Auto power Off
10-30-2015, 09:23 AM
Auto power Off
Bonjour
Il arrive souvent que ma Prime (HWA 8151)
s'éteigne à la fin de l'exécution d'un programme,
et quelques fois pendant l'exécution sur une instruction MSGBOX.
Lorsque je la rallume la machine revient au même état comme si
elle s'était mise en veille.
D'autres personnes ont-elles déja observé ce comportement ?
Hello
Often my Prime (HWA 8151)
turn off at the end of the program execution ,
and sometimes while running on a MSGBOX statement.
When I turn back the machine returns to the same state as if
she had paused .
Other persons have already observed this behavior?
Sorry for my english
11-05-2015, 05:18 PM
RE: Auto power Off
Ma machine serait-elle la seule à avoir ce symptome ?
Elle l' a depuis les premières ROM.
My machine would the only one to have this symptom ?
It has itself since the first ROM .
11-05-2015, 08:27 PM
RE: Auto power Off
(11-05-2015 05:18 PM)Tyann Wrote:  Ma machine serait-elle la seule à avoir ce symptome ?
This has been observed before in other programs that are run for a long time. See for example, post #7 in http://hpmuseum.org/forum/thread-379.html
Graph 3D | QPI | SolveSys
09-10-2016, 10:30 AM
RE: Auto power Off
Bonjour
Depuis la mise à jour 10637, ce problème semble avoir disparu.
Hello
Since the update 10637 , this problem seems to have disappeared .
09-12-2016, 06:19 AM
RE: Auto power Off
(09-10-2016 10:30 AM)Tyann Wrote:
(11-05-2015 08:27 PM)Han Wrote:  This has been observed before in other programs that are run for a long time. See for example, post #7 in http://hpmuseum.org/forum/thread-379.html
Bonjour
Hello
You can set the auto shutoff system variable TOff to higher values (standard 5 minutes).
http://www.hpmuseum.org/forum/thread-2815.html
regards
HP 33C 34C 11C 41CX 12C 15C HP71B 35s 50g Prime Rev. A, C, D. DM 41X, 42. TI 58C, 59, 74, 92-II, Voyage 200, nspire CX II-T, Sanyo ICC 82D and more
09-17-2016, 07:09 AM
RE: Auto power Off
(09-12-2016 06:19 AM)Wolfgang Wrote:
(09-10-2016 10:30 AM)Tyann Wrote:  Bonjour
Hello
regards
Bonjour
Quelques jours après le problème est revenu.
Vous suggérez que en augmentant la valeur de Toff, on peut résoudre
celui-ci ?
Pourquoi pas, je vais faire quelques essais.
Merci.
Hello
A few days after the problem came back.
You suggest that increasing the value of Toff can be solved
this one ?
Why not, I'll do some tests .
Thank you.
