[41/42/..] Micro-challenge: order X and Y by magnitude
03-08-2016, 01:53 PM
Really very small challenge. Given two numbers in X and Y, order them so that the smallest in magnitude is in X. To make it a bit more of a challenge, you can only use the stack, and must leave L, Z and T untouched.
Basically, perform a X<>Y when abs(X) > abs(Y). When the magnitudes are equal, you have a choice. BTW should you need a test X>=a? where a=0 or Y, present on the 42S but not on the 41, do X<a? X=a? instead, in succession. Good luck, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
03-08-2016, 02:53 PM
RE: [41/42/..] Micro-challenge: order X and Y by magnitude
This appears to work based on a couple quick tests.
Code: LBL "MAGORD" Tests (y, x -> y, x): 8, 4 -> 8, 4 4, 8 -> 8, 4 -8, 4 -> -8, 4 4, -8 -> -8, 4 -8, -4 -> -8, -4 -4, -8 -> -8, -4 -4, 8 -> 8, -4 8, -4 -> 8, -4 8, -8 -> 8, -8 -8, 8 -> 8, -8 |
03-08-2016, 03:50 PM
Pretty good ;-)
now try and shave off two more bytes ;-) Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
03-08-2016, 04:03 PM
RE: [41/42/..] Micro-challenge: order X and Y by magnitude | |||
03-08-2016, 07:33 PM
(03-08-2016 01:53 PM)Werner Wrote: Really very small challenge. Given two numbers in X and Y, order them so that the smallest in magnitude is in X. That's why I always wanted a MAXABS and MINABS function on the WP34s. ;-) Seriously: I think these would be two very useful functions. Maybe on the 43s ?-) Dieter |
03-08-2016, 08:39 PM
(03-08-2016 04:03 PM)Dave Britten Wrote:(03-08-2016 03:50 PM)Werner Wrote: Pretty good ;-) I came up with an exact copy of your program, except for the missing second RTN and the one-character LBL. { 16-byte Prgm} |
03-08-2016, 09:18 PM
(03-08-2016 07:33 PM)Dieter Wrote: That's why I always wanted a MAXABS and MINABS function on the WP34s. ;-) There are lots of useful extra functions that could have been added Would comparison commands be more useful? i.e. |x|=|y|? |x|>|y|? |x|>1? |x|<= rr extended to the complex domain as well c|x|<|y|? Pauli |
03-08-2016, 09:23 PM
03-08-2016, 10:31 PM
(03-08-2016 07:33 PM)Dieter Wrote:(03-08-2016 01:53 PM)Werner Wrote: Really very small challenge. Given two numbers in X and Y, order them so that the smallest in magnitude is in X. ?? Would a function to order the stack from hi to lo and/or vice versa be useful ?? 2speed HP41CX,int2XMEM+ZEN, HPIL+DEVEL, HPIL+X/IO, I/R, 82143, 82163, 82162 -25,35,45,55,65,67,70,80 |
03-08-2016, 11:20 PM
(03-08-2016 10:31 PM)TASP Wrote: ?? My suggestion was a function that returns the value with the minimum/maximum absolute value of X and Y. Alternatively, as Pauli said, tests commands could be implemented that compare the magnitudes of X and Y. A dedicated stack sort command maybe is a bit, err... "special". ;-) Dieter |
03-09-2016, 12:07 AM
indeed
03-09-2016, 10:34 AM
I'm not in favour of having all functions predefined - where's the fun, then? I'd rather have the means to define and include my own programs/functions and to use them exactly like the built-in ones.
In that regard, the RTN+1 function of the 34 is a stroke of genius, you can make your own |x|>|y|? function - too bad you're restricted to three characters for the name, but oh well. But we digress. here's my 'order X and Y in order of magnitude': Code: X>Y? Cheers, Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
03-09-2016, 12:28 PM
(03-09-2016 10:34 AM)Werner Wrote: I'm not in favour of having all functions predefined - where's the fun, then? I'd rather have the means to define and include my own programs/functions and to use them exactly like the built-in ones. Yeah, I really wish the HPs had RTN+1. On the 41 and 42, you can at least fake it somewhat if you designate a flag as "execute the next instruction" and adhere to that calling convention, e.g. "XEQ ABSX<Y?, FS?C 09, RTN, do something else..." Would also love to have SKIP and BACK. Here's hoping that, with Free42 being GPL, the DM-42L firmware will be open source as well. Assuming SwissMicros doesn't negotiate a different licensing scheme with Thomas, I would assume it would have to be GPL as well. Also, I haven't had a chance to try your program yet, but the odd number of CHS instructions being run would leave one of the values inverted on the stack, wouldn't it? |
03-09-2016, 12:48 PM
(03-09-2016 12:28 PM)Dave Britten Wrote: Also, I haven't had a chance to try your program yet, but the odd number of CHS instructions being run would leave one of the values inverted on the stack, wouldn't it? No, it won't ;-)) Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
03-09-2016, 12:59 PM
(03-09-2016 12:48 PM)Werner Wrote:(03-09-2016 12:28 PM)Dave Britten Wrote: Also, I haven't had a chance to try your program yet, but the odd number of CHS instructions being run would leave one of the values inverted on the stack, wouldn't it? Oh right, missed that one of them is hiding after a conditional. That's what I get for hastily reading code 5 minutes before leaving for work. |
