HHC 2016 RPN contest is now live
09-20-2016, 08:48 PM
RE: HHC 2016 RPN contest is now live
One more trick, two steps less :
01:        [cplx]STO J
02:        XEQ a
03:        DEC K
04:   a::  [cplx]RCL J
05:        SDR 001
06:        IP
07:        MIN
08:        [Sigma] 00
09:        x<> I
10:        RCL- I
11:        RTN
12:        LBL 00
13:        (-1)[^x]
14:        RCL K
15:        RCL Z
16:        COMB
17:        *
18:        RCL J
19:        # 010
20:        RCL* T
21:        -
22:        RCL K
23:        DEC X
24:        STO+ Y
25:        COMB
26:        *
27:        END
09-21-2016, 01:09 PM (This post was last modified: 09-21-2016 01:10 PM by Gene.)
Here's a link to a fast solution generator on the web.
Change N and SUM in the code here:
// Driver program
int main()
int n = 3, sum = 5;
cout << finalCount(n, sum);
return 0;
and click RUN.
http://code.geeksforgeeks.org/index.php
09-21-2016, 05:21 PM
(09-20-2016 06:41 AM)Werner Wrote:
(09-19-2016 01:47 PM)Gerson W. Barbosa Wrote:  If n < 10, then a 7-step would do the job:
You mean, five?
001- LBL A
002- DEC X
003- DEC Y
004  STO+ Y
005- COMB
006- END
Thanks for the improvement! I'm glad I didn't post the previous 11-step version :-)
001- LBL A
002- cENTER
003- +
004- DEC X
005- Γ
006- x<>y
007- Γ
008- /
009- Rv
010- Γ
011- /
012- END
10-05-2016, 05:00 PM (This post was last modified: 02-06-2024 06:31 PM by Jeff O..)
This is a little late to the party, but better late than never, I guess.
As is my usual practice, I did not look at the discussion of solutions to the HHC 2016 RPN Programming Contest until I decided that I was satisfied with my own efforts or reached a dead end. I did look at the thread before the embargo was lifted, and saw Pauli's post that he had a 32 step solution that ran instantaneously. Upon seeing that, I figured there must be some simple(?) technique to solve the challenge of which I was not aware. But since it is fun to attack Gene's challenges, I went ahead and pursued my first thought, which was of course, brute force: form the lowest k-digit number, find the sum of its digits, see if it equals the target sum, if so, increment a counter, if not, don't increment the counter, then increment the k-digit number and repeat up to the highest k-digit number. I suspected that it might take a long time to run on a 34s for some inputs, but I went ahead anyway, and was able to get a program up and running fairly quickly. It took about 75 seconds to return 35 as the answer to f(4,5), Gene's explanatory example. Based on that timing, figuring about a factor of 10 in execution time for each additional digit, I did not want to run it on even a 5 digit number. The next day, I entered the program into the wp34s emulator on my PC. It of course gave much quicker results, so I was able to check Gene's (valid) sample cases. Feeling brave, I turned the emulator loose on f(9,56) and let it run overnight. I was not at the PC when it finished, but my best guess is that it took 10 to 12 hours to return 9,286,233. In case anyone is interested, here is the code for that brute force program:
001    LBL"HHC"
002    STO 00       store target sum n in 00
003    x<> Y        swap
004    10^x         Form maximum k-digit number +1
005    ROUNDI       make sure it is an integer
006    STO A        store max k-digit+1 number in A
007    SDR 001      Form minimum k-digit number
008    STO B        store in B
009    CLx          clear x
010    STO C        store zero in C, count of digit sums n in k-digit number
011    CLx          clear x (target of BACK in step 030)
012    STO D        store zero in D, sum of digits in current number
013    RCL B        recall current number whose digits are being summed
014    SDR 001      divide by 10
015    ENTER        enter
016    FP           fractional part
017    STO- Y       subtract fractional part from current number divided by 10
018    SDL 001      multiply fractional part by 10
019    STO+ D       add to D, sum of digits of current number
020    Rdn          roll down
021    x=/=0?       is number being summed not equal 0?
022    BACK 008     if not, loop back to sum next digit
023    RCL D        when done, recall sum of digits
024    x=/=? 00     sum of digits not equal to target sum?
