negative number raised to even power
05-04-2015, 08:24 AM
Post: #41
RE: negative number raised to even power
What a waste of time! Just use negadecimal:
http://www.hpmuseum.org/forum/thread-3710.html
05-04-2015, 02:51 PM
Post: #42
(05-04-2015 06:10 AM)Dirk. Wrote:  So how do you explain your students that 2(+/-)² is -4 at the prime when entering it using the keyboard?
It's quite simple, really. Notice that you typed it as "2(+/-)²", which shows that you are assuming that keystroke order should always matter, which is true in RPN... but it does not (and SHOULD not) always matter in command-line calculators (the reason follows shortly). Prime is a command line calculator, and the command line is not evaluated until Enter is pressed. At that time, the order in which the keys were pressed is totally immaterial; the ONLY thing that matters are the rules of parsing the algebraic syntax on the command line. In those rules, "-2²" means "start with 2, square it, then negate the result".
In ANY command-line algebraic-notation calculator which follows standard algebraic notation rules of operator precedence, [2][+/-][x²] yields the same result as [+/-][2][x²], because both key sequences create identical command lines, namely, "-2²", which of course IN STANDARD ALGEBRAIC NOTATION equals -4.
(05-04-2015 06:10 AM)Dirk. Wrote:  In my opinion this is simply a bug which needs to get fixed as soon as possible.
(Sorry for my harsh tone, since I'm German, I can't do better :-) )
I'm half German, so I half understand. But my Irish half wants to write a sad song about how we algebraic users are so often misunderstood. Let's compromise by enjoying some Weihenstephaner Hefeweissbier and Guinness, and let the others fight it out. Smile
<0|ɸ|0>
-Joe-
05-04-2015, 04:18 PM
Post: #43
Well, due to my home, I have to recommend Licher.
But anyway: One of the main points for me is the inconsistency. The calculator behaves differenty when processing a previously calculated result and when entering something leading to the same display. I think the way the algebraic SHARP-Calculators (SHARP EL-512S and SHARP EL-520V) behave is much more consistent.
... and now I'll go out for an Edinger Weißbier :-)
05-04-2015, 08:07 PM
Post: #44
To add to the confusion, even in C/C++, it gets weird:
int a = (-2)^2;
printf("%d", a);
gives -4 as an answer??
But
int a = pow(-2, 2);
printf("%d", a);
gives 4 as an answer
So it seems that precedence rules aren't always followed.
05-05-2015, 05:17 AM
Post: #45
In C/C++, ^ is exclusive or (xor). In C (but not in C++), from C99 onwards, when using the alternative spellings iso646.h header, xor is expanded to ^.
With 2's complement representation of negative numbers:
* the binary representation of -1 is the pattern of 1 (0b11...111 in GCC and Clang for years, C++14 made the 0b syntax standard);
* the binary representation of -2 is 0b11...110;
* the binary representation of 2 is 0b00...010;
* the binary representation of (-2)^2 is therefore 0b11...100, i.e. -4.
05-05-2015, 06:12 PM (This post was last modified: 05-05-2015 06:24 PM by John Colvin.)
Post: #46
(05-05-2015 05:17 AM)debrouxl Wrote:  In C/C++, ^ is exclusive or (xor). In C (but not in C++), from C99 onwards, when using the alternative spellings iso646.h header, xor is expanded to ^.
That explains it. I knew ^ meant xor in the context of boolean operations, but that symbol is used so frequently to represent exponentiation, I just forgot about that quirk C. My bad.
05-05-2015, 07:11 PM
Post: #47
(05-05-2015 06:12 PM)John Colvin Wrote:  That explains it. I knew ^ meant xor in the context of boolean operations, but that symbol is used so frequently to represent exponentiation, I just forgot about that quirk C. My bad.
And I assumed you made a clever joke. Smile
05-05-2015, 07:16 PM
Post: #48
(just for clarification)
But in Standard C++, there's no need to include the header as xor is already a C++ keyword.
