hp-67 EE Filters pack manual
10-22-2015, 05:21 AM
(This post was last modified: 10-22-2015 05:22 AM by Ángel Martin.)
I'm considering putting together the 67 EE Filters pack into a module - which seems quite an easy task considering that all programs are available as RAW files in the museum, see:
http://www.hpmuseum.org/software/soft41.htm approx at the middle of the page section "HP-67 Filters Solution Book (Ported to HP-41C) " However I'm not all that happy with the direct port from the 67 code, a tad crude in data entry and result output for my taste. Does anyone have access to the original manual, so I can figure out the program flows and try to improve on them? Only then I think they'll be a valuable addition to the 41 community (and the CL of course). Thanks, 'AM "To live or die by your own sword one must first learn to wield it aptly." |
10-22-2015, 02:23 PM
RE: hp-67 EE Filters pack manual | |||
10-22-2015, 02:46 PM
(This post was last modified: 10-22-2015 02:52 PM by Ángel Martin.)
[/b]
Quote:(10-22-2015 02:23 PM)Dave Frederickson Wrote: [quote='Ángel Martin' pid='44314' dateline='1445491262'] Thanks for asking - ufortunately they appear to be two different beasts, as per the listing below the Filters seems to be a "solutions book" - I suppose it was without any cards. But there are also filter programs in the EE pack, so if you could share those pages it'd be grand and highly appreciated. Code:
and: Code:
10-22-2015, 02:57 PM
Hello Ángel,
I have ~60% of the original HP-67 Solution Books at home. Unfortunately I am currently at work and cannot check if I have this one. I will look tonight and if I have it, I will scan the manual then send sent it to you. Best regards, Sylvain |
10-22-2015, 03:43 PM
(This post was last modified: 10-22-2015 03:50 PM by Dave Frederickson.)
10-23-2015, 01:01 AM
(This post was last modified: 10-23-2015 01:14 AM by Sylvain Cote.)
Sorry Ángel,
I do not have it [the solution book] and the one on the MoHPC DVD is incomplete. [But I have the EE. Pac 1 if you are interested. btw MoHPC DVD also have it] Good luck on your search .... Best regards, Sylvain [edit] |
10-23-2015, 03:12 AM
(This post was last modified: 10-23-2015 03:13 AM by Ángel Martin.)
(10-23-2015 01:01 AM)Sylvain Cote Wrote: Sorry Ángel, Many thanks Sylvain, at this point I think I'll go with what's available on the museum DVD - so no need to scan/send any further. Those programs are rather old anyway and won't compare well with more modern versions of the same subject in the 41 solution's book - at least that's what I think. Cheers, 'AM "To live or die by your own sword one must first learn to wield it aptly." |
