[HP 35s] Hosoda trig program giving incorrect answers to certain angles
08-05-2015, 02:36 PM
(This post was last modified: 08-05-2015 04:30 PM by Marcio.)
Hello all,
After clearing all variables and registers, I noticed that Hosoda gives wrong answers to certain angles (cosine) on my 35s: \[ \begin{matrix} & Hosoda & 35s & 34s & 50g \\ 5\frac { \pi }{ 180 } & 9.96194698092E-1 & 9.96194698092E-1 & 9.96194698092E-1 & 9.96194698092E-1 \\ 75\frac { \pi }{ 180 } & 2.58819045098E-1 & 2.58819045098E-1 & 2.58819045103E-1 & 2.58819045108E-1 \\ 89.999\frac { \pi }{ 180 } & 1.74532948958E-5 & 1.74532948891E-5 & 1.74532925187E-5 & 1.74532948957E-5 \\ 89.9999\frac { \pi }{ 180 } & 1.74532489662E-6 & 1.74532489000E-6 & 1.74532925262E-6 & 1.74532489662E-6 \end{matrix} \] Does anybody have any idea as to what is happening? Maybe I am missing something here? I have already double-checked all program lines and everything is exactly as before. Very much appreciated. Marcio CORRECTION: Hosoda trig program is working as expected, it was I who "forgot" about the significant loss of accuracy that occurs while converting from DEG to RAD, as pointed out by our dear friend Gerald. |
08-05-2015, 02:49 PM
RE: [HP 35s] Hosoda trig program giving incorrect answers for certain angles
(08-05-2015 02:36 PM)Marcio Wrote: Hello all, Could it be related to the fact that near 90° the 35s trig functions have very limited accuracy? (about four digits only) Tom L Tom L Cui bono? |
08-05-2015, 02:57 PM
(This post was last modified: 08-05-2015 03:26 PM by Marcio.)
(08-05-2015 02:49 PM)toml_12953 Wrote: Could it be related to the fact that near 90° the 35s trig functions have very limited accuracy? (about four digits only)Well, the 35s does have troubles getting all digits correct when the angles are very small (1E-7°) or near 90°, as in 89.9999° (four decimals, not three), but the Hosoda code, a 3rd party program, is supposed to get digits right. I myself have been working with it a lot lately and yesterday, after clearing everything, I noticed this weird behaviour. I suspect it has to do with some registers not being real numbers, and they got erased, I know, it seems crazy but it is all I can remember from yesterday. To make matters worse, while \(e^x\) is stable across the entire domain on the 35s, \(e^{ix}\) shows the same instability as observed on the trig functions calculated by the 35s on those very same angles. |
08-05-2015, 03:17 PM
(This post was last modified: 08-05-2015 03:29 PM by Gerald H.)
Hosoda's programmes only work in radian measures.
For 75°, ie 75 * pi / 180, the programme returned 2.58819045108E-1 ie I did the ->RAD by hand, not using the built-in function. Other values as you have them. |
08-05-2015, 03:19 PM
(This post was last modified: 08-05-2015 03:23 PM by Marcio.)
RE: [HP 35s] Hosoda trig program giving incorrect answers to certain angles
(08-05-2015 03:17 PM)Gerald H Wrote: Hosoda's programmes only work in radian measures. Yes, I converted them to RAD before calling the routines. EDIT: The last digit of your answer reads 8. Is it not 3? |
08-05-2015, 03:25 PM
(This post was last modified: 08-05-2015 03:26 PM by Gerald H.)
I've now edited my posting to show I did not use the built-in ->RAD function.
08-05-2015, 03:29 PM
RE: [HP 35s] Hosoda trig program giving incorrect answers to certain angles | |||
08-05-2015, 03:31 PM
(This post was last modified: 08-05-2015 03:32 PM by Gerald H.)
I, as a lazy user, think the conversion ->RAD produces inaccuracies & Hosoda's programmes may be inaccurate near the cusp.
08-05-2015, 03:44 PM
89.9999 ->RAD gives 1.57079458147 on the 35S
actual value is more like 1.57079458146564... so you can't expect so much accuracy from the result. |
08-05-2015, 03:47 PM
(This post was last modified: 08-05-2015 03:50 PM by Marcio.)
My dear Gerald, with all due respect, I think you're missing the point. Please, have another look at the table at the beginning. Until recently, the Hososa code I have here gave the same answers as the 34s, which uses more digits deep inside.
Thanks Marcio |
08-05-2015, 03:50 PM
Try inputting 1.57079458147 on the 34S & see the value returned.
08-05-2015, 04:21 PM
& on my trusty HP 48S
89.9999° COS returns 1.74532925199E-6 & converted to radians 1.57079458147 returns1.74532489662E-6 |
08-05-2015, 04:23 PM
(This post was last modified: 08-05-2015 04:33 PM by Marcio.)
Yes, you're 100% correct. It was just another lapse of mine! I never thought the impact would be that big though! Thank you for pointing that out.
EDIT: I have also updated the table. Marcio |
