489 5493038196  (0200)
  4428810975 6659334461 2847564823 3786783165 2712019091  (0250)
  4564856692 3460348610 4543266482 1339360726 0249141273  (0300)
  7245870066 0631558817 4881520920 9628292540 9171536436  (0350)
  7892590360 0113305305 4882046652 1384146951 9415116094  (0400)
  3305727036 5759591953 0921861173 8193261179 3105118548  (0450)
  0744623799 6274956735 1885752724 8912279381 8301194912  (0500)
  9833673362 4406566430 8602139494 6395224737 1907021798  (0550)
  6094370277 0539217176 2931767523 8467481846 7669405132  (0600)
  0005681271 4526356082 7785771342 7577896091 7363717872  (0650)
  1468440901 2249534301 4654958537 1050792279 6892589235  (0700)
  4201995611 2129021960 8640344181 5981362977 4771309960  (0750)
  5187072113 4999999837 2978049951 0597317328 1609631859  (0800)
  5024459455 3469083026 4252230825 3344685035 2619311881  (0850)
  7101000313 7838752886 5875332083 8142061717 7669147303  (0900)
  5982534904 2875546873 1159562863 8823537875 9375195778  (0950)
  1857780532 1712268066 1300192787 6611195909 2164201818  (1000)
Runtime: 0.26 seconds
The last three digits should be 989, but we are here at the limit of DECIMAL BASIC precision.
Like number of iterations for the Viète's Product and the correction polynomial, not sure whether this gives optimal efficiency. Anyway, sublinear convergence rate (the number of iterations depends on the square root of the number of digits).
Edited to fix a typo
For one thousand digits, only 11 iterations of the first loop and 165 of the second loop would suffice. I have added six iterations to the latter as a safety margin for this range. Almost 2.5 times faster. Perhaps not too far from the ideal m/n ratio. The last two digits should be 89.
LET tm = TIME
LET n = CEIL(9/26*SQR(nd))         ! n = number of factors in Viète's Product
LET m = 15*n + 6                   ! m = number of coefficients in the correction polynomial
PRINT "n, m: ";n;m
LET p = 2
LET s = 0
LET v = 1
FOR k = 1 TO n
   LET s = SQR(2 + s)
   LET v = s*v
   LET p = p + p
NEXT k
LET pv = p/v
LET n = 1
LET w = 1/(v*v)
LET x = w
LET c = 1
LET p = 4
FOR k = 1 TO m
   LET c = c + n*x/d
   LET x = x*w
   LET p = 4*p
NEXT k
LET r = TIME - tm
PRINT
PRINT r$(0:1);
FOR i = 2 TO nd + 1
   PRINT r$(i:i);
   END IF
NEXT i
PRINT
PRINT "Runtime: ";
PRINT " seconds"
END
n, m:  11  171
  1857780532 1712268066 1300192787 6611195909 2164201968  (1000)
Runtime: 0.11 seconds
Using a recurrent formula also for the denominator might be better...
PRINT "n, m: ";n;m
LET m = 2*m - 1
LET tm = TIME
LET p = 2
LET s = 0
LET v = 1
FOR k = 1 TO n
   LET s = SQR(2 + s)
   LET v = s*v
   LET p = p + p
NEXT k
LET pv = p/v
LET n = 1                          ! n = coefficient numerator
LET d = 1                          ! d = coefficient denominator
LET w = 1/(v*v)
LET x = w
LET c = 1
FOR k = 1 TO m STEP 2
   LET n = 4*n*k/(k + 1)
   LET d = d*(4*k+8)/k
   LET c = c + n/d*x
   LET x = x*w
NEXT k
LET r = TIME - tm
PRINT
PRINT r$(0:1);
FOR i = 2 TO nd + 1
   PRINT r$(i:i);
   END IF
NEXT i
PRINT
PRINT "Runtime: ";
PRINT " seconds"
END
...and faster!
Runtime: 0.09 seconds
07-01-2024, 08:29 PM
I just realized I had done this before, in Arc SOHCAHTOA method
(03-31-2022 11:07 PM)Albert Chan Wrote:  asinq(x) = 2 * asinq(x/2/(1+sqrt(1-x)))
lua> k, x = 4, .5 -- 4 * asinq(.5) = 4 * pi/4 = pi
lua> FMT = '%g * asinq(%.17g)\n'
lua> for i=1,5 do printf(FMT,k,x); k=k+k; x=0.5*x/(1+sqrt(1-x)) end
4 * asinq(0.5)
8 * asinq(0.14644660940672624)
16 * asinq(0.038060233744356624)
32 * asinq(0.009607359798384776)
64 * asinq(0.0024076366639015569)
Argument inside asinq, x = z^2 in Free42 code. Undo asinq, we have pi
lua> k*sqrt(x) -- = pi', with n=6
3.141277250932773
lua> _ * (1 + x/6*(1 + 9/20*x*(1 + 25/42*x*(1 + 49/72*x))))
3.141592653589793
07-01-2024, 09:05 PM (This post was last modified: 07-01-2024 09:06 PM by Gerson W. Barbosa.)
(07-01-2024 08:29 PM)Albert Chan Wrote:  I just realized I had done this before, in Arc SOHCAHTOA method
Pi day celebrations appear to give these kind of interesting byproducts. In this thread from 2009 started by Egan Ford there’s a link about Vieta Acceleration. It looks quite complicated and his program for 5000 digits requires a lot of memory. I would like to check how the above compares to it.
A good think about the correction polynomial it that its coefficients can be easily determined, what was something I was counting on in order to make it a valid method for computing \(\pi\). Wolfram Alpha returned a formula including COMB(2n, n) for the coefficients, which of course would not be practical for that purpose. I had already quit, when I evaluated the first six or seven such COMBs on the 42S and noticed this pattern:
1 2 3 4 5 6 7 8 9 10
3 6 10 15 21
10 20 35 56
35 70 126
126 252 462
Problem solved!
