Permutations & Combinations for large inputs
05-24-2015, 05:39 PM
This program will calculate permutations or combinations (nPr and nCr) for arguments that would normally overflow the FACT function when using the standard forms n!/(n-r)! and n!/(r!(n-r)!). This is a good example of using flag 25 to handle errors. The method employed here is to attempt the standard forms, setting flag 25 before each FACT, then bailing out to a routine that performs repeated multiplication and division if FACT overflowed.
The loop routine will also perform the appropriate division for COMB as the multiplication is being performed, to allow evaluating COMB for arguments that would still overflow PERM even with this method. For small inputs, execution time should be relatively quick, but larger values will take longer due to the loop operation. The below example takes 33 seconds on my unmodified 41CV. Inputs: y: n x: r XEQ PERM, or XEQ COMB Example: 234 ENTER 78 XEQ ALPHA COMB ALPHA Result: 2.6795468 63 Uses registers 20 and 21, and flags 05 and 25 (error trap). No modules required. Code: 01 LBL "PERM" |
05-26-2015, 09:26 AM
(This post was last modified: 05-26-2015 09:51 PM by Dieter.)
RE: Permutations & Combinations for large inputs
(05-24-2015 05:39 PM)Dave Britten Wrote: This program will calculate permutations or combinations (nPr and nCr) for arguments that would normally overflow the FACT function when using the standard forms n!/(n-r)! and n!/(r!(n-r)!). This is a good example of using flag 25 to handle errors. The method employed here is to attempt the standard forms, setting flag 25 before each FACT, then bailing out to a routine that performs repeated multiplication and division if FACT overflowed. Dave, your method requires just one single overflow test: If n! does not overflow, the smaller values (n–r)! and r! won't either. So lines 17,19 and 20 resp. 25, 27 and 28 can be removed. They should be removed because a set flag 25 may cover other errors, e.g. non-integer or negative arguments. Just for comparison, here is another version that does not require any data registers and runs faster due to two separate loops and some further improvements within these. For instance two counters are used that are set up before the loops start so that no additional arithmetics within the loops are required. Both loops can be combined to one, but in this case especially nPr would run slower. The program also uses the property Comb(n,r) = Comb(n, n–r), which substantially speeds up the program for r > n/2. Flag 25 is not used – checking whether n>69 will do. Code: 01 LBL"NPR" // Permutations I sincerely hope you do not mind my suggestion – it includes some basic ideas that may be helpful for other programs as well. Edit: program modified to handle r=0 (and n–r=0 for nCr) correctly. Dieter |
05-26-2015, 12:08 PM
(05-26-2015 09:26 AM)Dieter Wrote: I sincerely hope you do not mind my suggestion – it includes some basic ideas that may be helpful for other programs as well. Not at all. Half the reason I post stuff here is to find better ways to do stuff. I find that if you want to ask an engineer the best way to do something, it's better to simply show him a poor way of doing it. |
05-26-2015, 12:22 PM
Common pitfalls for a COMB routine:
- C(8,3) calculated as 8/3*7/2*6 returns 56.00000001 solution : calculate it as 8/1*7/2*6/3, guaranteeing integers all along, but then...: - C(335,167) overflows while the result is < 1e100 solution: calculate 0.001*n/1*(n-1)/2*(n-2)/3... *1000 1e3 is large enough because we are looking for the largest p for which C(n,p)<1e100, and that is 168 (C(336,168) = 6e99) The largest intermediate number formed is p*C(n,p). - C(n,0) = 1 - C(n,n-1) = C(n,1) solution: calculate C(n,min(p,n-p)) The following routine avoids these, but may return slightly inaccurate results > 1e10 due to roundoff. Nothing to be done about that. Code: L X Y Z T 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
05-26-2015, 12:56 PM
(05-26-2015 09:26 AM)Dieter Wrote: Dave, your method requires just one single overflow test: If n! does not overflow, the smaller values (n–r)! and r! won't either. Yeah, those can probably go. I'm just hard-wired for defensive coding when it comes to error trapping. (05-26-2015 09:26 AM)Dieter Wrote: So lines 17,19 and 20 resp. 25, 27 and 28 can be removed. They should be removed because a set flag 25 may cover other errors, e.g. non-integer or negative arguments. In this case, it shouldn't be terribly harmful. The worst that will happen is it will detect some other error condition and run the looping algorithm instead. But on a related note, you should (nearly) always test flag 25 with FC?C so as not to accidentally leave it set and mask an error later. (05-26-2015 09:26 AM)Dieter Wrote: Just for comparison, here is another version that does not require any data registers and runs faster due to two separate loops and some further improvements within these. For instance two counters are used that are set up before the loops start so that no additional arithmetics within the loops are required. Both loops can be combined to one, but in this case especially nPr would run slower. The program also uses the property Comb(n,r) = Comb(n, n–r), which substantially speeds up the program for r > n/2. Flag 25 is not used – checking whether n>69 will do. Good idea with doing multiple loops. It briefly crossed my mind, but I wasn't sure which would be faster on the 41, and hadn't tested it yet. (05-26-2015 12:22 PM)Werner Wrote: Common pitfalls for a COMB routine: Mine deals with the first two situations, since it tries factorials first, and switches to looped division/multiplication if that overflows. As for r=0 or r>n, I haven't done anything to detect those. Sometimes you just have to accept garbage in garbage out. |
05-26-2015, 05:14 PM
(This post was last modified: 05-26-2015 10:45 PM by Dieter.)
