help with hpppl
05-07-2016, 12:30 PM
help with hpppl
hi there!
I was inspired by some threads in the forums and being really excited about the patch nots (cas now loves hpppl) I decided to dig out my prime and start over. Well, it seems that local variables do not interact with cas like I expected, so I do really need advice. I tried to make this program. It would make me use the prime at work for the first time :-) Code:
I always get {0,0} as a result. What am I doing wrong to pass local variables and data to the cas? Help is very much appreciated. A simpler version that solves R+C=var would be Code:
Maybe the simplest approach shows my error most easily. Thanks guys! |
05-07-2016, 04:55 PM
RE: help with hpppl
Add a local variable x:
LOCAL REAL,IMA,N,W,R,C,x; Store the result of the solve operation in x and add quotes around R and C x:=CAS.solve({REAL=ZIN_REAL,IMA=ZIN_IMA},{'R','C'}); then RETURN x; And you get {{0,_(1013904223)}} for an answer. I don't know if it's the right answer, but it's a start. Here's the code with the suggested changes: Code:
-road |
05-07-2016, 05:00 PM
RE: help with hpppl
Changing N, W, R, and C to lower case (n, w, r, c) may help also.
-road |
05-07-2016, 05:15 PM
RE: help with hpppl
(05-07-2016 05:00 PM)roadrunner Wrote: Changing N, W, R, and C to lower case (n, w, r, c) may help also. yes, 'cause in Home the calc uses the uppercase as default variables, so NW means N*W... non with nw that gives "Error: syntax error". Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
05-08-2016, 01:52 AM
(This post was last modified: 05-08-2016 01:57 AM by roadrunner.)
RE: help with hpppl
leprechaun,
I had some more time to look at your code. This seems to do what you need: Code: ZIN_F:=4000000; try it and see if it gives you good results. -road |
05-08-2016, 06:41 PM
(This post was last modified: 05-08-2016 06:44 PM by leprechaun.)
RE: help with hpppl
Thanks guys!
I will study your code and try to understand my faults later. atm I am on the way back home. After the last patch time I'll fall in love with the prime. I promise and I will do my very best! :-) I HAD that program running on the prime some time ago in cas as following: (rea,ima)->BEGIN LOCAL realteil,imagteil,w,n; w:=2*π*4000000.; n:=1+w^2*c^2*r^2; realteil:=r/n; imagteil:=w*c*r^2/n; solve({realteil = rea,imagteil = ima},{r,c}); END; But I would like to benefit from the comfort of hpppl and I must say I WANT to understand what HP designed and what they had in mind when doing so. I do not want to fail with the prime. I am more into low level code and that might be the reason for my constant problems with the machine. |
05-08-2016, 06:46 PM
(This post was last modified: 05-08-2016 07:58 PM by leprechaun.)
RE: help with hpppl
But a quick look at roadrunner's code looks like you still have to deal with strings when mixingmcas and hpppl? I did hope that that part had evolved after reading the patch notes.
A quick test Gives [undef]. Any suggestions? |
05-09-2016, 12:14 AM
RE: help with hpppl
You're right!
I ran down to my kid's computer that is running 10077 and I get [undef] I go up to my comuter that is running 8151 and get an answer. I'll have to determine what's going on with that later. Right now the kids want there computer back. -road |
05-09-2016, 05:09 AM
RE: help with hpppl
Home/Cas interraction has changed with the 10077 version. It has changed to make it better, but it might have side effect that affect you.. Attached is a file that describes the current 'system' in detail. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
05-09-2016, 05:14 AM
RE: help with hpppl
Thank you for your efforts. For me adding some cas code to simple programs seems to be unavoidable and it happens sooner or later.
Quote: roadrunner Wrote: That was something that made me think about in the car this morning. What the program does is using a locally declared variable R for the cas call. Ok i might switch to lower case variables if that helps, but what I do not understand is: it does use a local variable which is something different that the HOME/R built-in variable... I think. Patch notes say "mproved interaction between CAS functions and HPPPL program. CAS functions can now access directly HPPPL local variables as expected". Isn't that exactly what my problem is about? lokking forward to getting new information about what I am doing wrong. |
05-09-2016, 06:48 AM
(This post was last modified: 05-09-2016 07:00 AM by leprechaun.)
RE: help with hpppl
I have tried the simplest code I could think of. No variables passed to the program. Nothing sophisticated. Results are commented in the code. The [undef] result is contained as one could expect.
This is no special coding and similar tasks will arise sooner or later to everyone. What changes in the firmware might cause the result? How should I code a problem like the original one and what did I get wrong with the patch note about finally integrating the cas into home?? Code:
P.S: F1:="B^2=10"; RETURN solve(F1,B); Does the trick, BUT(!) that is really unintuitive and no improvement and I am sure that there must be an other way. And second it is totally different from what the other posters suggested i.e. useing lower case letters.... because F1:="b^2=10"; solve(F1,b) in all variants fail with syntax errors. So I am curious about what is going on. |
05-09-2016, 12:55 PM
RE: help with hpppl
(05-09-2016 05:09 AM)cyrille de brébisson Wrote: Attached is a file that describes the current 'system' in detail.Thanks Cyrille. That document explains everything! Leprechaun, Here is a modified program that works with version 10077: Code: ZIN_F:=4000000; The variables r and c being declared as local is what was messing thing up. -road |
05-09-2016, 01:25 PM
RE: help with hpppl
(05-09-2016 06:48 AM)leprechaun Wrote: I have tried the simplest code I could think of. No variables passed to the program. Nothing sophisticated. Results are commented in the code. The [undef] result is contained as one could expect. My suspicion is that you do not have a clear understanding of variable types and their priorities. B is a system-wide variable whereas b is generally not (it must be created). Moreover, when you use F1:="b^2=10" this will likely generate and internal syntax error if b does not already exist as a variable. http://www.hpmuseum.org/forum/thread-215.html Graph 3D | QPI | SolveSys |
05-09-2016, 05:35 PM
RE: help with hpppl
Thank you for your comments.
The whole system is not easy to manage. At least to me far from being intuitive. Personally I solved my problem with a cas-function that was called by the input function, but I disliked that. I will try to understand cyrille's paper and the proposed code. Frustrating thing ;-) |
05-09-2016, 05:53 PM
(This post was last modified: 05-09-2016 06:03 PM by Tim Wessman.)
RE: help with hpppl
(05-09-2016 05:35 PM)leprechaun Wrote: Thank you for your comments. Well, there is one more piece to be taken at some point (hopefully in the not too distant future) - the ability to declare a variable as a symbolic identifier. That should be the last step to allowing clean access to the CAS. Something like this is kind of the direction I'm thinking. LOCAL x:=id(x); //or possibly LOCAL x=id('x'); x=CAS.int(x^2-2,x); print(x); return x; or similar would then work like you'd think. Should look familiar to anyone who's used SymPy I'd think. What really happened in this last release is that using local variables for function calls behaves in a consistent manner rather then automatically replacing the variables with content on evaluation. The limitation of "the variable still contains some content - even if it is 0" is still there. Hence the thinking for the future improvement I mused about above. TW Although I work for HP, the views and opinions I post here are my own. |
05-28-2016, 01:17 AM
RE: help with hpppl
(05-09-2016 12:55 PM)roadrunner Wrote:(05-09-2016 05:09 AM)cyrille de brébisson Wrote: Attached is a file that describes the current 'system' in detail.Thanks Cyrille. That document explains everything! Thanks Roadrunner, your code really helped. |
