KEYTIME on the 48GX?
08-30-2016, 05:18 AM
I type so fast on my 48GX that it occasionally misses a keystroke. What is the equivalent of KEYTIME on the 48GX that will allow me to shorten the key debounce time?
Thanks. |
08-30-2016, 05:27 AM
RE: KEYTIME on the 48GX?
There is no KEYTIME equivalent on the 48GX. And it should not be needed. KEYTIME was introduced because the 49 had quite a lot of bounces on the keyboard, and keyboards specs that were not very well bounded (ie, a large distribution). The 48 does not suffer from this problem and the debounce time on it is less than 10ms if I remember well. If you can type faster that that, you surly are super, super fast! But the most likely scenario is that you do think/feel/assume that you are pressing the keys, but they are not registering electrically. This can be especially true if the keyboard is old, tired or has dust/crud in it... Sorry that I do not have a better news for you. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
08-30-2016, 05:38 AM
Thank you for the information!
James W. |
08-30-2016, 05:49 AM
Also, the 48 has a good keyboard buffer. even if you really manage to type so fast, it remembers all strokes and works them out one by one as soon as you stop typing.
08-30-2016, 08:29 AM
And with SpeedUI, you'll gain from the fastest key handling routines inside my System Outer Loop replacement;-)
-- Ray |
08-30-2016, 08:48 AM
Thank you Ray and damaltor!
--James W. |
08-31-2016, 05:30 AM
Actually, the 48, like the 49 have the same 15 key buffer.... Type any faster and you will hear a beep... Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
09-01-2016, 01:15 PM
(This post was last modified: 09-01-2016 01:18 PM by RMollov.)
(08-30-2016 05:18 AM)JDW Wrote: I type so fast on my 48GX that it occasionally misses a keystroke. What is the equivalent of KEYTIME on the 48GX that will allow me to shorten the key debounce time?So you are Yngwie J. Malmsteen on a HP48. Or Baron Munchausen with a lot of spare time, but not enough to briefly check TFM. |
09-01-2016, 01:28 PM
(09-01-2016 01:15 PM)RMollov Wrote: So you are Yngwie J. Malmsteen on a HP48. Or Baron Munchausen with a lot of spare time, but not enough to briefly check TFM. Harsh! But funny, so you get a pass. Would not have guessed any forum members are Yngwie Malmsteen fans... I'm not particularly a fan of his music, but I am a fan of his speed. --Bob Prosperi |
