Trigonometric regressions on hp 48?
04-11-2017, 03:20 AM
Is there a program or any way to do since cosine and tangent regressions on the HP 48?
04-11-2017, 04:20 AM
RE: Trigonometric regressions on hp 48?
Trigonometric regressions will have to be programmed on the HP 48, as they are not default regressions offered through the Stat menu.
04-14-2017, 06:07 AM
Do you know of any programs for the HP 48 to do this?
04-14-2017, 08:06 PM
(04-14-2017 06:07 AM)thomasross Wrote:  Do you know of any programs for the HP 48 to do this?
You can use SOLVESYS to do a regression using ANY formula (including trig formulas). The documentation for SOLVESYS even includes an example of how to do a regression.
Graph 3D | QPI | SolveSys
04-15-2017, 04:09 AM (This post was last modified: 04-15-2017 04:12 AM by thomasross.)
Thanks! Do you just need to enter how many data entries you have as the third parameter? Is there any way to do it automatically?
04-15-2017, 09:58 AM
(04-11-2017 03:20 AM)thomasross Wrote:  Hi,
Can you post here a data and a regression function to see clearly what you needed exactly?!?
Thanks!
Csaba
04-15-2017, 11:08 AM (This post was last modified: 04-15-2017 11:09 AM by Han.)
Thanks!
Csaba
Here's the documentation online: http://isa.umh.es/calc/ss49docs/solve49.htm
Scroll down to "Example 3: Nonlinear least-squares" to see an example. In your case, you would simply need to change the data; you will also need to change the formula to something like: 'Y=A*COS(B*T ADD C) ADD D'
