deTaylor
05-22-2015, 01:24 PM (This post was last modified: 05-22-2015 01:39 PM by fhub.)
deTaylor
Here's a small CAS function deTaylor for the HP-Prime (similiar to deSolve) which I've originally written for Xcas.
It approximately solves 1st- and 2nd-order differential equations (with initial conditions) as n-th degree Taylor polynomial.
1st order y'=f(x,y) with y(x0)=y0:
deTaylor(f,[x,y],[x0,y0],n)
2nd order y''=f(x,y,y') with y(x0)=y0 and y'(x0)=y0':
deTaylor(f,[x,y,z],[x0,y0,z0],n)
(I'm using z instead of y', because y' can't be used as input)
Here's the function definition:
(you can directly copy&paste it into the Prime-emulator commandline in CAS-mode)
deTaylor(f,v,c,n):=
BEGIN
  local k,yk,sol;
  yk:=v(2); sol:=c(2);
  IF dim(v)<2 or dim(v)>3 or dim(v)<>dim(c) THEN
    RETURN("Argument error!");
  END;
  FOR k FROM 1 TO n STEP 1 DO
    IF dim(v)=2 THEN
      yk:=diff(yk,v(1))+f*diff(yk,v(2));
      sol+=subst(yk,[v(1)=c(1),v(2)=c(2)])/k!*(v(1)-c(1))^k;
    ELSE
      yk:=diff(yk,v(1))+v(3)*diff(yk,v(2))+f*diff(yk,v(3));
      sol+=subst(yk,[v(1)=c(1),v(2)=c(2),v(3)=c(3)])/k!*(v(1)-c(1))^k;
    END;
  END;
  expand(simplify(sol));
END
Example 1: y'=x*y^2+1 with y(0)=1 (6th-degree approximation):
deTaylor(x*y^2+1,[x,y],[0,1],6)
Example 2: y''=x*y*y' with y(1)=2 and y'(1)=3 (5th degree):
deTaylor(x*y*z,[x,y,z],[1,2,3],5)
Maybe it's useful for someone, Wink
Franz
05-22-2015, 06:10 PM (This post was last modified: 05-22-2015 06:10 PM by salvomic.)
RE: deTaylor
thank you!
please help to control with an differential equation still not solvable in Prime (but now ok in XCas):
y'=(x+y)^2
Is it correct to input
deTaylor((x+y)^2, [x,y], [0,0], 7) ?
I get (17/315)x^7+(2/15)x^5+(⅓)x^3
The general solution of equation (XCas) is TAN(x-c)-x
With Taylor I've taylor(TAN(x)-x), x, 6) = (⅓)x^3+(2/15)x^5+x^7+o(x)
It should be ok, isn't it? Smile
Salvo
05-22-2015, 08:27 PM
RE: deTaylor
(05-22-2015 06:10 PM)salvomic Wrote:  thank you!
y'=(x+y)^2
Not exactly, you should enter order 7 (not 6), then you get the same result as with deTaylor (despite of the error term "x^8*order_size(x)"):
taylor(tan(x)-x), x=0, 7)
Franz
05-22-2015, 08:31 PM
RE: deTaylor
(05-22-2015 08:27 PM)fhub Wrote:  Not exactly, you should enter order 7 (not 6), then you get the same result as with deTaylor (despite of the error term "x^8*order_size(x)"):
Franz
right!
thank you.
Parisse has already added the solution for y'=(x+y)^2 in XCas, but it was after the last FW was ready. I hope this will be added in the next firmware.
In the meantime your deTaylor is helpful also for this equation ;-)
Salvo
05-22-2015, 09:44 PM (This post was last modified: 05-22-2015 09:48 PM by fhub.)
RE: deTaylor
(05-22-2015 08:31 PM)salvomic Wrote:  Parisse has already added the solution for y'=(x+y)^2 in XCas, but it was after the last FW was ready. I hope this will be added in the next firmware.
Well, in the meantime you could also use the following function: Smile
deLinSubst(f,x,y):=
BEGIN
  local k;
  k:=simplify(diff(f,x)/diff(f,y));
  IF diff(k,x)<>0 or diff(k,y)<>0 THEN
    RETURN("No linear substitution!");
  END;
  RETURN(solve(subst(integrate(1/(subst(f,y=y-k*x)+k),y),y=y+k*x)=x+G_0,y));
END
Works only for ODEs of the type y'=f(a*x+b*y+c) with a,b,c=const.
For your example y'=(x+y)^2 just enter:
deLinSubst((x+y)^2,x,y)
(enter only the RHS, not y'=...)
In this simple form you get a solution only if Xcas can 'solve' the equation for y, but it could easily be modified to return at least an implicit solution if the equation is unsolvable.
Franz
05-22-2015, 10:13 PM
RE: deTaylor
(05-22-2015 09:44 PM)fhub Wrote:  Well, in the meantime you could also use the following function: Smile
deLinSubst(f,x,y):=
Franz
well done, Franz!
it works: gives the true (general) solution of ODE y'=(x+y)^2 -> TAN(G_0+x)-x
Salvo