05-05-2015, 07:32 PM
Post: #49
I'm really baffled by all the discussion on this issue. Everyone agrees with the following two statements:
1) The square of negative two is four: (-2)^2 = 4 (In 41C rpn: 2 CHS ENTER 2 y^x)
2) The negative of the square of two is negative four: -(2^2) = -4 (In 41C rpn: 2 ENTER 2 y^x CHS)
What people are disagreeing about is the meaning of -2^2. Even though some calculators and computer programs may not follow it, the standard algebra order of operations indicates that exponentiation proceeds negation, so -2^2 means -(2^2) = -4.
05-05-2015, 07:49 PM
Post: #50
I thought the same thing: I wish he hadn't clarified that it was a mistake.
(-2)^2 = -4 was the smartest thing I read in the whole thread! The way it applies to the discussion makes it an excellent joke, could've caught a lot of people off-guard.
05-05-2015, 10:01 PM
Post: #51
(04-26-2015 06:57 PM)Marcus von Cube Wrote:
(04-26-2015 06:22 PM)TASP Wrote:  2
chs
2
chs
y\x
yields 'error'
You are computing (-2)^(-2) (not the original expression!) which is most probably computed as exp(ln(-2)*(-2)). A calculator that only handles real numbers cannot compute ln(-2). Try the x² key instead.
2
chs
2
y\x
The original expression (-2)^2 yields 'error' too on HP-21 and HP-25, however HP-29C computes 4.
2 chs ^ 3 y\x shows -8 and works only for integer exponents (-2)*(-2)*(-2)=-8
Bernhard
05-06-2015, 07:03 AM
Post: #52
(05-05-2015 07:32 PM)Wes Loewer Wrote:  What people are disagreeing about is the meaning of -2^2.
But then 0-2^2 is clear again. It's the missing zero that confuses some people.
05-06-2015, 02:37 PM
Post: #53
I agree that -2^2 = 0-2^2, but someone could argue that these are different as the left side involves negation while the right side involves subtraction, two operators that use similar looking symbols.
I think I've got something that will convince any doubters...
Consider the function f(x)=exp(-x^2)
I think everyone will agree that the graph of this function is a bell curve, which means that the function is interpreted as exp(-(x^2)) and not exp((-x)^2).
05-06-2015, 03:40 PM
Post: #54
(05-06-2015 02:37 PM)Wes Loewer Wrote:  I think I've got something that will convince any doubters...
Interesting, but here we have a variable instead of a number. This leads me to this thought:
I find it indeed difficult to realize we have no other representation of a negative number than a positive one subtracted from zero. An implicitly atomic expression -2 looks quite attrative to consider, but is unfortunately no convention. Hence a new symbol (raised minus) has been introduced on some calculators like the 32SII.
05-06-2015, 06:52 PM
Post: #55
(05-04-2015 02:51 PM)Joe Horn Wrote:  In ANY command-line algebraic-notation calculator which follows standard algebraic notation rules of operator precedence, [2][+/-][x²] yields the same result as [+/-][2][x²], because both key sequences create identical command lines, namely, "-2²", which of course IN STANDARD ALGEBRAIC NOTATION equals -4.
Maybe it has been mentioned before: Just found out the 32SII does it wrong.
[EQN][-][2][y^x][2][ENTER] gives 4 as well as [EQN][2][+/-][y^x][2][ENTER]. It was a hard day and it has been some time since I last get into the details of this calculator, so what am I missing here?
The 17BII equation solver does it right with [A][=][-][2][y^x][2][calc] resulting in -4.
05-06-2015, 07:56 PM (This post was last modified: 05-07-2015 03:45 AM by Wes Loewer.)
Post: #56
(04-26-2015 07:20 AM)Thomas Radtke Wrote:
(04-26-2015 06:38 AM)parisse Wrote:  Could you give a list of softwares/calcs that evaluate -2^2 (algebraic notation) to 4?
