Support for comments /* ... */
02-24-2017, 05:36 PM (This post was last modified: 02-24-2017 06:05 PM by compsystems.)
Hello
One way to better visualize a code, where a function has several arguments (for example input( arg1, arg2, ..., argn), is to write each argument in a separate line
input
arg1,
arg2,
argn
But if you want to comment with // the code generates error, because the comment covers until the end of the sentence (; ), for this we need comments of the form / * * /
PHP Code:
export testInputList()
begin
    local a
bc;
local resetVAL_aresetVAL_bresetVAL_c;
local initVAL_ainitVAL_binitVAL_c;
initVAL_a:={1}; initVAL_b:={2}; initVAL_c:={3};
resetVAL_a:={}; resetVAL_b:={}; resetVAL_c:={};
local ObjectType_AllAllowed := -1;
local ObjectType_Real := 0;
local ObjectType_Integer := 1;
local ObjectType_String := 2;
local ObjectType_Complex := 3;
local ObjectType_Matrix := 4;
local ObjectType_List := 6;
local ObjectType_Function := 8;
local ObjectType_Unit := 9;
local ObjectType_CAS := 14;
local ObjectType := ObjectType_List;
local title;
    case
        if
ObjectType == -1 then title:="Type Allow: "+"Alls" end;
        if
ObjectType == 0 then title:="Type Allow: "+"Real" end;
        if
ObjectType == 1 then title:="Type Allow: "+"Integer" end;
        if
ObjectType == 2 then title:="Type Allow: "+"String" end;
        if
ObjectType == 3 then title:="Type Allow: "+"Complex" end;
        if
ObjectType == 4 then title:="Type Allow: "+"Matrix" end;
        if
ObjectType == 6 then title:="Type Allow: "+"List" end;
        if
ObjectType == 8 then title:="Type Allow: "+"Function" end;
        if
ObjectType == 9 then title:="Type Allow: "+"Unit" end;
        if
ObjectType == 14 then title:="Type Allow: "+"CAS" end;
     default
title:="Type Allow: "+"?"
end;
local ok := 1;
local cancel := 0;
local keyPressedOnMenu := 0;
keyPressedOnMenu := input
a, [ObjectType] },
b, [ObjectType] },
c, [ObjectType] }
title,
"label_a""label_b","label_c" },
"help_a""help_b""help_c" },
resetVAL_aresetVAL_bresetVAL_c },
    if
keyPressedOnMenu == ok then
return ({abc});
    else
        return
"Done";
end;
end
Successful compilation
But not with
PHP Code:
INPUT
//{ resetVAL_a, resetVAL_b, resetVAL_c },
       //{ initVAL_a, initVAL_b, initVAL_c }
); // end input
The problem would be solved in the following way
PHP Code:
INPUT
/* { resetVAL_a, resetVAL_b, resetVAL_c },  */
        /* { initVAL_a, initVAL_b, initVAL_c } */
02-24-2017, 07:51 PM
RE: Support for comments /* ... */
(02-24-2017 05:36 PM)compsystems Wrote:  Hello
input
arg1,
arg2,
argn
PHP Code:
begin
    local a
bc;
local title;
    case
        if
        if
        if
        if
        if
        if
        if
        if
        if
        if
     default
end;
local ok := 1;
local cancel := 0;
a, [ObjectType] },
b, [ObjectType] },
c, [ObjectType] }
title,
    if
return ({abc});
    else
        return
"Done";
end;
end
But not with
PHP Code:
INPUT
); // end input
PHP Code:
INPUT
Would the following be equivalent?
PHP Code:
INPUT
Tom L
Cui bono?
02-24-2017, 07:58 PM
(02-24-2017 07:51 PM)toml_12953 Wrote:  The problem would be solved in the following way
PHP Code:
INPUT
PHP Code:
INPUT
Yes but the compiler does not allow this type of comments = (
02-25-2017, 12:25 AM (This post was last modified: 02-25-2017 12:29 AM by StephenG1CMZ.)
Changing the compiler to allow // comments on each line would be helpful, particularly when you have a long list of data
PlanetDistance:={
0.2,//Mercury
0.4,//Venus
1//AU
I
For function parameters, I have always liked the OPTIONAL ADA syntax for readability and avoidance of getting parameters confused, although for my own code I could remember the parameter sequence anyway without needing it:
TIMED(HOURS, MINS, SECS)
Return 60* ((60*hours)+mins)+secs;
END
Timed(hours=3,mins=2);
Timed(secs=1,mins=2);//the prefixes mean you don't need to remember which parameter is 1st
Timed(1,2,3); // the xxxx= is optional
I could imagine that syntax being useful when using a portable device with a small Screen makes looking up parameters difficult.
An alternative would be to have a way to search for user procedures and parameters, either within the editor (Find...), or by lookup within Help.
Stephen Lewkowicz (G1CMZ)
02-26-2017, 03:39 PM (This post was last modified: 02-26-2017 03:40 PM by compsystems.)
also, if in a future firmware version, it supports comments of the type,
You could directly copy the following sequence of steps (of this forum) to the history view
PHP Code:
expr1:=x^3;
rpnStr:="";
oper:="";
partn:="";
oper:=part(expr1,0); /*returns "^" */
parts:=part(expr1); /*returns 2 */
partJ:=1;
expr2:=part(expr1,partJ); /*returns x */
partn:=string(expr2); /*returns "x" */
rpnStr:=rpnStr partn/* returns "x" */
partJ:=2;
expr2:=part(expr1,partJ); /*returns 3 */
partn:=string(expr2); /*returns "3" */
rpnStr:=rpnStr " "/*returns "x " */
rpnStr:=rpnStr partn/*returns "x 3" */
rpnStr:=rpnStr " " oper/*returns "x 3 ^"  */
currently I have to suppress them =(
PHP Code:
expr1:=x^3;
rpnStr:="";
oper:="";
partn:="";
parts:=part(expr1);
partJ:=1;
rpnStr:=rpnStr partn;
partJ:=2;
rpnStr:=rpnStr " ";
PHP Code:
expr1:=x^3rpnStr:=""oper:=""partn:=""oper:=part(expr1,0); parts:=part(expr1); partJ:=1expr2:=part(expr1,partJ); partn:=string(expr2); rpnStr:=rpnStr partnpartJ:=2expr2:=part(expr1,partJ); partn:=string(expr2); rpnStr:=rpnStr " ";rpnStr:=rpnStr partnrpnStr:=rpnStr " " oper
I can not put comments between each sentence = (
[Image: hp_prime_convertToRPN_image00.png]
02-26-2017, 04:24 PM
The problem is that to do more things with comments requires us to turn it into a 2 step compilation process, with creating duplicate text for step 2. Right now there is not a preprocessor, nor enough memory to really do so on the hardware. There are not plans to support additional commenting methods at the moment.
[/quote]
TW
