MKSA not working as per user guide
01-05-2015, 11:43 AM
Hi
I am trying to use units and according to user guide the following should happen MKSA(8.175_cm/s) returns .08175_m*s–1 But what i get is MKSA(8.175_cm/s) returns 0.08175_m/s Any ideas why it does not sjow correctlu Thanks in advance Bill |
01-05-2015, 12:35 PM
(This post was last modified: 01-05-2015 12:44 PM by Snorre.)
RE: MKSA not working as per user guide
It seems to be just a typo in the manual, fuzzy in several aspects: 1) It should be 0.08175_m*s^-1. 2) When entering in algebraic mode (as the manual suggests) you've to put composite units in parentheses: 8.175_(cm/s). In textbook entry this is auto-done for you. 3) MKSA puts units with negative exponents to the denominator, so 1_(s^-1) becomes 1_(1/s). Maybe it behaved differently in some former firmware version. Luckily the Prime does it right. Don't take the manual too literally. |
01-06-2015, 09:09 PM
Two things are at play here. First, the command did earlier return s^-1 instead of /s in a 2d formatted way. Secondly, when we switched the document source to a different format there were some things like this that were missed.
I've put in the note so hopefully the next manual revision will correct it. Thanks! TW Although I work for HP, the views and opinions I post here are my own. |
01-06-2015, 10:07 PM
(01-06-2015 09:09 PM)Tim Wessman Wrote: Two things are at play here. First, the command did earlier return s^-1 instead of /s in a 2d formatted way. Secondly, when we switched the document source to a different format there were some things like this that were missed. Hi Tim and Snorre Thanks for the answers. Both m/s and m.s-1 and correct in terms of being the same thing. I have looked at the SI Brochure preparrd by BIPM and this shows speed as m/s so what is shown by tje calculayor is correct notation. For reference the SI Brochure can be found at, http://www.bipm.org/en/measurement-units/ Regards Bill |
01-09-2015, 06:43 AM
RE: MKSA not working as per user guide | |||
