Help me port this Matlab code......pls....(ported)[Solved]
11-25-2015, 05:16 PM (This post was last modified: 11-29-2015 07:22 AM by toshk.)
linedata=[1     2       0.01008,    0.05040,   3.815629,     -19.078144,     10.25,  0.05125;
          1     3       0.00744,    0.03720,   5.169561,     -25.847809,     7.75,   0.03875;
          2     4       0.00744,    0.03720,   5.169561,     -25.847809,     7.75,   0.03875;
          3     4       0.01272,    0.06360,   3.023705,     -15.118528,     12.75,  0.06375];
busdata=[1   0,     0,  50,     30.99,  1.00,   0   1;
         2   0,     0,  170,    105.35, 1.00,   0   2;
         3   0,     0,  200,    123.94, 1.00,   0   2;
         4   318,   0,   80,    49.58,  1.02,   0   3]
% Bus Type: 1.Slack Bus    2.PQ Bus    3.PV Bus
ss=1i*linedata(:,8);
y=linedata(:,5)+1i*linedata(:,6);
totalbuses = max(max(linedata(:,1)),max(linedata(:,2)));    % total buses
totalbranches = length(linedata(:,1));                      % no. of branches
ybus = zeros(totalbuses,totalbuses);
for b=1:totalbranches
    ybus((linedata(b,1)),(linedata(b,2)))=-y(b);
    ybus((linedata(b,2)),(linedata(b,1))) =ybus((linedata(b,1)),(linedata(b,2)));
end
 for c=1:totalbuses
     for d=1:totalbranches
         if linedata(d,1) == c || linedata(d,2) == c
             ybus(c,c) = ybus(c,c) + y(d) + ss(d);
         end
     end
 end
disp('TABLE 9.3 PAGE # 338   BUS ADMITTANCE MATRIX FOR EXAMPLE 9.2')
ybus
z=zeros(totalbuses,4);
busnumber=busdata(:,1);
PG=busdata(:,2);
QG=busdata(:,3);
PL=busdata(:,4);
QL=busdata(:,5);
V=busdata(:,6);
VV=V;
ANG=busdata(:,7);
type = busdata(:,8);
P = (PG-PL)./100;    % per unit active power at buses
Q = (QG-QL)./100;    % per unit reactive power at buses
tol=1;
iter=0;
kk=0.0001;
while tol > kk
    for i = 2:totalbuses
      YV = 0;
        for k = 1:totalbuses
            if i~=k
                YV = YV + ybus(i,k)* V(k);  % multiplying admittance & voltage
            YV;
            end
        YV;
        end
        if busdata(i,8) == 3     %Calculating Qi for PV bus
            %Q(i) = -imag(conj(V(i))*(YV + ybus(i,i)*V(i)));
            busdata(i,3)=Q(i);
        end
       % end
        V(i) = (1/ybus(i,i))*((P(i)-j*Q(i))/conj(V(i)) - YV); % Compute Bus Voltages.
         % Calculating Corrected Voltage for PV bus
           vc(i)=abs(VV(i))*(V(i)/abs(V(i)));
           busdata(i,6)=vc(i);
           V(i)=vc(i);
       end
      % Calculating Accelerated Voltage for PQ bus
       if busdata(i,8) == 2
        VACC(i)= VV(i)+(V(i)-VV(i));
        busdata(i,6)=VACC(i);
        V(i)=VACC(i);
       end
        %V(i)=V;
    end
 iter = iter + 1;      % Increment iteration count.
    tol = max(abs(abs(V) - abs(VV)));     % Calculate tolerance.
   VV = V;
end
Q;
iter;
YV;
V;
%real(VACC')
z(1:totalbuses,1)=busdata(:,1);
z(1:totalbuses,2)=busdata(:,8);
z(1:totalbuses,3)=abs(busdata(:,6));
z(1:totalbuses,4)=radtodeg(angle(V));
disp('           Bus No.   Bus Type     Voltage      Angle      ');
z
hp prime porting code ...tried but got different results
#cas
gausss(M1,M3):=
BEGIN
//M1=linedata, M2=ybus  M3= busdata
ss:= .* col(M1,5);
y:= col(M1,3);
y:=1 ./ y;
totalbuses:= MAX(MAX(col(M1,1)),MAX(col(M1,2)));
totalbranches:= length(M1);
M2:=makemat(totalbuses,totalbuses);
FOR b FROM 1 TO totalbranches DO
    M2(M1(b,1),M1(b,2)):=-y(b);
    M2((M1(b,2)),(M1(b,1))):=M2((M1(b,1)),(M1(b,2)));
END;
FOR c FROM 1 TO totalbuses DO
    FOR d FROM 1 TO totalbranches DO
             IF M1(d,1)==c OR M1(d,2) == c THEN
                M2(c,c) := M2(c,c) + y(d)+ss(d);
             END;
    END;
END;
M2;
M9:=makemat(totalbuses,4);
busnumber:=col(M3,1);
pg:=col(M3,2);
qg:=col(M3,3);
pl:=col(M3,4);
ql:=col(M3,5);
v:= col(M3,6);
vv:=v;
ANG:=  col(M3,7);
types:= col(M3,8);
p := (pg - pl) ./100;
q := (qg - ql) ./100;
toll:=1;
iter:=0;
kk:=0.0001
alfa:=1.6;
WHILE toll > kk DO
    FOR j FROM 2 TO totalbuses DO
      YV := 0;
        FOR k FROM 1 TO totalbuses DO
            IF j≠k THEN
                YV := YV + M2(j,k)* v(k);
            END;
        END;
//Calculating Qi for PV bus
        IF M3(j,8) == 2 THEN
            q(j) :=  -IM((CONJ(v(j)))*(YV + M2(j,j)*v(j)));
            M3(j,3):=q(j);
        END;
        v(j) := (1/M2(j,j))*((p(j)-*q(j))/CONJ(v(j)) - YV); //Compute Bus Voltages.
