Stat 2 Var Syntax error by digit grouping 123'456.789
01-28-2015, 09:43 AM
Hello.
I was trying to fill a column with the "MAKE" command in Statistics 2 Var. If I enter 1000 with the digit grouping set to 123'456.789 the entered value will be 1'000 and the app gives a syntax error. Same problem with digit grouping set to 123,456.789 123 456.789 Same problem with the digital point set to "," if you enter a number like2,3 It seems to work fine only with the digit grouping to 123456.789 I have the same problem with the input of data in programs but only on the emulator. Regards reto |
01-28-2015, 01:07 PM
RE: Stat 2 Var Syntax error by digit grouping 123'456.789
(01-28-2015 09:43 AM)retoa Wrote: I was trying to fill a column with the "MAKE" command in Statistics 2 Var. Dang! I thought we'd caught them all this time... I've put it on the list to look at. Thanks. TW Although I work for HP, the views and opinions I post here are my own. |
