(12C) Numeric Solver
04-13-2017, 01:50 AM
This solver uses Newton's method to solve f(x)=0. It is an adaptation of the HP-25 solver (HP-25 Application Programs, Chapter 5). The program uses registers 0, 1, 2, 3 and 4.
Enter the program as listed- it will occupy lines 1 through 38. The formula to be solved will start on line 39 and must end with the command GTO 17.
EXAMPLE-
Solve ln x + 3x -10.8074 = 0
Starting with line 38 displayed, enter the formula:
LN
LST X
3
1
0
8
0
7
4
GTO 17
Store an initial guess in register 1:
1
STO 1
Store the desired tolerance in register 2:
EEX
5
CHS
STO 2
Press R/S to solve. Result: 3.21336
PHP Code:
CLX
STO 0
RCL 1
GTO 39
//xeq formula
ROLL DN
STO 4
1
STO 0
RCL 1
RCL 1
EEX
5
STO 3
GTO 39    //xeq formula
X=0
GTO 37
RCL 0
X
=0
GTO 05
ROLL DN
RCL 4
1
1/X
RCL 3
x
STO – 1
2
Y
^X
SQRT
RCL 2
X
<=Y       //x is less than or equal to y
GTO 01
RCL 1
//answer
R/S
//formula...
GT0 17
04-14-2017, 04:33 PM (This post was last modified: 04-14-2017 04:33 PM by Dieter.)
RE: (12C) Numeric Solver
(04-13-2017 01:50 AM)Dwight Sturrock Wrote:  This solver uses Newton's method to solve f(x)=0. It is an adaptation of the HP-25 solver (HP-25 Application Programs, Chapter 5).
The program calculates h (in R3) as x/1E5. This does not work for x=0 since it yields h=0 and so the derivative gets zero, leading to a division by zero.
But this can be fixed easily:
RCL 1
RCL 1
X=0?
e^x
EEX
4
STO 3
After this change the GTOs of course need to be updated.
One more tip: instead of 2 [Y^X] always use [ENTER] [x]. This is much faster and exact.
Dieter
04-14-2017, 10:15 PM
RCL 1
RCL 1
X=0?
e^x
EEX
4
STO 3
Dieter
Thanks Dieter, I'll try your enhancements and repost.