025    SKIP 001     if not, skip
026    INC C        if equal, increment count of digit sums equal to n
027    RCL A        recall maximum k-digit number + 1
028    INC B        increment current number whose digits to be summed
029    x=/=? B      next number not equal maximum k-digit+1?
030    BACK 019     if not, go back to sum digits of next no. and check sum
031    RCL C        if equal, recall count of digits sums equal to n
032    END          done
At this point, my suspicions were of course confirmed that this was not the optimal approach to this problem, so I did not attempt to refine the program to reduce the number of steps, registers used, etc. To move forward, I decided to see if I could discern some sort of pattern. I started building a table which presented the counts of digit sums for number of digits vs. desired sum of the digits, like this:
sum of            Number of Digits
Digits  1     2     3     4     5     6     7     8     9
  1     1     1     1     1     1     1     1     1     1
  2     1     2     3     4     5     6     7     8     9
  3     1     3     6    10    15    21    28    36    45
  4    ...
I was able to figure out the answers for the simple values by hand, used my above program on the emulator for up to 6-digit values, and eventually used Gene's calculation source which he kindly provided directly to me to extend the above table in excel. In an effort to make a long story short, I was eventually able to deduce that:
f(k,n) = f(k-1,n) + f(k,n-1) - f(k-1,n-10)
Below is a screenshot of part of part of an excel table implementing the above formula. As an example, the value highlighted in blue, f(7,12), can be seen to be equal to the value highlighted in red, f(6,12) plus the value highlighted in yellow, f(7,11) minus the value highlighted in green, f(6, 2). The two cells with the little red triangles in the corners must be initialized to 1. The cells highlighted in orange must be forced to be zero. Beyond those forced values, the formula produces all of the other correct values in the table.
[Image: attachment.php?aid=3999]
With the above as an aid, I was eventually able to implement the method in a wp34s program. I have a working 63-step program on a physical wp34s that returns correct values for 9-digit numbers in about 3 seconds maximum. It could be extended to handle at least up to 11-digit arguments* within the memory confines of a wp34s, it would just run a little slower. In case it is not obvious, the method requires the current sum plus the previous 101 values to be retained in memory. I used local registers with rolling pointers to do that. (There is probably a more effective way of updating the pointers for each iteration, but I quit with what worked.) I forced the zeros required in the left-most column every 10th sum instead of calculating that sum by the formula using an inner loop. Here is the listing:
001    LBL"HHC"     Comments
002    DEC X        subtract 1 from target sum n
003    SDL 001      ten times (target sum -1)
004    +            add number of digits to form count of iterations, C
005    STO 02       store count of iterations in 02
006    REGS 010     set number of regs to low value to free space for 102 local regs
007    #112         constant 112
008    STO A        store initial r000 pointer value
009    #113         constant 113
010    STO B        store initial r001 pointer value
011    #122         constant 122
012    STO C        store initial r010 pointer value
013    #213         constant 213
014    STO D        store initial r101 pointer value
015    #002         constant 002
016    STO 03       store initial 10 loop counter in 03
017    LocR 102     create 102 local registers
018    #001         constant 001
019    STO-> A      store initial 1 in R01
020    STO .11      store initial 1 in R11
021    LBL 01
022    DSE 02       decrement iteration count, skip when zero
023    SKIP 002
024    RCL-> A      Recall final sum
025    RTN          finished
026    DEC A        decrement r000 pointer
027    DEC B        decrement r001 pointer
028    DEC C        decrement r010 pointer
029    DEC D        decrement r101 pointer
030    #111         constant 111
031    x=/=? A      is r000 pointer not equal to 111?
032    SKIP 003     if not, skip to check r001 pointer
033    #213         if r000 pointer is equal to 111, set pointer to max local reg
034    STO A        store new r000 pointer
035    SKIP 014     done updating, skip to calculate next count
036    x=/=? B      is r001 pointer not equal to 111?
037    SKIP 003     if not, skip to check r011 pointer
038    #213         if r001 pointer is equal to 111, set pointer to max local reg
039    STO B        store new r001 pointer
040    SKIP 009     done updating, skip to calculate next count
041    x=/=? C      is r010 pointer not equal to 111?
042    SKIP 003     if not, skip to check r010 pointer
043    #213         if r010 pointer is equal to 111, set pointer to max local reg
044    STO C        store new r010 pointer
045    SKIP 004     done updating, skip to calculate next count
046    x=/=D?       is r101 pointer not equal to 111?
