Inverse Matrix
06-28-2015, 05:01 AM
(This post was last modified: 06-28-2015 05:02 AM by Lin Su.)
Inverse Matrix
Hi = )!
When i calculate the inverse matrix, i use inv(Matrix) and for small numbers(img.1), there`s no problem but when i try to calculate using large number(img.2)..it shows wrong result.. what am i doing wrong? |
06-28-2015, 06:27 AM
RE: Inverse Matrix
(06-28-2015 05:01 AM)Lin Su Wrote: Hi = )! large number is the image (2?) with [[4,5][6,7]]? its inverse is [[-3.5,2.5][3,-2]], correct. Or am I missing something? Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
06-28-2015, 08:17 AM
RE: Inverse Matrix
(06-28-2015 05:01 AM)Lin Su Wrote: Hi = )! (06-28-2015 06:27 AM)salvomic Wrote:(06-28-2015 05:01 AM)Lin Su Wrote: Hi = )! The images are displayed on the forum web page in reverse order. By "img.2" he means the image on the left. Lin: I typed your 5×5 matrix into my Prime, and it gets the correct inverse both in Home and in CAS. Could there be a typo in your input? <0|ɸ|0> -Joe- |
06-28-2015, 09:17 AM
RE: Inverse Matrix
With the Excel matrix entered into M6, my results agree with Joe's, (I get the correct inverted values). Just for fun, notice the precision difference between inv(inv(M6)) function value, and (M6^-1)^-1.
Using the exponential form returns the original M6, while the inv() function returns a little less precision. -Dale- |
06-29-2015, 10:28 PM
RE: Inverse Matrix
Hi Again X)
Thanks !! it was my typing mistake. You were right!!! . Salvomic, Joe Horn, DrD.. For give me for "stealing" your time = ( and Thanks again! |
06-29-2015, 10:33 PM
RE: Inverse Matrix
(06-29-2015 10:28 PM)Lin Su Wrote: Hi Again X) never mind, we are glad to help you! :-) ciao ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