MS Excel.
Check out https://support.microsoft.com/en-us/kb/kbview/132686 where Microsoft says "This order of precedence may mean that a formula returns a positive value when you expect it to return a negative value."
Here's a table showing how various calculators/software handle the following order of operations issues:
-2^2 = (a) -4 (b) 4
2^3^2 = (a) 512 (b) 64
1/2pi = (a) 1.57 (b) 0.159
Calculators
aaa: HP Prime Algebraic Entry
aab: HP Prime Textbook Entry/50g EQW (but 1/2pi is shown as stacked fraction and is not ambiguous)
aaa: HP 50g Alg mode
abb: Casio fx-9960G
abb: TI 81/82/85/86
aba: TI 73/83/83+/84+(Classic Mode)
aaa: TI 84+(MathPrint Mode)/89/Nspire
Software
bb-: Excel
bb-: OpenOffice
ba-: Google Docs Sheet
ba-: Gnumeric (formula bar shows "(-2)^2" and "2^(3^2)")
ab-: Corel Quattro Pro
ba-: Corel WordPerfect Table
aa-: Maxima
aaa: Wolfram Alpha
aaa: GeoGebra
Legacy Software
bb-: VisiCalc
??-: Lotus 123 (can someone test this)
ab-: Lotus Improv (anybody remember this spreadsheet?)
This is certainly not a complete list, just what I had handy to test. All the calculators I tested agreed that -2^2=-4, but the other issues were mixed. The more recent HP and TI calculators agree with -4, 512, and 1.57.
05-07-2015, 03:55 AM (This post was last modified: 05-07-2015 04:02 AM by Wes Loewer.)
Post: #57
(05-06-2015 03:40 PM)Thomas Radtke Wrote:
(05-06-2015 02:37 PM)Wes Loewer Wrote:  Consider the function f(x)=exp(-x^2)
True, but I figured that either negation precedes exponentiation or it doesn't.
I'm curious, for those that say -2^2 = 4, what about -(2)^2 ?
05-07-2015, 06:04 AM
Post: #58
Well Wes,
Rule of thumb: negation as always higher priority when the calculator does it (Variable^2, Ans^2, ...) but not when you type it.
05-07-2015, 10:30 AM
Post: #59
A fascinating discussion.
From the HP 32S II Owner's Manual:
Page 1-11.
Making Numbers Negative
The +/- key changes the sign of a number.
To key in a negative number, type the number, then press +/-.
To change the sign of a number that was entered previously, just press +/-. (If the number has an exponent, +/- affects only the mantissa - the non-exponent part of the number.)
Note that last part. There is no mention of negation of the entire calculation, only negation of the mantissa.
The Microsoft support article link on MS EXCEL in a previous post basically says the same thing.
I come from a software environment and have written code since 1968, so I'm well aware of orders of precedence. In the software environment, -4 is the correct answer by virtue of the rules of precedence. But back to the original question of this thread: intuitively on a calculator, when I press the +/- key I want to change the sign of a single entity, not the entire subsequent calculation. For me at least, that was always the purpose of the +/- key.
What I find interesting is how the calculator's role has changed over the last 40 years or so. Today it has assumed the role of a software device (read: computer), thus assuming the computer's methodology of doing things. User beware! Today's calculator user must have at least a rudimentary knowledge of computer-speak!
Bill
05-07-2015, 10:40 AM
Post: #60
(05-06-2015 07:56 PM)Wes Loewer Wrote:
(04-26-2015 07:20 AM)Thomas Radtke Wrote:  MS Excel.
-2^2 = (a) -4 (b) 4
Calculators
abb: Casio fx-9960G
abb: TI 81/82/85/86
Software
bb-: Excel
bb-: OpenOffice
aa-: Maxima
aaa: Wolfram Alpha
aaa: GeoGebra
Legacy Software
bb-: VisiCalc
Lotus 123, 2.4: aba
User(s) browsing this thread: 20 Guest(s)