047    SKIP 002     if not, done updating, skip to calculate next count
048    #213         if r101 pointer is equal to 111, set pointer to max local reg
049    STO D        store new r101 pointer
050    #010         constant 010
051    x=/=? 03     check if loop count equal 10
052    SKIP 004     if no, proceed to calculate sum
053    CLx          if count is multiple of 10…
054    STO->A       ...force current sum to be zero
055    STO 03       reset loop count to zero
056    SKIP 004
057    RCL->B       recall r001
058    RCL+->C      add r010
059    RCL- ->D     subtract r101
060    STO->A       store in r000
061    INC 03       increment 10 loop counter
062    GTO 01
063    END
Disclaimer - I do not claim that the above method is anything special, certainly still brute force compared to the insightful methods presented in the posts above. But since it is a different approach that produces correct results, I thought I'd go ahead and present it.
* - 10 digits would require 112 local registers, 11 digits would require 122, 12 digits would require 132, and 13 digits would require 142 local registers. The manual states that there can be up to 144 local registers created, but when I tried to extend past 11 digits, i.e., tried to enter LocR 132 or LocR 142, the instruction defaulted to LocR 013 or LocR 014. I've tried to read all instructions regarding creation and use of local registers in the manual, but have still not figured out what I am doing wrong.
Edit - saw a simple improvement to the brute force program, could not stop myself from revising it.
Edit 2 - ditto for the 2nd program, also implemented a slightly optimized routine to update the pointers. Same number of steps but should run slightly faster.
Dave - My mind is going - I can feel it.
10-05-2016, 06:56 PM
Excellent Jeff! That's great!
10-06-2016, 11:42 AM
(10-05-2016 06:56 PM)Gene Wrote:  Excellent Jeff! That's great!
Thanks Gene, another fun and exciting challenge! Can't wait until next year!
10-06-2016, 11:47 AM
Jeff,
An very interesting approach to the problem. Kind of halfway between brute force and my analytic solution.
Pauli
10-06-2016, 04:26 PM
(10-06-2016 11:47 AM)Paul Dale Wrote:  Jeff,
Pauli
Pauli,
Any analysis on your part as to why it works? I was fairly shocked that it did, even producing the proper results when the counts are decreasing for sums over half of the maximum for a given number of digits, even producing the zeros for the counts of sums over the maximum. I thought I'd have to force those cases.
Also, any idea why I cannot create more than 127 local registers?
Jeff
10-07-2016, 06:49 AM
Well, it is easy to see that
f(k,n) = sum(i=0..9,f(k-1,n-i))
(which is what I used in a quick RPL program to verify the results)
so
f(k,n-1) = sum(i=0..9,f(k-1,n-1-i))
Naturally the two sums coincide except for the first and last elements, so
f(k,n) = f(k,n-1) - f(k-1,n-10) + f(k-1,n)
But I never thought of that, either ;-)
Cheers, Werner
10-07-2016, 02:03 PM
(10-07-2016 06:49 AM)Werner Wrote:  ....But I never thought of that, either ;-)
Cheers, Werner
Well, I did not think of it, just managed to stumble across it. Once found, the fun part was implementing on the 34s.
Jeff
10-14-2016, 07:48 PM (This post was last modified: 02-13-2024 01:50 PM by Jeff O..)
(10-06-2016 04:26 PM)Jeff O. Wrote:  Also, any idea why I cannot create more than 127 local registers?
Just to close the loop on this, I consulted with Marcus and found that creation of more than 127 local registers must be done via indirection. So, to set 144 local registers one must do as follows:
#144
LocR->X
I do not believe that the above is specifically stated anywhere in the manual, if so, I was unable to find it. It does follow from footnote no. 112 on page 271 of the manual: "Only arguments up to 127 are storable in an op-code, hence the limit." This was in reference to accessing local registers, but of course would logically apply to keying in something like "LocR 142".