(05-26-2015 12:22 PM)Werner Wrote: Common pitfalls for a COMB routine: That's the way I do it in higher-level programming languages where count-up loops are much more relaxed than on calculators like the HP41. ;-) However, small input like in your example is evaluated directly via factorials in the program I posted. Since the program calculates n!/(n–r)! first (which always is an integer) the results should be exact here. (05-26-2015 12:22 PM)Werner Wrote: - C(335,167) overflows while the result is < 1e100 OK. But at least the version I posted correctly retuns C(336, 168) as 6,0887 E+99. #-) (05-26-2015 12:22 PM)Werner Wrote: solution: calculate 0.001*n/1*(n-1)/2*(n-2)/3... *1000 That's an interesting approach. (05-26-2015 12:22 PM)Werner Wrote: - C(n,0) = 1 That's what my version implements as well. However, the C(n, 0) case has to be handled separately. I now posted an update. (05-26-2015 12:22 PM)Werner Wrote: The following routine avoids these, but may return slightly inaccurate Yes, you can't expect 10-digit accuracy with merely 10-digit precision. Dieter |
05-27-2015, 12:03 PM
(05-26-2015 05:14 PM)Dieter Wrote: Since the program calculates n!/(n–r)! first (which always is an integer) the results should be exact here.Only for n<16 I'm afraid. eg. PERM(16,5) = 16!/(11!) = 524160.0001. There's 110 cases like this for n<70. All of them can be corrected with 0.1 + INT. Worst case is PERM(64,5)= Then there are a few cases with a result of 10 significa 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
05-27-2015, 12:27 PM
(05-26-2015 05:14 PM)Dieter Wrote: Since the program calculates n!/(n–r)! first (which always is an integer) the results should be exact here.Only for n<16 I'm afraid. eg. PERM(16,5) = 16!/(11!) = 524160.0001. There's 110 cases like this for n<70. These can be corrected with 0.1 + INT. Worst case is PERM(64,5) = 914941440.4 Then there are a few cases with a wrong result of exactly 10 significant digits: PERM(31,9) = 7.315688014e12 (exact 7.315688016e12) PERM(35,8) = 8.489642628e11 (exact 8.489642624e11) PERM(38,7) = 6.360609025e10 (exact 6.360609024e10) 39 7 45 7 52 7 54 7 59 6 61 6 64 6 68 6 All of these are larger than 1e10 though, so you're at least able to deliver correct results less than 1e10 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
05-30-2015, 01:07 PM
(This post was last modified: 05-30-2015 01:15 PM by Dieter.)
(05-27-2015 12:27 PM)Werner Wrote: Only for n<16 I'm afraid. Yes, deviations like this can occur if one of the operands cannot be represented exactly with 10 digits. Here 16! is 20 922 789 888 000 which is rounded to 2,092278989 E+13. (05-27-2015 12:27 PM)Werner Wrote: There's 110 cases like this for n<70. That's the lazy solution. Too bad there is no ROUNDI on the '41. ;-) (05-27-2015 12:27 PM)Werner Wrote: Worst case is PERM(64,5) = 914941440.4 I suggested an upgrade to the combinations routine of the Binomial program that is discussed in another thread in this forum. Here the denominator loop counts up so that the intermediate results are integers. On the other hand, there is no chance to reliably get a result with 10 exact digits if the calculator works with the same 10-digit precision. So a slight error in the last digit might be acceptable. Dieter |
05-30-2015, 03:51 PM
(05-30-2015 01:07 PM)Dieter Wrote: That's the lazy solution. Too bad there is no ROUNDI on the '41. ;-) See this thread about CEIL/FLOOR. Do you recognize anybody among the authors? :) Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
05-31-2015, 07:37 AM
(This post was last modified: 05-31-2015 07:37 AM by Ángel Martin.)
(05-27-2015 12:27 PM)Werner Wrote:(05-26-2015 05:14 PM)Dieter Wrote: Since the program calculates n!/(n–r)! first (which always is an integer) the results should be exact here.Only for n<16 I'm afraid. The NCR and NPR functions on the SandMath can be a good reference. Since they use internal 13-digit accuracy the results are pretty much right on, always integers (no, there isn't any rounding done by the function in case you wonder). But I'm positive Dieter will find a counter-example to this rule as soon as he starts using the SandMath on V41 ;-) Cheers, 'AM "To live or die by your own sword one must first learn to wield it aptly." |
05-31-2015, 04:16 PM
(05-31-2015 07:37 AM)Ángel Martin Wrote: But I'm positive Dieter will find a counter-example to this rule as soon as he starts using the SandMath on V41 ;-) I wonder if the quotient of two numbers rounded to 13 or even 12 significant digits can have an error that would affect the 10-digit result. #-) BTW, the Sandmath manual I got is revision 44_E ("this compilation revision 4.44.44 (really!)") from November 2012. Is this the current version that matches the Sandmath .mod file you sent? I'll have to look a bit deeper into this. At the moment I get some strange results, e.g. floor(pi)=1 or ceil(0,5)=–1. Dieter |
05-31-2015, 05:36 PM
(This post was last modified: 05-31-2015 05:37 PM by Ángel Martin.)
(05-31-2015 04:16 PM)Dieter Wrote: ...the Sandmath manual I got is revision 44_E ("this compilation revision 4.44.44 (really!)") from November 2012. Is this the current version that matches the Sandmath .mod file you sent? No it isn't. The latest one is rev. 5.79.89 from February 2015 - I'll email you a copy. (05-31-2015 04:16 PM)Dieter Wrote: I'll have to look a bit deeper into this. At the moment I get some strange results, e.g. floor(pi)=1 or ceil(0,5)=–1. What did I say - you just found another bug right off the shoe... thanks! "To live or die by your own sword one must first learn to wield it aptly." |