//Calculating Corrected Voltage for PV bus
       IF M3(j,8) == 3 THEN
           vc(j):=(abs(vv(j)))*(v(j)/abs(v(j)));
           M3(j,6):=vc(j);
           v(j):=vc(j);
       END;
//Calculating Accelerated Voltage for PQ bus
          VACC(j):= vv(j)+alfa*(v(j)-vv(j));
          M3(j,6):=VACC(j);
          v(j):=VACC(j);
       END;
     END;
iter := iter + 1;
toll :=abs(abs(MAX(v))-abs(MAX(vv)));
vv := v;
END;
q;
YV;
v;
END;
#end
11-25-2015, 06:46 PM
RE: Help me port this Matlab code......pls
I might be able to help, but first it'd be interesting see what comes up if you debug them simultaneously, line by line.
Does the Prime code have any syntax error?
11-25-2015, 07:06 PM (This post was last modified: 11-25-2015 07:12 PM by toshk.)
(11-25-2015 06:46 PM)Marcio Wrote:  I might be able to help, but first it'd be interesting see what comes up if you debug them simultaneously, line by line.
no major syntax error....
but the while loop fails to iterate.
suspect: % Calculate tolerance. in Matlab translation.
also some variants in YV values.
input data
11-25-2015, 07:30 PM
(11-25-2015 07:06 PM)toshk Wrote:  no major syntax error....
Eliminate all syntax errors and see if the loop finishes.
11-29-2015, 07:18 AM (This post was last modified: 11-30-2015 04:00 AM by toshk.)
Power-Flow.....Gauss-Siedel Method
#cas
gausss(M1,M3):=
BEGIN
//M1 for linedata: column1=bus From, column2=bus To, column3=Zpu, column4=Shunt Admittance [Q value] but can enter zero if not know , column5=Shunt Admittance [Bpu/2]
//M3 for Busdata: column1=buses, column2=Pg, column3=Qg, column4=PL, column5=QL, column6=Vpu, column7= Vpu Angle, column8=Bus Type
//Bus Type: 1.Slack Bus    2.PQ Bus    3.PV Bus
ss:=(col(M1,5)) .* ; // capacitor
y:=(col(M1,3));
y:=approx(1 ./ y);
totalbranches:= length(col(M1,1));
END
             END
    END
END
M2;//ybus matrix
pg:=col(M3,2);
qg:=col(M3,3);
pl:=col(M3,4);
ql:=col(M3,5);
L2:= col(M3,6);
vv:=L2;
ANG:= col(M3,7);
types:=col(M3,8);
p:= approx((pg - pl) ./100); //Sbase of 100MVA
L0:=approx((qg - ql) ./100);
toll:=1;
iter:=0;
kk:=0.01;//tolerance
alfa:=1.6;
WHILE toll > kk DO
      YV := 0;
            IF j≠k THEN
                YV:= YV + M2(j,k)* L2(k);
            END;
        YV;
        END;
        IF M3(j,8)== 3 THEN
            L0(j) :=  -im(conj(L2(j))*(YV + M2(j,j)*L2(j)));
            M3(j,3):=L0(j);
        END;
        v1:=L2(j);
        m2:=M2(j,j);
        pu:=p(j);
        qu:=L0(j);
        L2(j):= (1/m2)*((pu-*qu)/conj(v1) - YV); //Compute Bus Voltages.
       IF M3(j,8)== 3 THEN
           L4(j):=abs(vv(j))*(L2(j)/abs(L2(j)));
           M3(j,6):=L4(j);
           L2(j):=L4(j);
       END;
       IF M3(j,8)== 2 THEN
          L5(j):= vv(j)+alfa*(L2(j)-vv(j));
          M3(j,6):=L5(j);
          L2(j):=L5(j);
       END;
     END;
iter := iter + 1;
L1:=vv;
toll:= max(abs(abs(L2)- abs(L1)));
vv:= L2;
END;
msgbox("check M3 col 6 for |V| and Angle; type M2 for Ybus ")
END;
#end