With that mystery (to me) solved, I modified my program to calculate the number of sums n in a k-digit number for k equal up to 13, presented below. It does run a little more slowly than the version limited to 9 digits; there appears to be about a 1.5 second penalty for large sums in 9-digit numbers. It calculates f(13, 117) in about 7.5 seconds. As warned in the manual (p.270), creating so many local registers requires you to be aware of how many steps are in use in program memory. If you have too many program steps used, you'll get a "RAM is FuLL" message when you try to run the program. I had to move some programs to the library so that there were no more than 351 program steps in RAM before it would run. I also added a couple of steps to release the local registers and reset the number of regular numbered registers to 100. Otherwise it stops with no such registers allocated, which would likely affect running other programs.
001    LBL"HHC"
003    #014           constant 14 (10 for k=9, 11 for k=10, 12 for k=11, 13 for k=12, 14 for k=13)
004    x              14 times (target sum -1)
005    +              add number of digits to form count of iterations
006    STO J          store count of iterations in J
007    REGS 000       set number of numbered registers to low value to free space for local regs.
                      Can be set to 0 since only lettered regs are used
008    #112           constant 112
009    STO A          store initial R000 pointer value
010    #113           constant 113
011    STO B          store initial R001 pointer value
012    #126           constant 126 (122 for k=9, 123 for k=10, 124 for k=11, 125 for k=12, 126 for k=13)
013    STO C          store initial pointer to R014
014    #253           constant 253 (213 for k=9, 223 for k=10, 233 for k=11, 243 for k=12, 253 for k=13)
015    STO D          store initial R141 pointer value
016    #002           constant 002
017    STO K          store initial forced zero sum loop counter in K
018    #142           constant 142 to indirectly set 142 local registers (indirection not required for less than 127)
019    LocR ->X       create 142 local registers (102 for k=9, 112 for k=10,
                      122 for k=11, 132 for k=12, 142 for k=13)
020    #001           constant 001
021    STO-> A        store initial 1 in LocR001
022    STO .15        store initial 1 in LocR015 (.11 for k=9, .12 for k=10,
                      .13 for k=11, .14 for k=12, .15 for k=13)
023    LBL 01         Label for overall count loop iteration, easier to keep track of than BACK
024    DSE J          decrement iteration count, skip when zero
025    SKIP 004       skip to update pointers and calculate next sum if not done
026    RCL-> A        done, Recall final sum
027    LocR 000       release local registers (optional)
028    REGS 100       restore 100 standard registers (optional)
029    RTN            finished
030    DEC A          decrement R000 pointer
031    DEC B          decrement R001 pointer
032    DEC C          decrement R014 pointer
033    DEC D          decrement R141 pointer
034    #111           constant 111
035    x=/=A?         is R000 pointer not equal to 111?
036    SKIP 003       if not, skip to check r001 pointer
037    #253           if R000 pointer is equal to 111, set pointer to max local reg
038    STO A          store new R000 pointer
039    SKIP 014       done updating pointers, go calculate next sum
040    x=/=B?         is R001 pointer not equal to 111?
041    SKIP 003       if not, skip to check R011 pointer
042    #253           if R001 pointer is equal to 111, set pointer to max local reg
043    STO B          store new R001 pointer
044    SKIP 009       done updating pointers, go calculate next sum
045    x=/=C?         is R014 pointer not equal to 111?
046    SKIP 003       if not, skip to check R141 pointer
047    #253           if R014 pointer is equal to 111, set pointer to max local reg
048    STO C          store new R014 pointer
049    SKIP 004       done updating pointers, go calculate next sum
050    x=/=D?         is R141 pointer not equal to 111?
