New to programming...help !
05-18-2015, 10:39 PM
Tried to print ticks divided by 1000 yet get a line of zero's ?. What is wrong with the below ?. Also what is the command to print at a particular location on the screen ?.
EXPORT TEST()
BEGIN
LOCAL TIC;
PRINT();
REPEAT
TIC=TICKS();
TIC=TIC/1000;
PRINT(TIC);
UNTIL GETKEY >-1;
END;
05-19-2015, 02:46 AM
RE: New to programming...help !
(05-18-2015 10:39 PM)Digitaldreams Wrote:  Tried to print ticks divided by 1000 yet get a line of zero's ?. What is wrong with the below ?. Also what is the command to print at a particular location on the screen ?.
EXPORT TEST()
BEGIN
LOCAL TIC;
PRINT();
REPEAT
TIC=TICKS();
TIC=TIC/1000;
PRINT(TIC);
UNTIL GETKEY >-1;
END;
I'm not sure why TIC=TICKS() produces a zero result. However, the following will get what I think you want:
EXPORT TEST()
BEGIN
PRINT();
REPEAT
PRINT(TICKS/1000);
UNTIL GETKEY >-1;
END;
Eddie
05-19-2015, 03:22 AM (This post was last modified: 05-19-2015 03:25 AM by Didier Lachieze.)
You got a line of zero's because you used "TIC=" instead of "TIC:=".
PRINT is printing to the terminal with each PRINT being on a different line, so if you want to print to a particular location on the screen you should use TEXTOUT_P instead of PRINT:
EXPORT TEST()
BEGIN
  LOCAL TIC;
  RECT();
  REPEAT
    TIC:=TICKS()/1000;
    TEXTOUT_P(STRING(TIC),0,0,0,0,100,#FFFFFF);
  UNTIL GETKEY>-1;
END;
05-19-2015, 05:58 AM
EXPORT TEST()
BEGIN
LOCAL TIC;
PRINT();
REPEAT
TIC=TICKS();
TIC=TIC/1000;
PRINT(TIC);
UNTIL GETKEY >-1;
END;
EXPORT TEST()
BEGIN
PRINT();
REPEAT
PRINT(TICKS/1000);
UNTIL GETKEY >-1;
END;
Eddie
Thanks Eddie...believe it or not that was my first attempt and it didn't work, now it does !?. Maybe the recent firmware update did the trick....
05-19-2015, 06:18 AM
(05-19-2015 03:22 AM)Didier Lachieze Wrote:  [quote='Digitaldreams' pid='35504' dateline='1431988787']
[code]EXPORT TEST()
BEGIN
LOCAL TIC;
RECT();
REPEAT
TIC:=TICKS()/1000;
UNTIL GETKEY>-1 ;
END;[/code ]
[/quote ]
Thanks Didier......I shortened it too by removing TIC altogether. What is the function of ':' after a variable ??
05-19-2015, 06:36 AM (This post was last modified: 05-19-2015 06:41 AM by Didier Lachieze.)
(05-19-2015 06:18 AM)Digitaldreams Wrote:  What is the function of ':' after a variable ??
With "TIC=TICKS()" you get the result of the test "TIC equal TICKS()" which in your case in false (zero).
With "TIC:=TICKS()" you assign the value of TICKS() to the the variable TIC, it's the same as with the Sto command "TICKS()▶TIC" where you store the value to TICKS() into the TIC variable.
So in your original program you were comparing TIC to TICKS(), then TIC to TIC/1000 but never assigning a value to TIC, so the default value (zero) assigned to TIC at its creation by the "LOCAL TIC;" statement was printed.
05-19-2015, 06:55 AM
Thanks again Didier !....I'm sure with other devices I've used, if you want to comparison test you would enter '==' !, no wonder It confused me Smile
