WP-34S --> WP-30S: Reduce / Reuse / Repurpose
03-03-2014, 01:37 PM
Post: #41
RE: WP-34S --> WP-30S: Reduce / Reuse / Repurpose
(02-06-2014 04:05 AM)Sanjeev Visvanatha Wrote: BIN File for anyone interested in flashing a 20B/30B into this basic RPN: Gene: Hello Sanjeev! Is this BIN file still the good one for the WP-30S here? I'm looking to flash one of my 30b units and want to see if this is the right version and layout. Thanks... |
03-03-2014, 05:05 PM
Post: #42
Hi Gene,
The file is out if date, but the layout hasn't changed. I will post new BIN file tonight. It fixes the SHOW suggestion made in this thread. -- Sanjeev Visvanatha |
03-04-2014, 04:19 AM
Post: #43
03-04-2014, 01:58 PM
Post: #44
(03-03-2014 05:05 PM)Sanjeev Visvanatha Wrote: It fixes the SHOW suggestion made in this thread. I think I made that suggestion, although others may also have done so. In any case, any chance to look at my other request, implementation of bit's two-line display? Dave - My mind is going - I can feel it. |
03-04-2014, 10:57 PM
Post: #45
(03-04-2014 01:58 PM)Jeff O. Wrote: I think I made that suggestion, although others may also have done so. In any case, any chance to look at my other request, implementation of bit's two-line display?Jeff: Yes, it was your suggestion! I have not had a chance to look at adding the two-line display. I think it is a good suggestion. I have no timeframe on when I could add it. It makes a good user option for 31S as well. The 30S was a sort of playground for me, and it does not have the same maturity as 31S currently has. On that note, based upon the work that I am doing for 31S, one possibility I see is to make a compile option so that the 30S/31S codebase can be shared, with the key layout differing between the two. -- Sanjeev Visvanatha |
03-04-2014, 10:59 PM
Post: #46
(03-04-2014 10:57 PM)Sanjeev Visvanatha Wrote: On that note, based upon the work that I am doing for 31S, one possibility I see is to make a compile option so that the 30S/31S codebase can be shared, with the key layout differing between the two. That sounds good. I was thinking about the 2-line display for the 31S too. I'm okay with it being a compile option. Not sure what Walter thinks about it for the released version. -Jonathan |
User(s) browsing this thread: 16 Guest(s)