051    SKIP 002       if not, done checking/updating pointers, go calculate next sum
052    #253           if R141 pointer is equal to 111, set pointer to max local reg
053    STO D          store new R141 pointer
054    #014           constant 014 (10 for k=9, 11 for k=10, 12 for k=11, 13 for k=12, 14 for k=13)
055    x=/=? K        check if forced zero sum loop count equal 14
056    SKIP 004       if no, proceed to calculate sum
057    CLx            if count is multiple of 14…
058    STO->A         ...force current sum to be zero
059    STO K          reset forced zero sum loop counter to zero
060    SKIP 004       skip sum calculation if sum forced to zero
061    RCL->B         recall previous sum
062    RCL+->C        add sum from 14 sums ago (10 for k=9, 11 for k=10, 12 for k=11, 13 for k=12, 14 for k=13)
063    RCL- ->D       subtract sum from 141 sums ago (101 for k=9, 111 for k=10, 121 for k=11, 131 for k=12, 141 for k=13)
064    STO->A         store new sum in current register pointed to by A
065    INC K          increment forced zero sum loop counter
066    GTO 01         loop back to decrement count, update pointers, calculate next sum
067    END
New version 8 steps shorter:
001    LBL"HHC"
003    #014          constant (10 for k=9, 11 for k=10, 12 for k=11, 13 for k=12, 14 for k=13)
004    x             constant times (target sum -1)
005    +             add number of digits to form count of iterations + 1
006    DEC X         decrement to get the number of iterations required to calculate the target sum
007    STO J         store count of iterations in J
008    REGS 000      set number of regs to low value to free space for 102 to 142 local regs
009    #111          constant 111
010    SDR 003       shift digits right 3 places to create .111
011    #112          constant 112, points to lowest local register
012    +             add .111 to set DSE skip index
013    STO A         Set pointer A to initial value of 112
014    INC X         increment by 1 for initial B value
015    STO B         Set pointer B to initial value of 113
016    #13           constant 13
017    +             add to initial B pointer to obtain initial C pointer value of 126
018    STO C         Set pointer C to initial value of 126 (122 for k=9, 123 for k=10, 124 for k=11, 125 for k=12, 126 for k=13)
019    #127          constant 127
020    +             add to initial C pointer to obtain initial D pointer value of 253
021    STO D         Set initial D pointer D value to 253 (213 for k=9, 223 for k=10, 233 for k=11, 243 for k=12, 253 for k=13)
022    #013          constant 13
023    STO K         store initial loop counter to set every (k+1)th sum to zero in K
024    #142          constant 142 to indirectly set 142 local registers (indirection not required for less than 127)
025    LocR ->X      create 142 local registers (102 for k=9, 112 for k=10, 122 for k=11, 132 for k=12, 142 for k=13)
026    #001          constant 001
027    STO-> A       store initlal 1 in registere 112
028    STO .15       store initial 1 in register 127 (.11 for k=9, .12 for k=10, .13 for k=11, .14 for k=12, .15 for k=13)
029    DSE A         Begin loop to calculate sums, decrement A pointer…
030    SKIP 002      skip when equal to 111
031    #142          constant 142
032    STO+ A        if A pointer is equal to 111, set pointer to max local reg by adding 142
033    DSE B         decrement B pointer…
034    SKIP 002      skip when equal to 111
035    #142          constant 142
036    STO+ B        if B pointer is equal to 111, set pointer to max local reg by adding 142
037    DSE C         decrement C pointer…
038    SKIP 002      skip when equal to 111
039    #142          constant 142
040    STO+ C        if C pointer is equal to 111, set pointer to max local reg by adding 142
041    DSE D         decrement D pointer…
042    SKIP 002      skip when equal to 111
043    #142          constant 142
044    STO+ D        if D pointer is equal to 111, set pointer to max local reg by adding 142
045    DSE K         decrement loop counter setting every (k+1)th sum to zero
046    SKIP 004      skip when equal zero
047    #014          constant 14
048    STO K         reset loop counter to 14
049    CLx           clear x for zero,
050    SKIP 003      if count is multiple of 14, skip to force current sum to be zero
051    RCL->B        recall register pointed to by B, sum(k-1,n)
052    RCL+->C       recall and add register pointed to by C, sum(k,n-1)
053    RCL- ->D      recall and subtract register pointed to by D, sum(k-1,n-10), forms sum(k,n)
054    STO->A        store new sum(k,n) in register pointed to by A
055    DSE J         decrement loop counting iterations required for input k,n
056    BACK 027      if not zero, loop back to update pointers, calculate next sum
057    LocR 000      if zero, final sum complete, release local registers…
058    REGS 100      restore 100 standard registers (optional)
059    END           stop, final sum displayed
Over 7 years after writing the above code, for some reason I felt like entering it into the WP 34S emulator app on my phone. When it did not work, I had to remember how to program the WP 34S, then troubleshoot the program, and found a typo in the above original listing which I have corrected for posterity. Then of course I had to see if I could improve it, and developed the new version above, which is 8 steps shorter (really only 7 since I saved a step by eliminating the single label) and just better overall, I think. A real WP 34S returns results in about 9 seconds for the worst case input of 13, 117. By way of comparison, the same algorithm on a 35s takes about 9 minutes for that input.
