HP-41 port blocks available ?
09-07-2016, 02:14 PM
I know there were some of these made a couple of years ago. Does anyone have a source for these? I'm thinking 10-15 of them? Help?
09-07-2016, 02:48 PM
RE: HP-41 port blocks available ?
(09-07-2016 02:14 PM)Gene Wrote: I know there were some of these made a couple of years ago. Does anyone have a source for these? I'm thinking 10-15 of them? Help? Have a look here Gene. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
09-07-2016, 02:54 PM
Thanks, but I guess I should have been more specific. :-)
The port block I meant was the copper block internal to the HP 41 at the top that the modules plug into and are visible from the top end of the HP 41 with no modules plugged in. The same piece of copper goes into the battery compartment and often gets corroded. I remember that someone had some of *these* port blocks made and wondered if any were still around. Massimo, thank you for your reply even if it wasn't what I was looking for. It's that type of spirit here that helps everyone! |
09-07-2016, 03:23 PM
RE: HP-41 port blocks available ? | |||
09-07-2016, 03:26 PM
(09-07-2016 02:54 PM)Gene Wrote: Thanks, but I guess I should have been more specific. :-) So you meant Diego's I/O block ;) Note: the site seems offline by now. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
09-07-2016, 03:31 PM
Oops, yes. If anyone communicates with Diego, ask him to check in here. :-) I've sent him an email.
09-07-2016, 03:38 PM
(This post was last modified: 09-07-2016 03:40 PM by Massimo Gnerucci.)
(09-07-2016 03:31 PM)Gene Wrote: Oops, yes. If anyone communicates with Diego, ask him to check in here. :-) I've sent him an email. I just sent him an e-mail about his website, too. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
09-07-2016, 04:39 PM
09-07-2016, 04:47 PM
(09-07-2016 03:26 PM)Massimo Gnerucci Wrote: So you meant Diego's I/O block FYI - It's up for me, same as usual. --Bob Prosperi |
09-07-2016, 04:58 PM
(This post was last modified: 09-07-2016 05:12 PM by Massimo Gnerucci.)
(09-07-2016 04:47 PM)rprosperi Wrote:(09-07-2016 03:26 PM)Massimo Gnerucci Wrote: So you meant Diego's I/O block WTF? It seems you're right: I just checked on http://downforeveryoneorjustme.com Time to check my DNS... (or provider filters) UPDATE Name resolution OK, trace in 25 hops, I get a timeout for http. Trying proxies I get: OK from HK and GER, timeout from USA and "Acceso bloqueado por seguridad. Rogamos contacte con su proveedor de hosting // Access denied by security. Please contact your hosting provider" from Romania... Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
09-07-2016, 08:20 PM
(09-07-2016 04:58 PM)Massimo Gnerucci Wrote: I just checked on http://downforeveryoneorjustme.com Didn't know that site, thanks Massimo. Here's another, with a bit more info, but same basic idea: http://www.isitdownrightnow.com/ --Bob Prosperi |
09-07-2016, 08:32 PM
(09-07-2016 08:20 PM)rprosperi Wrote:(09-07-2016 04:58 PM)Massimo Gnerucci Wrote: I just checked on http://downforeveryoneorjustme.com Yeah, there are a few of them. Didn't know this one: my time to say thank you, Bob. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
09-12-2016, 01:06 AM
