CAS: solve solutions
08-25-2016, 07:18 PM
(This post was last modified: 08-26-2016 11:43 AM by compsystems.)
hp-prime
solve(((x+5)*e^x) = ((x+5)*e^(2*x))) [ENTER] returns -> {0} // one answer why the CAS returns only one answer? Expanded form expand( (x+5)*e^x) = (x+5)*e^(2*x) ) [ENTER] returns -> x*e^x+5*e^x = x*e^(2*x)+5*e^(2*x) mathematica returns 3 answers https://www.wolframalpha.com/input/?i=(x...*e%5E(2*x) [ENTER] returns -> x = -5 // real solution x = 0 // real solution x = 2*π*i*n where n ∈ Z // a symbolic answer =] |
08-25-2016, 08:22 PM
RE: CAS: solutions
I tried it (with different parentheses) and, after a cryptic warning, got the same answer Mathematica did.
08-26-2016, 07:49 AM
RE: CAS: solve solutions | |||
08-26-2016, 01:12 PM
Have you select Complex? (CAS settings)
I have the same answer as Steve (10077) — Dirk Hartland |
08-26-2016, 01:17 PM
but the answer (-5) is not complex output is real number
08-26-2016, 01:50 PM
Have you try it?
Deselect complex, answer is {0} Selected complex, answer is {-5 0} — Dirk Hartland |
08-26-2016, 03:20 PM
Specifying a range works here as well.
-10..10 returns -5,0 also Perhaps bernard can shed some light as to why it only finds the one solution in this case without specifying a range. TW Although I work for HP, the views and opinions I post here are my own. |
08-26-2016, 10:07 PM
(08-26-2016 07:49 AM)retoa Wrote: Hi Steve! solve((x+5)*e^x = (x+5)*e^(2*x),x) (note that on the calculator I didn't have the parentheses around the 2*x term since in textbook form it was obvious that the whole term was part of the power of e) My settings were Exact on, Complex on, Use Sq on, Use i off, Principal off and increasing off. The warning I got was: Warning: solving x in equation
-x*(e^x)^2+x*e^x-5*(e^x)^2+5*e^x=0 Anybody know what this warning means? |
08-26-2016, 10:37 PM
Right, with complex on it gives both answers.
Does it need to use complex numbers for some substitution? |
08-27-2016, 06:16 AM
With the current version of Xcas I get -5 and 0 for solve((x+5)*e^x = (x+5)*e^(2*x),x). I don't know why it does not work for older versions of giac.
