(12C) Modulus
07-15-2016, 02:37 AM (This post was last modified: 07-15-2016 02:38 AM by Eddie W. Shore.)
(12C) Modulus
HP 12C Modulus
This program takes the modulus of two numbers:
Y MOD X = X * FRAC(Y/X)
In this program, X > 0 and Y > 0.
STEP    CODE            KEY
01    10             ÷
02    43, 36    LST x
03    34             X<>Y
04    43, 24    FRAC
05    20             *
06    43, 33, 00    GTO 00
Input: Y [ENTER] X [R/S], Result: Y MOD X
Test 1: 124 MOD 77 = 47
Test 2: 3862 MOD 108 = 82
07-15-2016, 06:32 PM (This post was last modified: 07-15-2016 07:00 PM by Dieter.)
RE: (12C) Modulus
(07-15-2016 02:37 AM)Eddie W. Shore Wrote:  This program takes the modulus of two numbers:
That's not a good idea: roundoff errors will spoil the results.
Consider your two examples:
124 mod 77 does not return 47 but 46,99999997
3862 mod 108 does not return 82 but 82,00000008
That's why you better use the relation y mod x = y – x * INT(y/x) instead.
01-       34  x<>y
02-     44 0  STO 0
03-       34  x<>y
04-       10  ÷
05-    43 36  LSTX
06-       34  x<>y
07-    43 25  INTG
08-       20  x
09-  44 30 0  STO- 0
10-       33  R↓
11-     45 0  RCL 0
12- 44,33 00  GTO 00
That's a bit longer and requires one data register, but it works.
The R↓ in line 11 was included to preserve the initiial values in T and Z.
Dieter
07-18-2016, 10:12 PM
RE: (12C) Modulus
01-       34  x<>y
02-     44 0  STO 0
03-       34  x<>y
04-       10  ÷
05-    43 36  LSTX
06-       34  x<>y
07-    43 25  INTG
08-       20  x
09-  44 30 0  STO- 0
10-       33  R↓
11-     45 0  RCL 0
12- 44,33 00  GTO 00
Dieter
Here's a routine I wrote about a month ago. One step longer, but it uses only the stack and Last-X register. I wrote it for the HP-38C, but the steps are exactly the same for the HP-12C (but the keycodes would be different). For the two examples given by Dieter, it gets the right results.
01-     x<>y
02-     Enter
03-     Enter
04-     R↓
05-     R↓
06-     R↓
07-     ÷
08-     LSTX
09-     x<>y
10-     INTG
11-     x
12-     -
13-     GTO 00
Bob
07-21-2016, 11:36 PM
RE: (12C) Modulus
From "ENTER: Reverse Polish Notation Made Easy", Jean-Daniel Dodin / Keith Jarett, (pg 115):
01-       36 ENTER
02-       36 ENTER
03-       30 -
04-       33 R↓
05-       34 x<>y
06-    43 36 LSTx
07-       10 ÷
08-    43 25 INTG
09-       20 x
10-       30 -
11- 43 33 00 GTO 00
07-25-2016, 09:17 AM (This post was last modified: 07-25-2016 10:10 AM by Dieter.)
RE: (12C) Modulus
(07-18-2016 10:12 PM)bshoring Wrote:  Here's a routine I wrote about a month ago. One step longer, but it uses only the stack and Last-X register.
Great. In the meantime I got exactly the same solution. Many/most other HPs offer a R↑ which can replace the three consecutive R↓, making the program even shorter.
(07-21-2016 11:36 PM)RobertM Wrote:  From "ENTER: Reverse Polish Notation Made Easy", Jean-Daniel Dodin / Keith Jarett, (pg 115):
That's a nice one as well. Here's another 10/11 step solution:
01 ENTER
02 ENTER
03 -
04 +
05 /
06 LastX
07 x<>y
08 INT
09 x
10 -
11 GTO 00 or RTN
The first four lines copy the content of Y to Z and T while X and Y are left unchanged.
However, all these solutions destroy the stack, while the version I initially posted keeps the values of Z and T. That's why it requires one data register. I wonder if it is possible to do it only with the stack, i.e. without a data register, while Z and T are still preserved.
Here's another challenge: what about returning y mod x as well as y div x (i.e. the integer quotient of y and x). There are many applications where both values are required at the same time. That's why I once suggested a DIVMOD command for the 34s that returns these two values.
Now, what do you think ?-)
Dieter
07-25-2016, 09:46 AM (This post was last modified: 07-29-2016 05:40 PM by Dieter.)
RE: (12C) Modulus
(07-25-2016 09:17 AM)I Wrote:  Here's another challenge: what about returning y mod x as well as y div x (i.e. the integer quotient of y and x). There are many applications where both values are required at the same time. That's why I once suggested a DIVMOD command for the 34s that returns these two values.
I just realized that the code in the previous post can be extended easily to return both values at the same time – it's just two more steps:
01 ENTER
02 ENTER
03 -
04 +
05 /
06 LastX
07 x<>y
08 INT
09 ENTER
10 R↓
11 x
12 -
13 GTO 00 or RTN
The same can be done with the Dodin/Jarett program by inserting ENTER R↓ between step 08 and 09.
The above version returns the remainder in X and y div x in Y.
3782 [ENTER] 72 [R/S]
=>  38   [X<>Y]   52
There even is a third useful result:
[LastX] => 3744
The largest number ≤ Y that is divisible by X.
Dieter
07-28-2016, 11:01 PM (This post was last modified: 07-28-2016 11:02 PM by bshoring.)
RE: (12C) Modulus
01 ENTER
02 ENTER
03 -
04 +
05 /
06 LastX
07 x<>y
08 INT
09 ENTER
10 R↓
11 x
12 -
13 GTO 00 or RTN
The above version returns the remainder in X (and Z) and y div x in Y (and T).
=>  38   [X<>Y]   52
[LastX] => 3744
Dieter
Nice program.
When I run 3782 [ENTER] 72 [R/S],
it leaves 38 in X only and 52 in Y, Z, & T.
Works for me.
Bob
07-29-2016, 05:39 PM (This post was last modified: 07-29-2016 05:43 PM by Dieter.)
RE: (12C) Modulus
(07-28-2016 11:01 PM)bshoring Wrote:  When I run 3782 [ENTER] 72 [R/S],
Hmmm... you're right. I am sure I had a version were the two results were in X and Z resp. Y and T.
Anyway – I now corrected my previous post. Thank you for your feedback.
Dieter
