AstroLab 4 and new FW
04-22-2016, 12:11 PM
For those who use AstroLab 4, a new corrected version will be post tomorrow (saturday).
This version will work with the new FW (10077) and the past one also. I think the function name can not exceed 30 char long in the new FW (10077). I have change this and AstroLab 4 work well now for me with FW (10077). Marcel |
04-22-2016, 01:45 PM
RE: AstroLab 4 and new FW
(04-22-2016 12:11 PM)Marcel Wrote: For those who use AstroLab 4, a new corrected version will be post tomorrow (saturday). hi Marcel, I use it (with my Effemeridi program, that I'll check soon for compatibility). I din't know about the "30 char" limit... Is it sure? Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
04-22-2016, 02:03 PM
(This post was last modified: 04-22-2016 02:23 PM by Marcel.)
Hi Salvo!
I am not sure but after the installation of the new FW, some functions of AstroLab declare error at line where I see the function "HeliocentricEclipticalCoordinates". I decide to change it to "HeliocentricEclipticalCoor" and after that AstroLab work fine... I check and reduce all the functions names to a lenght<30 and now everything is OK. Pleasure to write to you again! Marcel |
04-22-2016, 02:29 PM
I think it is 31.
Basically, we started enforcing a bit more checking on things to ensure avoidance of problems. Things will error now if the conflict with built in variables, exceed lengths, etc. TW Although I work for HP, the views and opinions I post here are my own. |
04-22-2016, 02:36 PM
(04-22-2016 02:03 PM)Marcel Wrote: ... (04-22-2016 02:29 PM)Tim Wessman Wrote: I think it is 31. thank you both. I'll review soon Effemeridi (I think this one is the only or one of a few set of programs of mine with "long" names... Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
04-22-2016, 02:58 PM
Hi Tim and Salvo!
Thank you Tim for your help! Nice work... I also find that if I format a word in the Note app of AstroLab on the real calculator, the virtual calculator crash when I start the program containing this note after the transfert.. I will continue to experiment this thing... Marcel |
